Step 2Assess your situation
For my door, I had to add a vertical support for the bolt to pass through. I used the left-over wood to make the horizontal mounting surface that the solenoids attach to. I reinforced the vertical pass-through with some framing hardware I found at Home Depot. The strike plates (the metal plates mounted to the door frame) are scrap steel I had laying around. Holes were drilled through the strike plates, steel reinforcements, and wood to accommodate the steel dowel.
IMPORTANT! --Make sure that you line up the holes well before drilling, and check your work after every step to make sure everything still lines up.
Add Comment
