3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a PVC Fig Rig
Build a PVC Fig Rig
A Fig Rig is a circular camera mount designed to simulate the look of a steadicam. Manfrotto sells them for about $400. Make an even better one for under $10.
Step 1Look at a real Fig Rig
A Fig Rig works by spreading out the center of gravity across the rig. Instead of the camera capturing all your hand movement, your hands are away from the camera, but at the same level so you not only get smoother movement, but more control as well.
32 comments
Nov 30, 2011. 5:36 PMirosas says:
this looks great, but is there any way you could give me the measurements?
Nov 29, 2011. 7:34 PMolympus201 says:
If you are handy with wood, you could make one just like a picture frame with a cross bar. And maybe with a few hinges and bolts to make it fold up. Or even cut out a circle of plywood, and cut out the center piece. A few bits and pieces and maybe a bracket for the bolt to hold the camera.
Apr 8, 2007. 3:24 PMBrother_Bear says:
Since we don't get this kind of PVC tubing in Sweden il make mine out of wood
Jul 25, 2011. 10:00 AMBeFit says:
I live in Italy, so I know they are not easy to find, you should look at big electric suppliers stores, they sell rigid pvc tubes of various diameters, I think they use it to protect the wires, the only downside is that they don't have any T connections, only 90 degrees, end caps, and 180 degrees connections.
I made my fig rig from only one piece of 25mm pipe, about 1,6m long, I bent it with heat to a circular shape, with a reversed V on the base, to make directly the camera support with only one piece of pipe, and connected the ends with a 180 connection. It's a hybrid between a fig rig and a halo rig, it has a diameter of 0,5m, so a little bigger than a fig rig, but I'm not that much impressed with it stabilisation capabilities, it gives decent results only if I'm standing still, and it reduces only "rotational" shakiness.
Nov 13, 2008. 3:55 PMshylock says:
No PVC tubing? How come?
Nov 13, 2008. 11:39 PMBrother_Bear says:
Well we do have PVC tubing just not the plumbing kind you yanks have. and the kind we got is kinda flimsy and weight aslong as its not to much a good thing in a steadycammish project.
Feb 19, 2009. 7:19 AMCatflavor says:
In Sweden you have PE-Xa (cross linked polyethylene) which is usually used for underfloor heating (nice and springy, but maybe too flexible for this project) If you want something which will keep the shape you bend it to, try PAL pipe (as above with an aluminium layer which makes it form-stable). You can get both of these from plumbing suppliers.
Apr 17, 2007. 7:01 PMCementTruck says:
What about tweaking a Hula Hoop, or some flexible copper tubing?
Apr 23, 2007. 4:46 AMBrother_Bear says:
I'm thinking that'll be to flimsy. I would rather make it from half hard rigid copper tubing instead and solder it together.
Aug 22, 2007. 6:39 PMlordofthedonuts says:
I've just made mine with a 24in hula hoop with a wood bar in the middle, its strong, sure i can bend it, but its not easy, the wood bar in the middle help a lot to give it strength. I tie-wrapped some gray copper tubing insulation to it and, i'm considering bicycle cork tape it'll be more comfortable. The only thing is the 24in rim is too big for my small Canon Elura 100 (it's like 4x3x2.5 inche).
May 15, 2007. 10:15 AMlaernmoer says:
I would think you could try using a bicycle rim, if you can find a used one in decent condition. Take out the spokes and mod it.
Jul 4, 2011. 8:16 PMdwosullivan says:
Looks like a good way to use up some old aluminium bike rims....
Jul 10, 2008. 4:53 PMpielroja says:
I made mine with a direction wheel of an old car and a piece of wood
Jun 29, 2007. 11:12 AMwacamoledip says:
this is really cool i was about to go buy one for around 300 bucks but now im not!!
May 22, 2007. 4:45 PMdancmarsh says:
Here's an idea, why not go to a junkyard, get a decent looking steering wheel for next to nothing and use that. It would already have grips etc.
Apr 14, 2007. 11:45 AMbethehammer says:
Nice Job! Also, many of the consumer camcorders come with small remotes... mounting it to one of the grip areas would allow you to control the zoom feature, record, etc... Thanks for Sharing!
Feb 6, 2007. 9:15 AMmr bkilled says:
Man the idea of the fig rig sounds great but wouldent you be sacrefising the use of zoom due to the fact that if you have both hands on the side bars you canot acess the zoom control.
Dec 9, 2006. 6:03 PMchr says:
If you need to film something more smoothly than handheld, and don't have the time to make a rig. Try filming with a tripod attached. Fold the legs out, but dont extend them lengthwise. Find the center of gravity on the tripod with the camera connected, and hold the rig at this spot. Works great.
Jul 24, 2006. 8:19 PMmensmaximus says:
It's similar to leverage. A large movement at the circumference causes small movement near the centre. This rig still needs a camera counterweight and gimbal. It could also use a 'cross' attachment at the bottom for floor shots.
Nov 21, 2006. 11:14 AMdannytheman says:
I agree with mensmaximus. However can someone suggest how that can be created.
Oct 16, 2006. 2:03 PMTwist says:
I built one of these recently. Awesome!
Aug 14, 2006. 1:49 PMTwist says:
Could I get a parts list? This would be great for my next movie.
Jul 31, 2006. 5:47 PMTheDugger says:
The PVC rig looks functional, and unattractive. Have you thought of building one by bending PVC. I ran into this site that shows how to bend PVC using heat and sand. http://www.pvcworkshop.com/bendpipe.htm
Jul 22, 2006. 4:41 PMfungus amungus says:
"A Fig Rig works by spreading out the center of gravity across the rig" You can spread out the center of gravity now?
Jul 21, 2006. 11:32 AMenero says:
Sounds good, how about some more detailed pictures (or at least one full picture) and measurements?
Jul 22, 2006. 12:15 PMsaites2001 says:
Your video doesn't seem to be working.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:esotericsean(SeanDuran.com)
