loading
Step 6: Placing the DVD/CD drive
I decided to use heavy-duty duct tape to fix the optical drive to the top of the case. Slimline optical drives are very light, so the tape worked fine. I had to cut off a part of the case (check the picture) to fit the drive.
I built a NES PC last year, and it's fairly easy once you have everything you need. If you're going to build a new NES PC, I suggest using a Zotac IONITX-A-U motherboard, since it comes with a 90W power brick that connects to the NES like the original NES power connector. It also has a dual core Intel Atom processor, and Nvidia ION graphics, which are capable of running 1080p Bluray movies. The Silverstone TOB02 is the only slimline Bluray drive I know of. I use a tri-color LED for the Power LED, it lets me use it for power and HDD activity. I have a third color available if I ever need it. <br />
&nbsp;Great job, that looks fantastic, other than the USB ports being slightly uneven from each other (I'm a nitpicker hehe, srry). &nbsp;My questions for you are:<br /> <br /> - how did you go about connecting the tri-color LED to the motherboard<br /> - the frontal USB ports, did you use a custom mounted board or something and if so how did you attach it to the board<br /> - do you still have any information from this project like schematics, etc?<br /> - how many fans did you use and what size<br /> - did this require much more cutting etc?<br /> <br /> Thanks in advance. &nbsp;I've got most of the components already picked out... not looking to rush in until I'm sure I can do this!<br />
Lots of hot glue to attach the USB ports, and all you need for the LEDs is to wire the single ground of the tri-color LEDs to both the grounds on the board (for the Power and HDD activity LED headers) I didn't think it through too well, I just did it. More pics at http://img198.imageshack.us/g/img2409t.jpg/ if you want to see how it looks inside. I used the fan that came with the motherboard, and 40mm fans. I&nbsp;should have cut some of the plastic covering the top vents off on the inside so it actually vents some air, it's pretty much an oven right now. I also used lots of hot glue for the motherboard headers. It required a fair bit of cutting, but not too much. <br />
&nbsp;Wow thanks for the awesomely quick reply. &nbsp;That's pretty much along the lines of what I was thinking, except i had no idea wiring in the LED was so simple, thanks! &nbsp;<br /> <br /> After looking at your imageshack photo's I have one additional question. &nbsp;Where your blueray drive slides out, it appears to have two &quot;faceplates&quot; I guess you could call them, one white and one black. &nbsp;Is this a feature of the drive or did you rig this up? &nbsp;I'm considering using a regular CDR/DVDR slim drive (laptop style) for this, just curious how yours works. <br /> <br /> &nbsp;When you open the drive does it open the NES cartridge hinge automatically or do you need to pre-open it? &nbsp;Not a big deal, just curious.
you could use some thick (or strong) wires to make the drive open the door on its own. with a normal drive you could use the guiders onthe sides to pull the door open
The slimline drive I use doesn't have room for a motor in it to open it automatically, so I'd also have to add a motor. It's basically a laptop drive; you push the button and pull it open.
well, then i guess you got me there. i wish i had a nes to use, but i dont want to wreck my only one. (and it works)
Put the working insides of the NES in an old broken toaster or something, instead of toast going in you put a game in? :o
<p>You don't put toast in a toaster</p>
great idea, but i still probably wouldn't do it until i bought a new nes first. you should make an instructable though!
I used the Silverstone TOB02, which comes with both a silver and black bezel. <br />
<br /> This posting has won today&#39;s &quot;I Made It&quot; Challenge. For winning you will receive a 3 month pro membership!<br /> <br /> Thanks for using instructables!<br /> <br /> https://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/<br />
This is great - thanks for the MB&nbsp;recommendation. Does that MB require a fan? Is it loud / quiet? I'm wondering if you've experienced any problems with heat in such a small case.<br />
It comes with an optional slim fan but I didn't have room to put it on the way it was meant to go, so I used a 40mm fan to blow from the side. I'm not sure how loud the fan is by itself, but I know that I've used so many 40mm fans in it that it's really loud. I could optimise the airflow a bit more but I've kinda just left it. The atom gets to 80C under full load sometimes, but it should be fine. The ION gets to about 55C. <br />
It is with great sadness that I share the news of hatsuli's death. You can read more about it here:<br/><a href="https://www.instructables.com/community/Build-a-Nintendo-NES-PC-author-hatsuli-dies-of-can/">https://www.instructables.com/community/Build-a-Nintendo-NES-PC-author-hatsuli-dies-of-can/</a><br/>
<p>wow!!1</p>
<p>anyone know of a 3D case like this i can send to print. i would love to make this my next gaming pc for work/ take around and stuff. I can't seem to find anything. </p>
<p>duct tape is conductive. </p>
<p>Great Idea!</p>
Um.... I don't know how to put this....but... THAT IS SO ADVANCED AND AMAZING!!!
