3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Paintball Mine
My friends and I enjoy playing paintball out in the Arizona desert on occasion. It’s great fun, but sometimes pelting someone with a couple hundred paintballs traveling at 300 feet per second just isn’t enough. Sometimes you just need something extra…. So I built the paintball mine that you will see in this instructable!
Step 1Concept
Concept
This paintball mine is based (i.e. ripped-off) from a patent I found online. (US # 6,688,234 B2) Browsing patents online is a great way to come up with cool ideas for your own projects! The mine is a small canister that you bury in the ground, filled with liquid paint. A standard 12 gram CO2 cartridge is inserted upside down into the canister. A top with a plunger centered over the cartridge is screwed on. When someone steps on the plunger the cartridge is pierced, pressurizing the canister and expelling the paint. I feel the original patent has a simple, but serious design flaw. Look at Diagram #1 below.  When the CO2 is released it follows the path of least resistance, and blasts directly out of the holes, carrying some, but not all, of the paint with it. It also tends to create more of a thin “aerosol spray” with the paint. Diagram #2 shows my design, which adds tubes/nozzles in the holes with a small gap beneath them. When the CO2 is released, it cannot travel down to the tubes, so instead it pressurizes the canister, forcing almost all of the paint out before it can escape out through the tubes. This results in more of the paint being expelled in a thicker and more forceful stream.
189 comments
1-40 of 189next »
Apr 26, 2012. 11:35 AMKontaKt says:
How are you supposed to bury this thing without any of it showing but not have the spraying tubes underground?
Apr 5, 2012. 4:06 PMParacord Ninja16 says:
Instead of using a PVC pipe cutter i just use a hack saw.
Mar 16, 2012. 6:10 PMDa Person who plays paintball. says:
Another good idea is to make a tripmine. You connect a wire to the Co2 thingie, which goes into the nail, and then when the Co2 moves up the tube, it goes through a tube surrounded by paint, which goes into the barrel too. (I dont know what principal :P) It then comes out and hits a thin mesh, which spreads it thinner. This will spray anyone who trips the line. And maybe some other people too.
Feb 29, 2012. 2:15 PMAron313 says:
Whyd you post this in an airsoft group?
Feb 13, 2012. 4:14 PMjohn209 says:
I working on a tripwire version of this mine, I going to post it when I'm done, I just started the prototype a day or two ago.
Jan 22, 2012. 3:40 PMAron313 says:
Thats why i like airsoft because i can go home and lay on the couch after a game and i dont have paint all over me. I also like the airsoft mines better!
Nov 24, 2011. 4:29 PMilpug says:
I saw this a while ago, and, remembering how cool it is, decided to come back and suggest some improvements.
1. larger spray radius, with the paint tubes less centralized. with your design, it looks like the paint only goes onto the bottom of someones shoe, if they step on it directly. I reccomend making the paint tubes come out the sides, and curve upward, so as to spray in a wider radius, to possibly hit multiple players.
2. Make a larger contact plate, or modify it to work via tripwire. At the moment, it looks like the trigger is only about an inch in diameter, easily pressed. you should increase the surface area of the plate. Maybe just glue some sticks or the lid of a tin can to it, as long as it doesn't get in the way of the spraying paint, it cant hurt.
amazing mine! i am i the process of making one to use flour instead of paint, for airsoft.
Aug 31, 2011. 10:16 AMaesquivel says:
Great instructable, though you could go a notch up over the terrorist scale and fill it with pee.
Now THAT would make you watch your step, and actually you could just leave it there as it'll get better with time (and the sun). From there the possibilities are endless.
Nov 24, 2011. 4:10 PMilpug says:
You have an evil mind.
I like that.
Oct 12, 2011. 12:23 PMdeobomb says:
its adapter not adpater lolollol
Nov 24, 2011. 4:09 PMilpug says:
It's "LOL" not "lolollol."
Jun 27, 2011. 7:28 PMacarlson5 says:
could u make this shoot 4 paintballs?
like, make the spray parts wider and then just put a paint ball in each?
idk if they would be propelled fast enough to break, but what do ya'll think?
Nov 5, 2011. 3:10 PMhightekrednek2396 says:
it probably would if you could get the right size pipe and smaller chamber
Aug 13, 2011. 5:24 PMhungyhipo 2 says:
is there a way to convert this to airsoft. i was wondering how i would do that.
Oct 4, 2011. 12:19 PMwchbeast says:
in airsoft,pellets arnt in landmines... powder is so if you want to covert it to airsoft fill it with powder or baking soda instead of liquid paint
Aug 16, 2011. 5:59 AMreddevved says:
Probably just use pellets smaller than the tubes.
