3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Pair of Helping Hands
With just a few items you may have around the house you can build a soldering, gluing, or assembly jig. Its an extra pair of helping hands.
Step 1Gather the parts
Gather the parts
1. Items required: a) 2 five inch pieces of 12 gauge copper wire which can be taken from home wiring cable, b) two solderless ring lugs, c) two mini alligator clips, d) a 3" x3" block of wood or decorative molding - available at your local home improvement store, e) one small wood screw (and a suitable drill bit for the pilot hole).
90 comments
1-40 of 90next »
Oct 21, 2011. 4:04 PMspystealth1 says:
Wow! I took apart a cell phone just like the one being dissected in the photo of the helping hands! Too cool!
Dec 1, 2007. 9:46 PMdenilsonsa says:
Very simple and useful idea. I made my own third hands loosely based on this instructable. This also looks like a very popular one, with many comments (68 right now), and I don't know if what I'm writing here has been already written on other comments.
- I've not used the ring lugs. I've just made a small ring using the copper wire and attached it to the wood with a screw. Actually, I've used one screw for each copper wire.
- I've used 2 small alligator clips (useful to hold small parts and thin wires), plus 2 bigger alligator clips (useful to hold bigger things, like a PCB). There is also a space "reserved for future use" onto which I might add a bright white LED and maybe a small fan (like this).
- I've tried to solder the alligator clips to the copper wire, but I failed. The solder did not fix the clip to the wire strongly enough. It broke a few seconds after using. I'm still looking forward to another solution (maybe I should try glue? or maybe just using pressure should be enough)
I still don't have any photos of it (and it looks ugly, anyway :) ), but it has already been damn useful! Thank you for this simple but effective idea.
Jan 25, 2011. 2:21 PMmartzsam says:
Use JB weld to hold on the alligator clips.
Jan 25, 2011. 4:59 PMdenilsonsa says:
And what is JB?
Jan 25, 2011. 5:03 PMdenilsonsa says:
Okay, found it here: http://en.wikipedia.org/wiki/JB_Weld
I've asked because, since I don't live in USA, I didn't know about that product.
Jan 25, 2011. 5:46 PMmartzsam says:
Yeah, JB weld is the brand name of a fast weld adhesive. (One fluid metal, one hardener.) Similair to epoxy glue.
May 30, 2006. 1:32 AMretrod1ct says:
Great idea. I stumbled across some slate at the hardware store. It makes for a more stable base.
Jun 12, 2009. 3:47 PMunclouded says:
Thanks for suggesting this. It prompted me to look for junk lying around that's compact yet heavy for the base:
Jan 3, 2011. 1:49 AMbeehard44 says:
lol nice idea
Jun 15, 2009. 3:50 PMReCreate says:
Hey! Is that a western digital hardrive? Is it by chance the Caviar 33100 HDD?
Dec 10, 2006. 10:51 PMPixlGnome says:
IR Remote? Looks realy bad condition heheh.
Jun 20, 2010. 6:51 AMMelty Mcface says:
I imagine the arms also act as reasonable heat sinks when soldering?
Jun 16, 2010. 10:44 AMsexysav says:
ti_marners last reply was excellent! I never thought of that. thank you.
Jun 17, 2009. 9:42 PMdeerfishgoat says:
soo wat does this do???
Jul 8, 2009. 1:06 AMthepaul1993 says:
it holds you project in place wile you work on it
Nov 10, 2008. 3:20 PMjrt42 says:
How about a wire coat hanger for even more strength.
Jun 12, 2009. 3:41 PMunclouded says:
Thanks for suggesting this! We don't have any sturdy wire so I wasn't going to build one, but we do have wire coat hangers and now I've built one, so thanks again.
Jun 12, 2009. 3:43 PMunclouded says:
I also meant to say that they are really stiff and I have to use pliers to move them but they also hold stuff fast.
Mar 7, 2009. 5:06 PMwolf555hound says:
I've tried that, but for me, its way too stiff to us.
