3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Paintball Mine
Step 7Mine Top
Mine Top
Drill a pilot hole in the exact center of the threaded plug.. Then drill a ¾” hole through the plug. Our plunger will be going through this hole, but unfortunately the ½” PVC has an outside diameter that’s a little bit more than ¾”  You will have to enlarge the hole just enough so that the plunger will slide through it freely, but not too loose that it wobbles. I used a dremel with a sanding wheel. You could also try a large rasp, or heavy grit sanding paper wrapped around a dowel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:kaptaink_cg
We spend our youth trying desperately to fit in, and then the rest of our adult life doing whatever we can to stand out in the crowd.
