Generic Disclaimer: I'm in no way responsible for anything anyone decides to build/create/destroy with anything from this instructable. Don't even try to build anything related to this if you don't know exactly what you are doing. If you are unsure about anything in a build process with compressed air involved, seek help of a qualified individual or just don't attempt it at all. Be responsible and use common sense :)
A little background info.... The idea to make this particular gun design was kind of a spur of the moment idea. I had some small pieces of PVC laying around and an extra sprinkler valve so I decided to go at it with what i had(save some money too). Most of the potato guns I make are usually larger diameter barrels (1" - 4") but this time I wanted to go small with it. The diameter of the barrel I decided to use was 1/2" and the air chamber was 2". I wasn't sure how well this would perform but it seemed worth a try. I will try to be as specific as possible in the build process. If you don't like part of the design or have any feedback, please let me know. I do like to hear peoples opinions, good or bad.
Here's a materials list of the items I used in my version. Depending on the size you wish to build, this list can change dramatically.
This is not a complete list, these are just some of the main parts.
Main Materials:
1/2" PVC Pipe
2" PVC Pipe
3" PVC Pipe
2 - 3" PVC Couplers
1 - 3" PVC Cleanout with Plug
1 - 2" PVC Cleanout with Plug
2 - 2" PVC Coupler
1 - 2" to 1"threaded bushing
1 - 1" by 1" threaded pipe
1 - 24 Volt Sprinler valve
1 - 1" threaded to 1/2" slip Coupler
4 - 10" Hose Clamps
2 - 4" Hose Clamps
1 - Cheap Airsoft Gun
1 - SPST Pushbutton Switch
3 - 9 Volt Batteries
4 - 9 Volt Battery Terminals
Miscellaneous Pieces of Wood
You'll also need some pvc cleaner, pvc glue, expanding foam, liquid nails, and miscellaneous building tools.
Also, sorry if some of the pictures are crappy. The best thing I had to take pictures with during the first part of the build was a crappy cell phone.
Remove these ads by
Signing UpStep 1Air Chamber
For the chamber, I used:
1 - 2" PVC Cleanout
2 - 2" Couplers
1 - 2" Slip / 1"Threaded Bushing
There's only one way those parts can be put together so it's a pretty easy step. Make sure to be generous with the cleaner and glue. You want to definitely make sure that you are getting a good air-tight seal on all parts of this project. Always wait the recommended curing time for the glue you are using. I've had caps pop off on parts before and it has the potential to be very dangerous.
The purple on the PVC is the primer in case anyone is wondering.
The next part has to do with the end cap. There can be many different ways and connectors for the end cap but it's all the same basicprinciplee. I decided to use a quick-disconnect fitting on the back of mine. I chose this because this can help with refill times (just keep it connected) and I don't like using tire valves. This is most likely the place where a leak will form in the air chamber. It can be challenging to get a good air tight fit on this. I found a pretty easy way to fix this by heating up the couple part for the inside of the cap to a very hot temperature. It screws on rather loosely (it expanded) but it melts the PVC on the inside and gets a good seal. There are possibly better ways of doing this but this way works for me.
After letting my glue cure it was time to put the cap in place. I didn't use plainTeflonn tape on the threads. I used tape specifically designed to seal gas. This tape is a little thicker and in my opinion has been more durable and reliable than plainTeflonn tape. But I'm sureTeflonn tape will probably work just fine.
At this point, the chamber can be considered done. I would recommend testing it before using it though. You can just put a 1" plug on the other end of the chamber and dunk it in a bucket of water to check for leaks. Be very careful with this also. If the chamber blows up in a bucket of water, it can be a very big explosion. My chamber was good andair tightt. I tested it up to 100psi. So I'm good to move on.
better no explosion than a less damaging one.
Just an idea though, if you threw some metal hose clamp bands around the pressure chamber every few inches or so over the duct tape, and then another layer of taper over that, that might help prevent failure and minimize damage if failure does occur.
A suggestion: did you use Krylon Fusion brand paint? I've heard (from boltsniper and others on nerfhaven) that it bonds well to PVC and doesn't chip. I've seen it at walmart.
