3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Suitcase Drum Set
Step 6Attaching Bass Drum Pedal
  • last photo ←
The metal plate is the critical component in suitcase construction. I have tried and seen others try many approaches that fail or make the suitcase very clumsy.
When drummers see the suitcase drum set they always ask, “Why doesn't it t fall over when you hit it?” The metal plate takes care of that problem. Any ¼” thick metal will work, but aluminum is best.
Pedals are designed to clamp on a bass drum hoop, which is about ¼” thick.  It needs to be ¼” thick or the bass drum pedal will not attach well. The piece I used was recycled from another project and has a trapezoid shape. The shape is not critical. I recommend a 3 ½ ”x4” rectangle -- if you're buying this piece from a metal shop, they can cut it for you. The size can change slightly depending on the pedal and suitcase used -- use your judgment.
Countersinking the screws is necessary so the bolt heads don’t touch the ground and throw the suitcase off-balance. Drill three holes in a triangle pattern. The triangle pattern is to create enough stability.
To attach the plate, you must first find the perfect spot to mount it.
Clamp the plate in the pedal and slide the plate under the suitcase (either side of the suitcase is fine, I  hit both sides  of the case to hear which side has a lower pitched sound, and pick that one).
When pedal is depressed and beater is touching drum, the beater shaft should be parallel to the suitcase. Mark the spot where the plate is and drill holes in suitcase using the plate as a template.
Bolt the plate to the suitcase using lock nuts and flat washers.
After its bolted on, cut a piece of rubber just big enough to cover one side of the exposed plate and glue it on. Gorilla glue works great. The rubber keeps the pedal from slipping off the smooth metal. Don’t skip this step.
Now you can set up the bare-bones kit and jam out.
3 comments
Feb 11, 2011. 12:27 PMgolfchick005 says:
We went to guitar center and the guy working at the drums gave us a piece of rubber actually used for a bass drum. We had to cut it down a bit, but it works. The suitcase drum set is up and running as of last night!
Feb 8, 2011. 7:26 PMgolfchick005 says:
what kind of rubber did you use? I've been looking at stores like Home Depot and haven't really found anything suitable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:mikereetz
Drummer who builds hot rods and teaches music for a living.
