Step 4Cut And Grind Your Metal
1.
Cut your metal. You can use any scrap as long as it is roughly 1-1.5 inches diameter. I used scrap 1" steel conduit for the longer side pieces and some cut up shelf tracking for the bottom pieces.
Cut: 4 pieces at 5 ft.
2 pieces at 18.5 inches'
2.
Take two of the longer pieces and cut a sliver off the top of both of them (See Diagram). The degree of this cut will determine the angle of your pegboard. Use a sawzall or hacksaw to cut it off. Then Use a grinder to perfect your angle
Make sure you don't shorten the overall length of steel though. It should come to a point a 5 feet. Take your time and just remove a little metal at a time until you have the angle that fits nicely. Its better to make a smaller cut and grind it down than then have to cut another 5 footer.
3.
You will also need to grind the bottoms of all four of the longer pieces - so they will sit straight on the bottom piece. See Diagram
Add Comment
