Build a Multimedia System Using Raspberry Pi2
Published
Introduction: Build a Multimedia System Using Raspberry Pi2
About: Howdy, we are application engineers in Seeed. Sharing projects with maker community is awesome. Hope you like it XD Seeed is the IoT hardware enabler providing services that empower IoT developers to swiftl...
In this project, I’ll install OpenELEC on Rpi2, and make the Raspberry Pi2 as the Home Multimedia Center.
OpenELEC is an embedded operating system built around Kodi, the open source entertainment media hub. Home Theatre PCs are known to be hard to install and configure, and it can take a massive amount of time to keep them running. OpenELEC, on the other hand, is designed to be as lightweight as possible in terms of size and complexity, meaning your HTPC becomes no harder to configure than your satellite box or DVD player. With its small footprint, OpenELEC is also ideal for today's small form factor systems, so you won't need a big desktop computer in your living room!
If you want to know more info. about OpenELEC, please click http://openelec.tv/home/what-is-openelec .
Step 1: What You Need
Plastic box for raspberryPi
Raspberry Pi 2 Model B
LCD Screen with HDMI
Loud Speaker Box
Step 2: INSTALL THE OPENELEC
  1. Please click http://openelec.tv/get-openelec to get the current release image. As the picture shows
  2. Installing OpenELEC/Writing the Disk Image.
For Linux:
Extracting the archive using the CLI (Command Line Interface) Each distro has a different way of getting to the Terminal however it is usually called something like Terminal or Term. On Ubuntu it can be found in the Applications menu.
Change to the folder where you downloaded the release archive to (let's assume the Downloads folder in your home directory):
cd ~/Downloads
Then extract the archive. It will be named OpenELEC-build-architecture-version.img.gz. We need to usegunzip to extract the archive.
gunzip -d OpenELEC-Generic.x86_64-5.0.0-efi.img.gz
Creating the USB Stick
Now pop your USB Stick in. After you've inserted the USB Stick use dmesg | tail to find out what /dev/device it is. It should be something like /dev/sdX).
You can also use parted or fdisk
parted -l
Disk /dev/sdb: 1016MB
Sector size (logical/physical): 512B/512B Partition Table: msdos Disk Flags:
Number  Start   End     Size   Type     File system  Flags
 1      1049kB  1015MB  1015MB primary  ext4
First make sure the disk is unmounted
umount /dev/sdb1
Next we need to write the disk image. You'll need superuser privileges to do this, whether you use the root user or sudo. Either way, you need to execute the following command:
sudo dd if=OpenELEC-Generic.x86_64-5.0.0-efi.img of=/dev/sdb bs=4M
Lastly ensure the changes are synced to the USB Stick before removing it:
sync
For windows:
This will install the OpenELEC disk image to your USB stick / SDcard using Windows.
Requirements:
Instructions
Extract the image using 7zip.
Insert your USB Stick / SDcard into your system. It should appear as a new drive letter.
Run Win32DiskImagerSelect the image file and verify the destination drive letter is correct, then click write.
When it is finished you can safely remove the USB stick / SDcard by right clicking on the drive in windows explorer and selecting eject.
Safely remove your USB key.
For MAC
If you are using a Mac please click here.
Step 3: Hook Up Your Device
After you install the OpenELEC, do as follows:
  1. Insert the micro SD card you prepared into your Raspberry Pi 2 (the slot is indicated by arrow #1 in the image below).
  2. Connect a network cable from your local network to the Ethernet port on the board or connect a WiFi dongle to the USB port on the board.
  3. Connect an HDMI monitor to the HDMI port on the board.
  4. Connect the power supply to the micro USB port on the board.
Step 4: Have a Try
Now, you can have a try to use it, and install some music APPs, listen to the music, and enjoy yourself.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    5 Discussions
    and don't forget to add the TVAddons package to it. opens up a WORLD of streaming...
    I have been using these as well. only i add a build on to it for easier use. ARES builds are great there is multiple builds on this one that you can choose from!
    RickG5
    2 years ago
    Small world, I've been building one of these myself, based on OSMC, a Kodi-based distribution similar to OpenElec.
    If anyone's followed this instructable - and I'd encourage people to, these media boxes are hugely useful - then you can easily share folders with Windows or Mac machines on the network using Samba. This, with a USB HDD and a powered hub, makes a full-featured but inexpensive media server. Plug a DVD or Blu-Ray into that hub, and you can play video discs on it (although you will have to buy a MPEG-2 license from the Raspberry Pi folks for a couple of pounds; it's not difficult).
    And a massive bonus; what I didn't realize until I tried it is that most modern TVs support HDMI-CEC; that is, passing control signals to devices plugged in via HDMI *from the television*. In a nutshell, that means that there's a very strong chance that as soon as your Kodi system is plugged in, you can control it with the cursor buttons on your TV remote.
    DVD players controlled from the TV remote. It's the impossible dream we've been promised since the eighties.
    What a coincidence. we all should enjoy the fun of the progress of science and technology, wish you enjoy your system
