Features:
- 10-turn potentiometers for precise resistances
- Low-resistance protection button
- Wire terminals
- Twenty-two capacitors on rotary two rotary switches
- Series or Parallel cap orientation switch
Remove these ads by
Signing UpStep 1Tools & Materials
- 4x Binding posts
- 2x 1 Pole 12 Throw rotary switches
- 1 Pole 6 Throw rotary switch
- 10k Pot (multi-turn is best for increased accuracy)
- 100k Pot (multi-turn optional)
- DPDT slide switch
- 2x 100k 1% resistors
- 3x 200k 1% resistors
- 1M 1% resistor
- 4.5" x 6" x 3" project box
- 5x Knobs
- Solder
- Ribbon cable
- 10p
- 47p
- 100p
- 220p
- 470p
- 680p
- 1n
- 2.2n
- 3.3n
- 4.7n
- 6.8n
- 10n
- 22n
- 47n
- 68n
- 100n
- 220n
- 470n
- 680n
- 1u
- 4.7u
- 10u
- Drill and various bits
- Wrench
- Hot glue gun
- Soldering Iron
- Phillips Screwdriver
- Tin snips
- Printer
- Square needle file
- Center punch
- Tape
- Scissors
I am a lab technician in africa and we are looking in purchasing decade boxes but we can not really afford them; I have looked into time electronics and IET stuff but they are expensive; Could we buy 30 of your boxes ?
Do you have something with inductancces as well?
Thanks
Landry (landrygaetan@yahoo.fr)
Aren't the "tuning" knobs in radios variable capacitance? Could one of those be used somehow in a box like this? Would it be worth the hassle?
Just curious,
Mike from DieCastoms
Each knob in a Decade Box is connected to a "rotary switch". Then each point on the switch is connected to a different value capacitor. Adjusting the switch changes the capacitance value to a defined value dictated by the value of the capacitor connected to a particular point of the switch. i.e it jumps form 1 uF to 10 uF to 100 uF etc.
There for, they are not as you say "tuning" knobs.
These are known as Variable Capacitors. A variable capacitor will, when adjusted, change its capacitance value smoothly. i.e .1 to .11 to .12 to .13 and so on depending on the quality and accuracy of the device.
You could use a variable capacitor from a frequency tuning device if you need very low capacitance values.
It may not be worth the hassle because variable capacitor at mid to high values are massive and expensive. The parts in your typical decade box can be scrounged from most any collection of old electronics, or from you local electronics suppliers clearance bins. :-)
I hope this helps.
Thank you.
Sometimes things you can buy aren't what you want. This is one of those cases.
But I would suggest that your smaller picofarad selections are useless. The capacitance and inductance of the internal (and external) wiring will swamp the actual component values.
These small values are most often used in RF circuits where lead length must be kept as short as possible.
You would probably be better served to substitute larger capacitors on the other end instead of anything smaller than 1nf.
http://www.ampbooks.com/home/amplifier-calculators/wire-capacitance/
Beautiful work, Matt! I used to play with things like this when I was a young kid in my thirties about thirty years ago. I still have one lying up in the attic I think.
Kudos!
Ken
PC i give you 5/5 cause this is our scale but your job exceeds....;)))
The thing about decades is, you need ultra-precise resistances and capacitances. Proper units are done with laser-cut components and even traces on a PCB need to be considered so they don't affect the values. Its very difficult to do. Also it would take about 14 rotary switches to achieve a good range. When does anyone really need individual ohms or nanofarads anyway? I managed to build this thing for $5 since I happened to have all the other components on hand from recycling or garbage stock from work.
10/10 for me. As my box ended up a Wheatstone bride or something.
What program did you use to make the label?
I trace the box contour onto graph paper with a pencil, and draw approximate locations I want my components. Then I scan it on a flatbed and load it into Photoshop. With the layers in Photoshop I can draw over top my lettering and component center dots, using the graphing paper as distance reference. Then I just hide the layer with the graph paper scan and export a PNG. Then I put the PNG into MS Word and size it using the ruler on the side and top of the screen, and print. In this case, I cut it out and had it laminated, then just placed the laminated sheet on the top and held it down with the components itself.
I have only one question...
where do you buy your BINDING POSTS?!?!
