3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Remote Control Deadbolt
This instructable will show you how to build a remote-controlled door lock out of any number of 110V solenoids, solid steel dowel, some various odds and ends and an X10 remote appliance control. I built this for my garage door for less than $30.00, but your results may vary as I was able to score a couple of solenoids free from work.
Step 1Shopping List
Here is what you'll need to build your own remote control deadbolt:
Solenoid
I used two 110V solenoids out of an icemaker, but you may want to build your lock using DC solenoids. Some of them are very strong, and your options for powering the lock in the event of a power outage are greater. Just something to think about. IMPORTANT! -- Make sure you get a continuous duty solenoid, some solenoids are only meant to be energized momentarily, which will cause a problem if you leave them energized and walk away. Read up on the various types of solenoids here.
X10 Controller
I got my X10 controller (Keychain Remote type) on eBay for about $15.00 shipped. This is a simple kit that includes the receiver/appliance module and one remote. Search for "X10 Keychain Kit" or "RC6500" on eBay to find the one I bought.
Hardware
In addition to the above, you'll need 2 return springs per solenoid used, 1/2" steel dowel rod (about $6.00 for 3'), an extension cable long enough to reach your outlet with enough to spare for some additional wiring, and possibly some bits of steel for reinforcement. Depending on what kind of connections your solenoids have, you'll probably want to get some crimp-on connectors. Solder and shrink tubing work better, but are harder to get apart if you should need to.
Optionally, you can buy a couple of magnets to mount inside the recessed mounting hole. This will help the bolt to stay extended, and make a great noise as the bolt closes.
Another improvement on my design would be to use a small hobby box as an enclosure for each solenoid. This would look a lot cleaner and keep the electrical contacts under wraps.
95 comments
1-40 of 95next »
Oct 1, 2011. 3:26 PMjmmgmm says:
It might be possible to use a simple garage door remote. For example, I used the extra button on my garage door remote to power on my interior lights to my house. I was thinking that it just might be possible to activate a solenoid as well. This picture below is the model that I was referring to. I found one with the cover removed that might provide a better idea to what I'm talking about. Notice how the female connectors provide a good attachment to a solenoid. It would be much more secure than X10 and I only needed to order the control since I already had a remote that worked with it. You can buy it at Garage Door Remotes . It can be turned on or off with a key chain remote, regular car remote, or even a biometric fingerprint keypad if you felt like it.
Aug 6, 2011. 2:04 PMtxoutback says:
In my scenario, I have a large gate for my driveway. Currently it has a manual latch that must be used each time I drive in or out. It's mainly there to keep my dog in the yard, and other dogs out of my yard.
There is AC 110 power out there, and I happen to have an old icemaker that is unused. What I'd like to do is make a gate latch "popper" so I can remotely pop the gate latch, and allow a spring and gravity to pull the gate open.
This would save me one stop/trip each time I go through the gate in a vehicle, and the hundreds of dollars I would spend on a Mighty-Mule that would probably only last a few years at the most.
Where to start? Should I take apart the ice maker to find the solenoid?
Jul 18, 2011. 1:48 PMhilldweller says:
Could you please provide information on the solenoid please, such as the manufacturer, model number, and where they are available?
I've tried googling it but most all are valves and pool supply stuff.
Thanks in advance.
Nov 22, 2009. 2:56 PMeemanuel says:
x10 is awesome, but I live in Europe, so I have 220-230V on my socket, which means I can't use it :(
Aug 4, 2010. 5:30 PMchamag1996 says:
Couldn't you use a travel adapter of some sort? I'm sure that could work.
Dec 10, 2010. 7:04 AMdan_ce says:
no, would need a transformer.
Jun 1, 2011. 5:57 PMruaidhriodj says:
you could always look at car lock solenoids, and just use a 12 volt system?
Aug 9, 2010. 2:37 PMCodeKid1001 says:
Quick Question: If I wanted to use this on my bedroom door to keep out pesky siblings, could I use servo motors instead to "push" or "pull" the dowel?
Sep 26, 2010. 2:48 PMspider87 says:
I would like to know this as well for the same application. I'm trying to make a lock for my lab and i am going to put a keypad on the other side. My only dilemma is, how do you reinforce the servo so it can move the bolt but doesn't have to be linked to it (making it a weak point).
My thought right now is something along the lines of this:
(\/) (Servo with gear w/ teeth)
[^^^^^^^^^] (Bolt)
and then the servo just spins the bolt... However, I doubt this is the best way.. Any other thoughts?
Nov 21, 2009. 3:03 AMeemanuel says:
just take it out, they are in parallel so if you take out one solenoid just ignore the wires that were going to it.
here's how the "diagram" will look with only one
Jul 19, 2010. 6:48 PMcoilsinamotor says:
that doesnt work parallel means that it will draw more amps but not volts i prettey sure u would hook the solenoids on series to draw 220V but only a few amp hope that helps ;)
Jan 19, 2010. 10:05 PMCrucio says:
This is a very nice project and very nicely done.
However, be aware that using X10 (especially wireless) for security this way is a bad idea.  X10 signals are simple, well-known, and published.  Someone would need to know only that you are using X10 to be able to quickly gain entry.  A brute force search of all 16 housecodes and the TM751's fixed unit code (1) can be completed in seconds.
