3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Microwave Transformer Homemade Stick/Arc Welder
Step 9Thick Rod Test
Thick Rod Test
Those skinny 1/16" electrodes cost about twice as much as thicker ones.
We wanted to see how our welder works with thicker electrodes.
The next size up is 3/32", but we got a box of 1/8" 6011 electrodes.
When we pulled one out of the box we both said "wow, that's thick".
We fired up our welder and I welded this bead across the diamond plate with 1/8" rod.
The arc was pretty short but it burned in well and felt pretty good once I got used to it.
I had to shove it in a bit more than I'm used to to keep the arc going, but sticking wasn't a problem. I welded a long bead and used up more than half the rod without stopping.
That's the long weld in this photo.
Then I set the "torch" in this plastic tub so it wouldn't short out to anything.
I checked the transformers, and they didn't even get warm!
3/32" rods are less likeley than 1/8" to blow a circuitbreaker though. For your first welds get 3/32" 6013 rods.
6011 rods have thinner flux and make it easier to see what the metal of your weld is doing, but tend to spatter a bit more.
The next picture is for reference, from
hobartwelders.com
Udate 4/16/2008:
This is now my favorite welder. I made new leads for it from a pair of jumper cables. I left one alligator clamp on for a ground clamp, and added a $6 electrode holder. I've taught a bunch of people to weld using it.
The next photo is Ita welding for the first time, making an awning frame. That project was welded with this welder by total beginners using 3/32" 6013 rods. As you can see we have every other kind of welder, but the homemade ones are more fun.
1 comment
Jul 7, 2009. 8:35 AMBOOJAN says:
I want to build mig welder, but i have problems with the transformer, so can i use the transformers that are used in this Instructable???
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
199
Author:stasterisk
Hi! I'm Star Simpson! I'm a real me! See more at [http://stars.mit.edu stars.mit.edu]. photo by [http://bea.st/ Jeff Lieberman] (http://bea.st) stasterisk - my name is Star, and when I wa...
more »