would be an wlawsome steam machine
awesome
<p>I recently made one.</p><p><a href="http://www.ebay.com/itm/NES-PC-AMD-Quad-Core-AMD-Radeon-HD-8400-4GB-RAM-500-GB-HDD-USB-3-0-All-in-One-/111628353837?" rel="nofollow">http://www.ebay.com/itm/NES-PC-AMD-Quad-Core-AMD-R...</a></p><p>I need rent money so I'm parting with it. 600 or best offer.</p>
<p>sooooooo advanced</p>
I want to build one of these, and have been looking around for my options. I came across an acer one that has hdmi out with a broken screen on ebay. intel atom 1.66, 320gb hdd, 1 gig of ram. I checked dimensions, and the components should have no problem fitting in NES. This would even make the little retro box wireless if ever needed. What are you thoughts? I could snag this cheaper than mini itx mobo.
Just like to say a big thanks for this idea, its taken a while to sort out !
I made a couple cases like this. Welding/soldering with ABS plastic also looks good with some practice. <br>http://www.speedlimit88.com/indoors/snes/
How about an external USB for the HDD? Or if you don't mind a little extra expense one of the SSD's for internal.
As you could get a really small one and run an old windows or something like XP or whatever is handy.
I was thinking SSD would be nice too.
Great Job on this project! now i just need to buy a nes! just a suggestion but if you put a piece of wood or something under the lid at an angel, then the drive when ejecting will push the lid up when it opens. nice project!
anyone ever thought of using a mini/bare bones pc such as a Foxconn?<br> <a href="http://www.newegg.com/Product/Product.aspx?Item=N82E16856119056" rel="nofollow">http://www.newegg.com/Product/Product.aspx?Item=N82E16856119056</a><br> figure rather than struggling with space constraints just use a pc built with space constraints in mind.
I was thinking the same thing. By the time the build is done you could spend $300, or just buy a mini pc or an old netbook for under a $100. It's cheating for sure, but it is quick and painless. Of course, this is a 5 year old instructable so I'm sure that's what he would have done now.
Here is the NES Media PC I have put together. http://bobinc.blogspot.com/
https://www.instructables.com/id/Xbox-Hackintosh/ Mine is similar as yours. Btw you cant put graphics card to a pci slot... pci slot uses something like wireless and other computer accessory. but very good work!
<a href="https://www.instructables.com/id/Xbox-Hackintosh/" rel="nofollow">Xbox hackintosh<br> <br> a</a>nd<br> <br> <a href="https://www.instructables.com/id/How-to-make-a-tablet-pc-from-an-old-laptop/" rel="nofollow">make Laptop tablet pc</a>
You could also use the switches from <a rel="nofollow" href="http://www.allelectronics.com/cgi-bin/item/ISW-4/700/PUSH_SWITCH_ASSEMBLY_.html">here</a>. They are much smaller, and can still be mounted in the case the same way.<br/>
Here is an updated link for the push switch assembly in case anyone wants to order one.<br><br>http://www.allelectronics.com/make-a-store/item/ISW-4/PUSH-SWITCH-ASSEMBLY//1.html
You can just remove the copper part on top, and the pin under it and use the original switches just fine, turns it into momentary. Reset is already momentary.
Heh, you're right :) I didn't know those existed.
It doesnt cost much to do this.. The NES i got on ebay for 15$, the cd drive i got from an old PC, the4 motherboard i bought on newegg.com for 115$ it was an mini itx as well.&nbsp; the cables r cheap.. u can get them on dealextreme for like 2$&nbsp; the picoPSU goes for around 60 bucks with the adapter included<br /> so all and all it will cost 250$<br />
If all you want is to run emulators, one could skip the hard drive and install a small OS to a flash stick. Most modern mobos can boot from them. That would save space, heat, power consumption and some money on IDE adapters.<br>There are some even smaller form factors than itx that have processor, ram, graphics, sound and storage all on-board, meant for embedded systems but would work for this build too.<br>Also if one was clever he might add a piece of structure that would push the cart lid up as the cd tray slid out. Slick.
How would you remove the plastic? I dont own a dremel and Im not planing on spending &pound;50+ for a single use.
soldering iron, heat it up and melt the plastic, or a handsaw. or a cheap dremel from harborfreight
any clue if a dreamcast emulator would run on this?<br />
I'm not THIS tech savvy, but I know a lot more than my piers. Dreamcast emulators are very heard to set up. You need a lot of things. The only tutorial movie I've seen uses the dreaded torrent file.<br />
whats wrong with a torrent file.
I got dreamcast working with ease on my laptop, so it must be possible
im thinking about doing this, but im gonna wire up the controller ports to either parallel or serial and map them so they can still be used
do you know how much ths would cost? i would love to make one, but have a very tight budget
About This Instructable
756,743views
1,347favorites
License:
More by hatsuli:Build a Nintendo NES PC
Add instructable to:
