3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Microwave Transformer Homemade Stick/Arc Welder
Step 11Dimmer Control and Welding Thin Wall Tubing
The welder was too hot for thin-walled tubing frames, I kept melting holes even with the 1/16" 6013 rods. So I plugged the welder into a variac dimmer and turned the power down about 30%.
That gave me very fine control over power. Marc Lander and I did some very nice welds as seen here. After a few we got good enough to do the same welds with 3/32" 6013 rods and no dimmer and not burn holes.
More tricks - I used my left hand to feed a piece of mig welding wire into the weld to add more metal in and soak up the heat. Here's Marc doing that. Any wire is fine for this, coathangers are traditional for muffler work. Sand off the paint first if you don't like fumes.
Stopping to eat lunch helped a lot also. Your welds won't be good when you're shaky and tired.
I got my variac for free, don't buy one for this, they cost as much as a welder.
A solid-state dimmer that's rated for inductive loads does the same thing and costs a lot less.
If you're feeling particularly fancy, you can add in your own scr-based switching circuitry to vary the power, like this guy did.
13 comments
Aug 7, 2009. 4:48 PMddc1011 says:
How do you tell if a dimmer is solid state and rated for inductive loads. I have checked the website of leviton which is a manufacturer of dimmers sold at home depot as well as the packages and cannot find any references. Thanks
Oct 17, 2011. 10:29 AMtditulio says:
Used this speed control. Tested with a 34.4VAC on full. It does vary the voltage readings under adjustment, so I would say it works. Haven't welded with it yet however.
Oct 24, 2011. 9:26 PMsir bobby says:
When you do weld with it can you post your results here?
Nov 4, 2011. 10:45 PMtditulio says:
First let me say, I have never welded before. This is my first hands on experience.
The box only goes to 15 amps and you will be blowing a lot of them at first. Probably run a 20 amp fuse with no problems. I ran a 30 @ 75% and it started to work properly, then the transistor in the box blew up. Upgrading this or decipating the heat from it will need to be done to go above 15 amp fuse safely. Also, one of the transformer secondaries smoldered, so I need to replace the wire or re-insulate it to have this welder work again. This was probably due to lack of proper heat decipation.
Jun 28, 2011. 4:39 PMapplegeek says:
I think it would be cool if stasterisk added a page on here about how to add taps and switches on the transformer to vary the voltage without buying a special, and probably expensive, dimmer.
Nov 15, 2010. 7:20 AMferball says:
Would a standard light dimmer on the 120 v in wire work for power control?
Jun 26, 2011. 1:56 PMapplegeek says:
You would probably melt it very quickly. They are rated for only 400 watts and welders use much more than that.
Aug 9, 2010. 6:01 AMonkelf says:
would it work with a triac regulator ?
Nov 5, 2009. 9:08 PMThe 4th Doctor says:
Thats the exact variac i have, got it on ebay for 55$ with shipping
Mar 12, 2009. 6:05 PMvernors says:
where do you find a solid-state dimmer that's rated for inductive loads ?
Aug 6, 2008. 6:03 AMdman2two2 says:
Does anyone know what kind of variac dimmer I should use?
Feb 25, 2009. 4:17 PMWyle_E says:
Follow the link in step 11 to Dan's Workshop for the details of SCR control. A Variac (a variable autotransformer) bit enough for this job would probably cost as much as a small commercial welder. You'll also find Dan's big welder, built around *eight* microwave transformers.
Feb 25, 2009. 1:22 PMLeffe says:
i dont want to be rude or something but its not a really nice weld tho :) u went too fast in the middle (becoming a flat weld and creating a track instead of nice weld rings) and ur start and end is too slow wich gives those bumps
but nice work on the microwave oven conversion tho
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
199
Author:stasterisk
Hi! I'm Star Simpson! I'm a real me! See more at [http://stars.mit.edu stars.mit.edu]. photo by [http://bea.st/ Jeff Lieberman] (http://bea.st) stasterisk - my name is Star, and when I wa...
more »
