3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Images By Request.... Update June 2008
Update on progress at http://www.spinpower.org March 2011
LAST NOTE FROM JUNE 2008 -
Hi everyone! Thank you for your interest in my project. I have met a commercial manufacturer and we are going to make these for distribution to third world areas as well as bringing them to areas looking to go green. Hopefully we will be able to sell you a kit for less than you can buy all the respective components, that is the plan, although nothing is done yet. Prototyping for mass production is just getting started.
All components that I have shared will be gone over and those that do not conflict with any patents we are able to get will be posted again in the near future. However, I may be re-posting this as a how to build the kit and or make use of the kit. The bottom line is, I will be re-posting some good solid and useful information for you here again soon.
I have a website dedicated to the new endeavor: www.spinpower.org you can watch there for updates.
- Brad
Back to the information about these attached photos -
These are my first batteries, and I will add as the system becomes established. My first inverter dedicated to the wind, not quite powerful enough to take over a complete circuit in the house unless it were all CF bulbs. The preliminary rectifier circuit with diode for charging without a regulator, I know it looks messy, but it is as simple as the diagram in the PDF. And lastly the multimeter showing volts in about 8MPH of wind down the side of my house with the gate at one end closed. The second mov file shows about 8MPH steady wind and the unit making close to 16VDC. Also included is an mov file of the multimeter in a little less wind, maybe 6MPH. You can see the needle dance a little, my alternator has a wobble in it that I am trying to balance. When I hold the top of the unit steady, the voltage stays closer to peak and doesnt bounce as much. I think the solution is its permanent home on my back hill with guy wires.
The local weather service is reporting the wind at 4MPH, but Im sure it is closer to 6MPH or 8MPH when there is a slight gust. If Im wrong, that just makes the unit even more efficient than I think. : )
158 comments
1-40 of 158next »
Jun 12, 2008. 10:47 AMadmin says:
This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do. 1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable. 2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made! Thanks for your submission and let me know if you have any questions along the way.
Aug 15, 2008. 11:29 AMadmin says:
Oct 14, 2008. 7:11 AMmacpeku says:
Hi ! Thanks Peku
Jun 8, 2008. 10:41 PMseanc says:
HELP ANYONE, I need someone really sharp. I'll pay to have my problem resolved. $600+ light bill is B.S. Looking to solve with wind & solar, inexpensively. No time to do the work myself, even though 30+ yrs in electronics. scarey@austin.rr.com
May 20, 2008. 8:12 AMsnowman46919 says:
I see one problem with this you say you have 16 volts DC although your meter is set to ACV. Now this may not mean anything with your meter but mine is from the stone ages and very picky about this sort of thing. Just wondering whats going on in that picture.
May 20, 2008. 12:43 PMsnowman46919 says:
Cheers to you then that makes perfect sense now. One of these days maybe fluke meters will rain from the skies and all our woes will be cast by the way side.
May 20, 2008. 9:49 AMcrippledeath says:
i love your idea very cheap why to generate wind energy check out my site thank you here is a link to it DIY Solar
Apr 19, 2008. 12:28 AMcrimity46 says:
I was wondering if AWG 26 wiring would work for this project?
Mar 13, 2008. 6:14 PMcsb says:
Alright, this is a great project, thank you!
I'm seriously trying to wrap my head around the math of this... 6+6 = 24??? That 1" circle in the center looks like it can only fit 12 times... How is that disc 24" diameter?
Apr 6, 2008. 1:43 PMfieldman says:
Write the equations down. Pi cancels. I haven't been to the site yet but I know what he is talking about.
Mar 17, 2008. 2:59 PMcsb says:
Thanks for the reply ... but wow, I'm really struggling to wrap my head around this. Half of a 6" diameter circle is still half of a 6" diameter circle... two halves placed side-by-side would cover 12" as you've described, but how does it magically cover the 24" diameter of the pine disc?
Mar 17, 2008. 5:51 PMcsb says:
Ahhhhh Got it. Thank you! Apparently the fault was in my lack of familiarity with stovepipes. I thought you had split a single pipe in half.