Sep 28, 2011. 12:21 PMwierdguy03 says:
Idea, flip the co2 canister and put the puncture screw in the mechanism from the top, as well as the escape holes for the gas. This way you won't add another hole in the canister/container for the gas to escape, and (with the escape holes for the gas at the upper end of the canister housing the gas will easily go to the void space at the top of the container, instead of forcing it's way through the paint first. Just suggestions, and GREAT land mine!
Sep 22, 2011. 4:44 PMI1FaLLenAngel1I says:
I noticed on the PDF file has a safety pull pin hooked to the top, is there any reason you didn't add that in your version? and also your mine is pretty sick.
Jul 27, 2011. 7:58 PMtmckenzie1 says:
well i just built mine today and the problem im having is the co2 let out is shooting through the cemented pvc pipe that holds the co2 in place with the screw in it so i just re did it and set it out for the night and maybe if i keep re aplying it each day it will get stronger idk
Aug 24, 2010. 6:56 PMMolybdenum says:
How do you manage the logistics of placing and retrieving the mine?
Aug 30, 2010. 6:29 PMMolybdenum says:
so your field allows you to just walk on an bury stuff between games? I guess I'm asking more about permission from the refs, and and when you get time to set and retrieve.
Sep 13, 2010. 1:25 AMsmeeves says:
He said he played out in the desert.... Don't think he uses these in fields.
Nice project, are the CO2 canisters reusable at all? Or do you just have a to buy a whole bunch.
Jul 26, 2011. 9:01 PMtmckenzie1 says:
well its a 12 gram co2 canister so there not reusable
May 5, 2011. 5:39 PMHuntman00 says:
or you can bury it before you switch sides... LOL someone may be pissed though
Sep 28, 2010. 8:45 PMspenfisher12 says:
i dont think they are reuseable you just gotta keep buying theme
Nov 24, 2011. 4:11 PMilpug says:
you do have to keep buying them, but they are cheap, and you get a lot of bang for your buck.
Jul 20, 2011. 8:55 AMpbman123 says:
dude nice ible, and your paintmine way better than mine
Jul 14, 2011. 1:52 PMginger20037 says:
I woulda tricked one of my friends into testing it out xD
Jul 14, 2011. 1:44 PMginger20037 says:
hahahaha xD That's awesome, and maybe even a little evil xD
Jun 2, 2011. 10:42 PMloku1125 says:
how much did it all cost
Jul 14, 2011. 4:52 AMaleutphova says:
it cost me 30 dollars because i had to buy drill bits and glue. with out them it would cost u under 15 dollars for the tubing and pvc.
3” ABS Cap- $3.68
3” ABS Threaded Adpater- $3.74
3” ABS Threaded Plug- $1.25
½” PVC Cap- $.25
½” PVC Union(coupling)- $.30
½” schedule 40 PVC pipe(5ft)- $1.50
¾” schedule 40 PVC pipe(5ft)- $1.60
¼” Pex tubing(5ft0- $1.68
Jul 12, 2011. 6:25 PMaleutphova says:
does it have to be a 5/32” x ½” Metal Screw or can i just use a small screw
Jul 9, 2011. 12:26 PMElectronics Man says:
Awsome Idea!!!
May 22, 2011. 11:44 PMMadBricoleur says:
A much "greener" variant of this would be to use a refillable compressed air system, using water as the "paint". after all, summer's just around the corner! :) (the trigger could be some sort of quick dump system. like this maybe. just inverted, upside down, and the valve opens when a small screw with the rubber seal is pushed out, not pulled in, of a pipe... thru which the air would pass towards the opening once the seal is broken. so basically the air travels up the pipe when you push down on the seal that breaks on its bottom end, forcing air through the bottom, up through the pipe, out side holes at the top (which is capped), and down on the fluid that goes in turn up the tubes...
sorry if that was confusing. i'll make an ible if I make it.
May 22, 2011. 9:21 PMilpug says:
doing this, but for Airsoft!!!
May 22, 2011. 4:02 PMMusicman41 says:
Have you considered modifying it to have a larger blast radius? If you put a couple of the outlet pipes at an angle, instead of straight up, it will hit bystanders as well. Also, ever considered a way for remote detonation?
1-40 of 189next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:kaptaink_cg
We spend our youth trying desperately to fit in, and then the rest of our adult life doing whatever we can to stand out in the crowd.
