3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Microwave Transformer Homemade Stick/Arc Welder
Step 3Get some 24 foot chunks of ten-guage wire
We scavenged some heavy wire from an old powerboat the owner was scuttling.
We stripped the outer jacket off and separated the inner conductors to wind new secondaries
on our transformers.
9 comments
Nov 14, 2011. 7:29 PMpyrogreasemonkey says:
alturnative to using thick wire: just wind two wires ! yo can just take many small wires and solder them at the ends to make one big wire.
Sep 6, 2009. 6:03 PMarkfusion says:
I used 12 gauge. is this going to make a difference?
Jun 14, 2011. 6:34 AMapplegeek says:
I suppose it would just make the duty cycle shorter. I've been thinking about using 12 AWG myself because I know I can find lots of unused Romex cable with 12 gauge wire in it.
Dec 6, 2010. 6:35 PMferball says:
I used 12 wire 10 was two thick to get enough windings. Idid melt one coil when my rod stuck rewound and it added a fan to my enclosure and pay a little more attention and no problems. 12 wire makes for less of a "duty cycle".
Jun 23, 2010. 5:04 AMmaxpush99 says:
It would help if you try to have the 2 windings in resonance. after you remove the secondary windings you should weight it. you then use the same amount of copper by weight in your new winding,\ Just calculate lenght by thickness or weight the new windings good luck
Jan 13, 2009. 7:08 AMtaoybb-TH says:
What size of your wire (In mm)
Feb 2, 2009. 12:01 PMautophile says:
Google is your friend. Ask it the size of 10-gauge wire. You'll probably find a site that gives the measurements of all sorts of wire. Bookmark that!
Feb 3, 2009. 7:30 AMtaoybb-TH says:
(removed by author or community request)
Feb 23, 2009. 2:12 PMdesertcat says:
Aluminum is not as conductive as copper. If you are using the same size aluminum conductor as is suggested here for copper, this may be the source of the excess heating you are experiencing. Try rewinding the transformer with larger diameter aluminum wire, or switch to using copper wire. Or add more turns of wire to increase the voltage and decrease the amperage output. You're running 170 amps through approximately 9 gauge wire. I'm not surprised it is heating up.
Feb 24, 2009. 5:17 PMtaoybb-TH says:
It isn't very hot now.That temp I check at my school now I know why it hot.Because my school have a power transformer It give a heavy power to my transformer .now I use in my home(No Power transformer) my transformer are not hot but warm about 30-36'C (Now weather in thailand are hot!! about 33.5°C) I think Copper wire and Aluminium wire conductive are not different so much It work good not bad or very bad and why I don't use copper wire because it hard to winding and a expensive now I studying I don't have very much money.
Jan 31, 2009. 10:14 PMtaoybb-TH says:
tell me please.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
199
Author:stasterisk
Hi! I'm Star Simpson! I'm a real me! See more at [http://stars.mit.edu stars.mit.edu]. photo by [http://bea.st/ Jeff Lieberman] (http://bea.st) stasterisk - my name is Star, and when I wa...
more »