Mar 23, 2008. 8:55 PMHunterBishop says:
Sarcasticassclown
Nov 8, 2007. 8:11 PMsamcrut says:
About the coil... You say in the other Instructable that putting a metal object in the middle of the coil is more efficient in some ways but not here. Were you just saying "This is the simplest way (most efficient) to do this little demonstration." or was there another actual power efficiency reason?
I can't help thinking that a bolt with the wire coiled tight and neat would be more clean looking and possibly more effective for the VAWT. Since the bolt would be purposefully channeling the flux, you could bolt it with an L bracket on the far end and not have to deal with the plexiglass. I've been searching around to find an answer to: Is a flat, hollow solenoid more efficient than a long solenoid with a metal core of equal wire length?
I can see where the magnets might attract to the bolts in the solenoids causing additional drag and requiring more wind to generate the additional torque but if it really focuses the flux, you could expand the air gap a little and maybe still get better power. Additionally, since the bolt solenoids would be about 1/3 the width of the ones you're using now, you could put in more of them.
I have lots of neodymium magnets around here, but they're all small. I'd have to scale it down to a spinning 2 liter bottle. =)
Mar 21, 2008. 5:29 PMconntaxman says:
bhunter,What size wire and how many turns did you end up useing to have a cut in speed of 30 RPM, to charge your 12 VDC battary. Im just now startign to build my alt. TKS Johnny
Mar 4, 2008. 12:12 PMjohn j says:
http://www.energy.ca.gov/2005publications/CEC-500-2005-084/CEC-500-2005-084.PDF
Have a problem with this report. They say that zero overlap is the most efficient, but the image they show seems to be the 48% overlap. Is it me that is wrong?
If its me wrong, then how would 48% overlap look? Cheers, John
Mar 3, 2008. 2:04 PMjohn j says:
Hi, fellow builders, just came across a set of profiles and test results for savonius: http://www.energy.ca.gov/2005publications/CEC-500-2005-084/CEC-500-2005-084.PDF
Hope Im not getting problems for showing this? Legally I mean.
Anyways, happy building, John from Denmark.
Feb 3, 2008. 4:43 PMFrank_the_Bunny says:
Ok, I am very new at this so I will not pretend to know anything...but what are your thoughts on wind funnels to assist in the use of wind turbines?
Oct 11, 2007. 4:55 PMwinspnr says:
Please refer to the book "Mechanical Engineering" Volume 53, May 1931, No.5 pg 333. This may help in designing a more efficient Savonius Rotor. (Note: I will try to send a picture of the one I built.)
Feb 2, 2008. 5:52 PMwinspnr says:
This is the photo I attempted to send some months ago.
Jan 29, 2008. 3:03 PMconntaxman says:
Magnets and their spaces Useing 12 magnets and 9 coils,It seems that a 12 dia. peice of steel would be large enought.What would the largest Dia. steel disc that would work for magnets . 1 inch wide 2 inches long 1/2 inch thick. their the neo 50. they have 80 lbs pull. Thank you. Johnny
Jan 29, 2008. 5:11 PMconntaxman says:
Just thought of another way to place the magnets and it would increase the size of the rotor plate.Put the magnets length ways around the outer edge,that would be 2 inches for each one and the rotor plate should increase to 24 inches in Dia. Would the coils work the same? Has anyone done it this way for a Vawt? I seen on the web were the guy only used one Rotor and one stator plate. Isn't it as long as the magnets go over the feilds just on top>? That way I could use 24 magnets length ways and with only 1 RPM it would make ele. Any ideas . Tks Johnny
Mar 2, 2008. 6:20 PMconntaxman says:
Almost done with the 3 sails.Next is to finish the main shaft,and also do alittle more on the Frame. Still have to make the alt. 2 rotors with 12 magnets each and stator with 9 coils.
1-40 of 158next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:bhunter736(SpinPower)
Im an ex computer guy who turned locksmith then Resource Conservation Coordinator for a school district and I still love to tinker with everything. During the last 3 and a half years, I sold the scho...
more »