Nov 11, 2008. 7:20 PMm85476585 says:
I made one of these a while back, but I found it too springy to be useful, and it didn't hold things other than a PCB very well at all. I recently bought a $30 mini-vise, and I have found it to be extremely useful. I would say it is probably the second best investment I have made for soldering (best is my temperature-controlled soldering station, of course!)
Aug 10, 2007. 4:31 PMthat one guy says:
nice work. a good blend of ingenuity and resourcefulness that gets things done is hard to come by nowadays.
Aug 10, 2007. 4:36 PMthat one guy says:
by the way,sorry to point out an obvious idea, but if you coated the copper in shrink tubing and perhaps connected them to the board with 2 screws which are insulated from one another, it would be safer for some electrical projects and (hopefully) prevent short circuiting. You could also use shrink tubing or electrical tape to make the alligator clips less scratchy, and evenconnect a power source to the bottom of the board to power some projects if you were so inclined, very versatile.
Nov 4, 2008. 5:11 PMCartermarquis says:
I made a pair like this a while back, and just shrunk some pieces of heat-shrink tubing over over each side of teeth of the clips. It helps to keep them from scratching up circuit boards.
Oct 26, 2008. 5:58 PMCoodude26 says:
If you're soldering, you shouldn't worry about short- circuiting because you shouldn't have anything wired up when soldering in the first place.
Nov 4, 2008. 1:21 PMRikasu says:
I just finished mine, doesn't look quite as good as yours does, but it will help. Great 'able.
Oct 27, 2008. 2:35 PMjunits15 says:
cool
Oct 26, 2008. 5:57 PMCoodude26 says:
Wow, this is great! This is one of the first "parts around the house" 'ables I actualy have the parts for around the house! Thanks a lot, very clever!
Nov 4, 2007. 9:25 PMinertia18 says:
Why not, screw each independently and add another 2 hands and screw the two pieces at the the side. but anyway very nice...
Oct 7, 2007. 2:09 PMxproplayer says:
this is so cool im going to substitute the copper wire for solder braided together since i have extra making soon
Aug 16, 2007. 1:25 PMfrazeeg says:
Brilliant! I'll definitely have to build myself one of these.
Aug 9, 2007. 7:46 AMshankarforscience says:
Make sure not to use when connected to power supply, even for D.C Voltages. Resistors & Capacitors may burn due to Short Circuit, because here the Copper wire will happily conducts Electricity !
May 13, 2007. 7:57 PMyoyinsola says:
what exactly does it do?
May 14, 2007. 8:39 PMstudmuffin3dawg2 says:
it is just like a stand to hold projects while you work on them, except it holds it inbetween the clippy "hand" thingys.
Aug 6, 2007. 9:08 AMRibs says:
the hand things are cocodile/aligator clips
May 14, 2007. 8:41 PMstudmuffin3dawg2 says:
by the way if anybody knows that im wrong on what i think it does, then tell us. but i fo know pretty well that that is what it does, i was sort of confused at first as well.
Jun 17, 2006. 2:20 AMleeweek says:
to save a little bit of money and the trouble of going out and buying ring lugs i just made a little loop in the middle of a long piece of (insulated)copper wire and put the loop on the wing nut/bolt i also used a little tripod looking thing like yawfle up there. to keep from damaging / short circuting my soldering pieces i put some extra insulation from the wire on the tips of the aligator clips, worked great and saved time while bienge resorcefull! another mod would be to make multiple arms with loops and alligator clips at each end and put them evrywhere to hold up random stuff like notes or pictures at the office!
Aug 2, 2007. 3:54 PMdannydutton says:
I have so many ring lugs at home, it is ridiculus!
Aug 2, 2007. 3:49 PMdannydutton says:
Great Idea, just one problem. if the wire doesn't have insulation covering either end, couldn't that short circuit something. I would leave insulation on at least one end of one of the wires or use two screws on the block of wood instead of one.
Jul 24, 2007. 4:50 PMandy60 says:
thnx for the idea ill make some tomorrow!
Jul 20, 2007. 3:06 PM!Andrew_Modder! says:
heh wood...
1-40 of 90next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:john otto
Hardworking demonoid engineer, struggling to reconcile my hobbies with a desire to conquer the universe.
