3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Random Music and Light Generator and Glimpse Evidence of GOD
Generating truly random numbers appears to be impossible. It is, however, fairly easy to use a microcontroller to generate pseudo random numbers and then use them to display sounds and different colored lights. While the music that is generated is not exactly Beethoven, it is more interesting than you might expect. I would venture to say it is more pleasant to listen to than much of what they play on the radio these days. A music generator slightly better than this, may someday replace rock stars (I am hoping).
The fact that we cannot generate true random numbers has interesting implications which are considered in step 4.
pic 1 shows the music and light generator. It is 1.3"x2.3"x.8". It plays music over a two octave range through a built in 1" speaker. A surface mount RGB LED displays a range of colors below the speaker. It runs on a 1.5 volt AAA battery.
Step 1Music Generator Components
Pic 2 shows the random music generator top of circuit board.
Pic 3 shows the bottom of circuit board
You can see the liberal use of Liquid Tape to reduce the chance of shorting between the components.
MATERIALS
1.5 volt to 5 volt voltage converter:
http://www.bodhilabs.com/vpack5aaa1.html
08m Picaxe Microcontroller: http://www.hvwtech.com/
1 inch, 32 ohm speaker, LM-386 amplifier, switch, resistors, capacitors, .1" header sockets, RGB LED: http://www.mouser.com
On-off Switch, Plastic Case-1.3"x2.3"x.8" : http://www.jameco.com/
47 comments
1-40 of 47next »
Nov 8, 2011. 8:48 PMbotronics says:
Does anyone have a video of it in action so e can hear hat it sounds like?
Feb 20, 2010. 9:23 AMlegionlabs says:
If there is a higher consciousness which designed the universe, I would like to give it a good stern talking to about proper engineering practices (not to mention documentation).
Humor aside, I built an actual random number generator a while back. It uses a shielded particle detector to sample the impact of helium atoms originating from a radioactive source. The full engineering specifications are available at your request. If you want to try and prove your hypothesis that there is no randomness, I have just over 100 megabits of data you can have if you want.
I'd be happy to give it to you and let you see what you can find. That's science, right?
I'll be honest: I've already run extensive statistical tests on it and it passed every one I can throw at it. It's random so far as I can tell, as predicted by current knowledge of quantum physics.
Also: Praise Eris.
Sep 27, 2011. 9:47 PMfastlines49s says:
Woot for the absolute randomness of quantum physics!
Jul 17, 2011. 2:31 PMmarc_is_curious says:
Am totally new to Picaxe
a Mac (hence MacAXEpad ) User
and
just tried to look at the code
receiving the message "error: loop without Do" message -
this happens with a lot of other PIcaxe script
which i downloaded too,
hence it must be me
who "does smthng wrong" -
may you please provide a hint
on this (for an absolute newbee)?
i look forward to your reply!
Jul 18, 2011. 12:33 PMmarc_is_curious says:
good hint - thanks -
but now the code gets stuck at ....
lookup b8,($20,$2 ....
.... telling me about syntax errors.
am a bit worried that eventhough i work myself through
whole script it's functionality might suffer from my corrections.
however and whatever remains:
such a shame they changed the syntax -
i like your project !
i need to teach myself/learn about the alterations
of the current script - and "translate" it.
thanks for you rreply
& have a great day!
Dec 9, 2009. 6:53 PMAKninja04 says:
Hi, I'm trying to use the LM 386 for a different project. This is surely a noobish question but I wanted to know: do all the grounds in this project run back to the negative end of the battery?
Apr 4, 2011. 3:19 PMski4jesus says:
absolutely. if not, no power would run at all. rule of electrons is they have to have a backwards route, or nothing will work.
Apr 8, 2010. 1:44 PMcodongolev says:
there's so much more evidence for God than nature. I mean, it depends on which God you're talking about, but I've found that the God of christianity has the most evidence for existence.
but really, do you think this was the best place for this? I mean, this is instructables. and this was kind of jammed onto the end of an instructable. I'm not saying you're wrong, I'm saying that you probably could find other, more effective ways of sharing your faith.
Apr 9, 2010. 7:31 PMcodongolev says:
um.... the evidence I'm talking about would be too long to explain in this little box. but I'm currently reading "the case for christ" which explains the historical accuracy of the bible (actually documents an atheist's journey to discredit christianity, and ends with him converting- true story), and I've read "mere christianity" (which has a large chunk of it explaining how morality proves God exists), and I'd like to read "evidence that demands a verdict" and "more evidence that demands a verdict" (obviously both by the same author), which, because I haven't read, I can't really account for the topic. (by the way, all three of these authors were atheists who decided to search for the truth and became christians. I find this to be overwhelmingly convincing for the evidence of Christ and God.)
but yeah. that's what I mean by there's more evidence.
Jul 21, 2010. 1:22 PMnikolardo says:
My current view is that there is something more to the universe than we can discover and test scientifically - all the real things science cannot explain - but I won't put faith in any religion. Religions are the oldest form of organized crime, Christianity being no better. However, every single religion I've ever heard of has the same base: be nice to other beings. Every religion is based on that principle, only the dogmas are different. Interestingly, almost all/all religions have a mystical sect, and they vary very little in their dogmas, even. So while I agree that there is something to spirituality, I strongly doubt the existence of a single conscious entity, "God". Also, at the instructable: things that survive millions of years of evolution have to look designed, and are designed, not by a conscious entity with forethought, but by the continual process of evolution. Also, it has been suggested that the human tendency to view things as "designed" is evolutionarily beneficial, as it comes to the same thing in terms of survival, etc, but is simpler than comprehending evolution. It does make trouble philosophically, though.
