3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Nintendo NES PC
Step 4Placing the hard drive
The hard drive will sit under the motherboard to maximize space efficiency. First I covered the hole I'd cut (see step 2) with some plastic so the hard drive bottom wouldn't be seen from the outside.
Next, I placed the hard drive (marked red in the picture) and covered the top with duct tape so as not to short-circuit the mother board, which will sit directly on top.
NOTE: I later found out the 2.5" laptop HD I had was broken, so I ended up using a regular 3.5" 160gb one. It fit just as well, but was a bit higher so the motherboard had less space vertically.
3 comments
Jun 5, 2010. 3:45 PMtom12385 says:
I thought that Duct Tape conducts a small amount of electricity, since it has metal in it or something
Apr 19, 2009. 4:51 PMSuperInventor863 says:
how did you cut off the little things sticking up that was in the way
Jun 6, 2009. 7:29 AMmightymax83 says:
use a dremel to cut those things off... (its one of the tools that he mentions earlier) you can probably find on of these at home depot.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:hatsuli
