Introduction: Build a Pinhole Magnifier
Picture of Build a Pinhole Magnifier
When I first learned about this device, it was called a "Pinhole Microscope."  I don't think it has enough magnification to be considered a microscope, so I'm just calling it a magnifier.
Materials:
Clear beverage bottle (a half-liter water bottle in this case)
Dark, opaque plastic piece, large enough to cover the top ot the bottle. (top from a peanut can) Cardboard, like from a cracker box, will also work.
Tools:
Knife, scissors, or both (Okay, I'm using tin snips.  They were easier to find!)
CA cement (Superglue, Crazy Glue or the equivalent)
Pin (not shown)
Sandpaper (not shown)
Step 1: Cut the Bottle
Picture of Cut the Bottle
Cut the neck off the bottle just below where it starts to widen.  This should give you a section about 1" (25mm) long.  Sand the cut edge smooth, so nobody cuts themselves on it.
Step 2: Cut the Disk
Picture of Cut the Disk
Cut a circular piece of your opaque material, just large enough to cover the top of the bottle.
Step 3: Glue
Picture of Glue
Glue the material over the top of the bottle.  You may want to roughen the bottle top a bit with the sandpaper first.
Once the glue is dry, poke your pinhole in the center of the opaque material.  Start small, it's a lot easier to make the hole larger than it is to try to make it smaller.
Step 4: Finished
Put the object you wish to view under the magnifier, make sure you've got plenty of light, and look through the pinhole!
rickharris (author)2011-06-10
Add a drop of water on top of the pin hole and you will increase the magnification many many times.
Early magnifiers started as pin holes - this allows your eye to focus at a shorter range. And then moved to using small round glass beads as a lens magnifying many 100's of times.
Good project. - try the water.
gerbilboy (author)rickharris2011-06-11
Good idea if a plastic top is used, not so good if somebody tries cardboard. In fact, I now recall a version that used clear plastic wrap stretched over the too of a bottle, held in place with a rubber band, and a drop of water placed on the center of the wrap.
rickharris (author)gerbilboy2011-06-12
A bit of nail varnish round the hole in the card would solve the water + card problem :-)
About This Instructable
5,137views
2favorites
License:
More by gerbilboy:Bobbin for braiding lanyards and suchManual Focus Webcam ModBuild a Pinhole Magnifier
Add instructable to:
