3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Tetris DVD (or book) shelf
Step 12The Dreaded S
The Dreaded S
Now we are on to the last piece which is the most difficult one to assemble, but really it's not a lot more difficult than the last piece if you do it the way we have been in the tutorial. but if you do each piece individually like I did, then it becomes a bit of a pain. A lot of a pain, if you want me to be completely honest with you. Since this is the last piece, we should be using each of the remaining pieces we have left. But in case you don't have all of those pieces, you will need to fix that.
Assemble this one any way you like. I did it the wrong way though, I will tell you that much. Assembling the interior pieces and then the 20" pieces followed by the 10" outside pieces seems to be the way to go. You may be able to tell from this photo, but one of my pieces was about 1/4" too long, and as a result, the top part of the S is tilted. The reason this happened is because I miscounted when I originally cut the pieces, and I was missing one 10" piece. So I lined it up to the old line as best I could and cut, but it was still just ever so slightly off.
This will stress the importance of cutting all the pieces at the same time. Normally on woodworking projects you cut pieces as you go, but it is so important that these pieces be exactly the same that you pretty much have to cut everything at once.
In any case, they all more or less fit (the S fits perfectly if you flip it around and use the other side) and we are now officially done with the building phase.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:odecom5