Nov 24, 2010. 8:14 PMRobot Lover says:
Christianity is not based on doing good things to others to go to heaven. Although God does want us to love one another and do good things. it is not how to inherit eternal life. The way to get into heaven is to accept that Jesus died on the cross and believe what god says in the Bible. Believing in God is not about religion, it's about worshiping God.
Nov 27, 2010. 9:03 AMnikolardo says:
Maybe - your post was a little confusing, and I didn't follow it entirely - so maybe Christianity is not based on doing good things to others to go to heaven. However, Jesus's main teachings went along the lines of "all you need is love," and are contradictory to much of the Old Testament. Also, I don't believe that any God could support faith without evidence based on a book written by men, who are fallible. The last thing you said, though, about belief in God not having to be tied into religion, I support that. Maybe not in the blind worship plane of things, but certainly in that one can experience God (or a deeper understanding of the universe, or what-have-you) without dogmatic religion.
Nov 27, 2010. 6:22 PMRobot Lover says:
I am glad you think the same about religion as I do. I do not view you as a bad guy because you have different beliefs, just wanted to get that straight so we don't brake out fighting. I am sure you are a great guy. I hope that you do not get angry for me saying this, but that is your opinion and I am sure many others share the same opinion as yours. My belief is my opinion which I have based my life around. i do not believe it as an opinion though, because I thoroughly believe it. I am sure you feel the same way.
Nov 27, 2010. 7:57 PMnikolardo says:
Not really, actually. My notion of the "everything else" in the universe has changed a lot over the years, and I suspect it will continue to do so. It's like my view of anything else - when I gain more information and experience, I have to change what I believe to fit what I know. What I believe is based on what I experience, and because I'm always experiencing more, my beliefs change accordingly. Really, all I have now are a set of suspicions, because I don't believe that I have it right.
Jun 27, 2010. 1:24 PMmacmaniac says:
A rock does not become a plant. Evolution is not random or blind.
May 27, 2009. 12:30 AMand7barton says:
I made a simple random number generator which I believe, did make truly random number sequences - I pointed a lens at the sky, with an Light dependant Resistor mounted underneath it, connected to an A-D converter, resulting in a number between 0 and 255, which was dependant upon the light level affecting the LDR. Clouds, which are random in size and thickness, affected the primary light levels so there was truly a random output. I then wrote some simple software to compress the 0 - 255 range into a small range of 0 - 9.
Feb 20, 2010. 9:00 AMlegionlabs says:
The problem of course is proving that clouds are random size and thickness. I'm sure many meteorologists would claim otherwise.
The best thing to do is test the ouput! NIST produces a decent randomness test suite (if such a thing can exist), though you'll need ~100 megabits of data.
http://csrc.nist.gov/groups/ST/toolkit/rng/index.html
Jul 10, 2008. 10:27 PMalex-sharetskiy says:
Love th last step :' )
Nov 25, 2009. 7:28 PMJohnJY says:
I second that motion!
Jul 31, 2009. 12:16 PMbigdeee says:
Odin is truly a wonderous god. Thanks for providing evidence!
Jul 10, 2008. 6:42 PMAar000n3y says:
(removed by author or community request)
Jul 10, 2008. 7:09 PMAar000n3y says:
Also, if there's a way to randomize the note's length with a limit on how long it can go for, that could make it sound more musical
Jun 9, 2009. 7:11 AMTimmydamonkey says:
ur post got removed. wat did you sat?
was it bad. Oh no it was bad wasn'y it.?!!!
noob.
May 27, 2009. 12:34 AMand7barton says:
That's easy, with a simple set of software rules. You need to write a rule for each possible value your random input delivers. I only know it in BASIC, in which it will be a FOR-NEXT loop. Turn the sound on, loop so many times, then turn the sound off. Don't ask my how to do it for a PC.
Jul 10, 2008. 6:49 PMsr1sws says:
Those that have ears to hear, will. Steve
Jul 10, 2008. 6:57 PMAar000n3y says:
Jul 10, 2008. 9:05 PMpitty says:
It's his Instructable and he did label it appropriately. If you are offended by people talking about there beliefs may be you should not have gone past the title. Great instructable and good on you for talking about your beliefs.
Jul 10, 2008. 8:35 PMLinuxH4x0r says:
If you don't like it don't read it. He can say what he wants. BTW, nice ible. If nothing else, that 1.5 to 5v chip looks promising
Apr 19, 2009. 7:52 PMbudsiskos says:
kind of reminds me of that galatic god from futurama
Feb 14, 2009. 1:53 AMAzurusNova says:
Iv come across this a few times and always liked it. I was curious if there is a way to put in a potentiometer into this design to increase or decrease the speed and volume. If I can get the parts for this and put together one of my own, I'm sure Ill have it up online somewhere. :P Also a light resistor could add some fun to this as well >:)
Feb 10, 2009. 4:33 PMsreekarthi says:
Looks great!! Could you please give the RGB LED specification?
Dec 30, 2008. 5:35 AMIW5 Industries says:
one word: supercalaawsomessifaction!!!!!!!!
Dec 30, 2008. 5:36 AMIW5 Industries says:
if thats not a word then ill just use: awsome.
Sep 16, 2008. 12:01 AMdmitry says:
I don't really get what the crap about creationism is about, but that's an alright statement about creating true randomness. Which is, as far as I know, impossible.
Jul 10, 2008. 9:07 PMsaites2001 says:
You can generate truly random numbers.
Jul 11, 2008. 5:01 AMGoodhart says:
That is more "deriving" random numbers then "creating" them though, isn't it?
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
387
Author:mikey77
I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
