This paintball mine is based (i.e. ripped-off) from a patent I found online. (US # 6,688,234 B2) Browsing patents online is a great way to come up with cool ideas for your own projects! The mine is a small canister that you bury in the ground, filled with liquid paint. A standard 12 gram CO2 cartridge is inserted upside down into the canister. A top with a plunger centered over the cartridge is screwed on. When someone steps on the plunger the cartridge is pierced, pressurizing the canister and expelling the paint. I feel the original patent has a simple, but serious design flaw. Look at Diagram #1 below. When the CO2 is released it follows the path of least resistance, and blasts directly out of the holes, carrying some, but not all, of the paint with it. It also tends to create more of a thin “aerosol spray” with the paint. Diagram #2 shows my design, which adds tubes/nozzles in the holes with a small gap beneath them. When the CO2 is released, it cannot travel down to the tubes, so instead it pressurizes the canister, forcing almost all of the paint out before it can escape out through the tubes. This results in more of the paint being expelled in a thicker and more forceful stream.
1. larger spray radius, with the paint tubes less centralized. with your design, it looks like the paint only goes onto the bottom of someones shoe, if they step on it directly. I reccomend making the paint tubes come out the sides, and curve upward, so as to spray in a wider radius, to possibly hit multiple players.
2. Make a larger contact plate, or modify it to work via tripwire. At the moment, it looks like the trigger is only about an inch in diameter, easily pressed. you should increase the surface area of the plate. Maybe just glue some sticks or the lid of a tin can to it, as long as it doesn't get in the way of the spraying paint, it cant hurt.
amazing mine! i am i the process of making one to use flour instead of paint, for airsoft.
Now THAT would make you watch your step, and actually you could just leave it there as it'll get better with time (and the sun). From there the possibilities are endless.
I like that.
like, make the spray parts wider and then just put a paint ball in each?
idk if they would be propelled fast enough to break, but what do ya'll think?
Well, I didn't feel it was really necessary. It felt more like a gimmick to me. You dont fill/prime it until you are ready to use it, and I'd hate to set it all up and forget the pin. So I just left it out. Also I didn't want to add any additional holes for the gas to escape from besides the tubes.
Nice project, are the CO2 canisters reusable at all? Or do you just have a to buy a whole bunch.
3” ABS Cap- $3.68
3” ABS Threaded Adpater- $3.74
3” ABS Threaded Plug- $1.25
½” PVC Cap- $.25
½” PVC Union(coupling)- $.30
½” schedule 40 PVC pipe(5ft)- $1.50
¾” schedule 40 PVC pipe(5ft)- $1.60
¼” Pex tubing(5ft0- $1.68
sorry if that was confusing. i'll make an ible if I make it.
tell me you ideas on that