Nov 15, 2009. 12:51 PMIanmck12 says:
im not buliding it but im doing a report on it but thanks for your help
Nov 13, 2009. 7:10 AMIanmck12 says:
 im not much of a techy but i hope i do what i can do
Nov 13, 2009. 7:41 AMIanmck12 says:
 how should it look if i only use one solenoid.
Nov 13, 2009. 3:01 AMreaver26 says:
hello.. your guide is very helpful but the only problem is the "solenoid" its really hard to acquire one here in the philippines. but anyway thanks
Nov 11, 2009. 8:53 PMSn0wl3all says:
I'm thinking of doing something like this for my school's Engineering Fair (if you don't mind, I can still cancel the topic)
Can anyone tell me exactly what type of solenoid is used here? Because I can't seem to find anything like it anywhere, including home depot and ebay.
Nov 12, 2009. 7:28 AMIanmck12 says:
 and are you sure its 110v becuz the sticker says 120 v
Nov 12, 2009. 7:23 AMIanmck12 says:
 sizes and mabey the dimentions of the door the wood and springs
Nov 11, 2009. 7:33 AMIanmck12 says:
 can you be a little more specific im doing a report on this
Feb 14, 2009. 12:32 PMcokebottle tuque says:
The key switch is just that, radio shack should have them same goes for the magnetic reed switch, connect the + & - lines to some metallic things that are accessible from both sides of the building and electrically insulated from each other, personally I like the upper hinge has positive and the lower as negative, nice and easy to remember. The idea is that in the event of power or x10 failure you put a magnet over some small mark on the door indicating the location of your reed switch on the other side, turn your keyed switch and then jump start the hinges of your door with some handy 12v power source, car, lawnmower, jump box, spare robot battery, or worst case a 12V wallwart on a extension cord(if you have power). The last thing is that if your not terribly worried about security you could omit the keyed switch and reed switch and just operate on the assumption that applying 12V across the hinges of a door is not a standard method of unlocking doors, or add more normally open switches("broken" light switch, lose 12V light bulb that you need to screw in, light sensor under a brick, 2 metal tool hooks you need to short together, you get the idea) in series to increase security. and in hindsight it would probably be a good idea to throw some sort of current limiting resistor in series with the relay as well just as a safety factor.
Feb 14, 2009. 2:24 PMcokebottle tuque says:
Oh no problem diagrams like that take less time to make in muftisim than multisim takes to start up so really minimal effort, and I have been toying with a similar idea for an apartment/dorm lock and all the fail safes I would need to build in just in case. If you hit a road block let me know I may have some different prospective on it.
May 20, 2009. 3:41 AMadamvan2000 says:
I'm planning to try and build one of these into a standard deadbolt, so that I can still use the key if necessary. Any idea what the security is like on those wireless keyfobs? I'd like to combine that, and a wireless video intercom/door chime, so that when I'm not home and my wife's in bed, she can admit friends or our home-maker from bed. ~adamvan2000
Feb 2, 2009. 10:40 AMjammmie999 says:
Wouldest it be easier to use elector magnet both sides press switch electromagnet activated locked or vice versa
Dec 23, 2008. 9:11 PMstusatwork says:
I keep coming back to this one looking for a reason to do it and I came up with what I think is a great backup.... Setup up 2 keyed backups on the door with pivot bars attached to the lock that will manually slide the pins out when you turn the lock. I would use round locks just to be obscure. Now juice the locks with current from any # of sources. That way if someone goes around randomly probing in the lock while there is power then they get a nice jolt. Just insulate your set of keys and if the power is out it won't matter anyway. If you get a marine type lock they are usually pretty well insulated already so that casual brushes against it shouldn't be an issue. If all else fails dip the face of it in liquid rubber. May even be possible to stick the electrodes in the lock in such a way that only something that isn't the key would set it off... take out a pin on the lock??use that area?
Sep 19, 2008. 4:31 PMCoffee bean says:
do u think this moves enough to shoot a bb
Apr 11, 2008. 7:43 PMkillerjackalope says:
All this worrying about backup power, have an inverter et. all inside the building with a pair of hidden jump leads to use the car battery, or if you use the inverter for stuff in the car just have an extension cord style attachment to inside, problemo solved, no worries of the battery just discharging over time either. Also for a backup switch system a good plan might be two contacts at the bottom of a hole in a brick of the wall, shole a potential burglar attempt to switch after observation their finger gets zapped, assuming they find the hole as a possible switch point. Also why not take a standard garage door and use solenoids to control that and leave the outer handle as a dummy mechanism?
Mar 23, 2008. 12:51 PMMr. Rig It says:
Would love to see you add this to my new group.
Hope to see you there.
Home Repair, Refurbishment, and New Projects
Mar 24, 2008. 9:37 AMMr. Rig It says:
Thank You! I hope to see more stuff from you stuffman. I love the Remote Control Deadbolt, really cool.
Feb 10, 2008. 12:25 AMCitizenX says:
I use the extra button on my garage door remote to power on my house lights. You could use it to activate a solenoid as well. This is a picture of the model that I am talking about with the cover taken off. The connectors to the female outlet slide off giving you a good spot to attach a solenoid (or whatever). It would be much more secure than X10 and I only needed to order the control since I already had a remote that worked with it. You can buy it at TD Supplies. It can be turned on or off with a keychain remote, regular car remote, or even a biometric fingerprint keypad if you felt like it.
1-40 of 95next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:stuffman
