Step 4Mount the Solenoids
iImage Information
Now that everything is fitted, you should be able to mount the solenoids to your surface. Test the action and make sure that there isn't too much resistance on the dowel to easily move it. At this point your springs should still be hanging freely. Extend the springs to test the return action on the dowel. If the springs have too much tension on them, they will bend and lose their 'springyness', so make sure they're not working too hard.
An idea that I wanted to try but ended up not using was to mount small magnets inside the holes that the dowel will slide into. The springs would barely have to work at all before the magnets took over. In the end though, I used some dowel from work which was non-ferrous and wouldn't be attracted by the magnet so I scrapped that step.
