loading
Step 5: Forming the Cones- Slip Roller
There are two ways to form the metal for cones or cylinders.  The best way for the cylinder is to use a Slip Roller like the one in Picture 1.  It gradually rolls the metal tighter and tighter until you have a nice cylinder, then the top roller lifts and you slip the metal off the end of the roller (Pictures 2-7).
Finished cylinder, ready to weld! (See Picture 8)
This works really good for straight cylinders, but its a little harder to do with a cone that will have different diameters on each end.  I've been told a trick to this is to pinch the short end of the cone with pliers to hold it back allowing the longer side to get sucked through faster (see Picture 9).  This didn't really work for me because my rollers were to big for the cones I was making anyways.  I think with some practice, though, it would work really good.
The other option is to "micro-brake"- see the next step!
<p>very cool topic thanks a lot for the info, I am working on the exhaust right now and purchased the software, wondering if it did what it supposed to? </p>
<p>Great article a really interesting read.l have 3 old Russian motorcycles all 350cc 2stroke singles,but with twin exhausts!.Do you know if the wizard click and build program would cover this scenario?I really fancy having a go at building my own pipes,not looking for silly rpm just a bit more torque. At this moment in time I am living in Bulgaria and do the bike rallies,a bit more grunt through the Balkan mountains would be handy</p>
<p>Sorry, we've upgraded our computer and haven't tried reinstalling the software so I can't check for you. Have you tried contacting the software company? They would be the ones who could tell you for sure if it can do that or not! Would love to see some pics of the bikes and pipes when you get them done!</p>
Thanks for your prompt response,sent an email waiting with baited breath for a reply.My bikes are in bits at the minute,l will send you some photos when rebuilt
<p>Can anyone help, I am keen to get started with my project, thanks ?</p>
<p>Dont bother buying 2 Stroke Wizard. NO CUSTOMER BACKUP. I HAD IT AND IT STOPPED WORKING. Sent them many emails and got automated reply's but nothing from them. Dont waste your money. Plenty of free programs out there that work just as well if not better. Theires is all smoke screens. </p>
<p>helo bro can you pls send me the 2 stroke wizard </p>
<p>Looks like it's still available here: </p><p><a href="http://www.buildandclick.com/" rel="nofollow">http://www.buildandclick.com/</a></p>
where can i purchase <br> 2 Stroke Wizard by Build and Click.
great work on the sheet roleing and math but you realy should have tig welded it and used a gas perge line inside the pipe with something to plug the ends then have a small hole to let the used argon excape .not bagging you by any means we don't all have acces to a tig I am sure it still worked awsome
good writeup. i enjoyed all the practical tips. thanks
If it helps the engine visually looks like a YB100 which is rated as a 97cc I did have a go at cross referencing some of the engine parts but could only get some numbers for your bike and none for mine a main dealer might have better resources.
Hi I'm a member of www.yammy100.com a UK forum and I can see your bike is a 100cc yamaha but not sure of the model there are a few of us that would like to make a tuned pipe, can you update the build on how well it works? <br> <br>Cheers Rich.
The bike is a '67 Yamaha YL2C, also known as the Trailmaster. I have not run it much since I finished the pipe- still working on the rearsets and am trying to locate a part for the oil pump. I will definitely post back with test results when I've had a chance to ride it!
When you let the pipe gas exit from the belly and not from the end cone then the noise is automatically greatly reduced. No power loss either. Actually you gain some low rpm power. Then you won't be banging your head with frustration at not being able to find a truly quiet silencer that doesn't restrict the flow (and reduce the power).
Nice writeup but it is based on outdated info. For the latest free info on how expansion chambers work and how to design them please go to dragonfly75.com/motorbike/ECtheory.html <br>The info there exposes the flaws in the former ways of thinking about pipes and how to design them. If you are serious about pipes and want the best results at zero cost then check it out!
Very impressive! <br> <br>You have managed to break down a fairly complex operation, combine it with the relevant theory and still make it readable. <br> <br>
Very interesting! <br><br>I am a stick welder apprentice, and to weld thin sheet I use a method that I invented: use an additional black iron wire, as in autogenous (Oxy-Acetlyne) welding. It is not easy, but allows some welding tasks otherwise are very difficult. <br><br>A question: the &quot;tuned&quot; exhaust seems like a resonant circuit. Does it enhance the motor only in a certain speed or range of speeds? Forgive me if you said that, I don't speak English and it is difficult for me to read and undestand all the text.
Yes and no... Two strokes have what is referred to as a &quot;power band&quot;- the rpm range where the pipe is MOST effective- just like what you are saying. You can change the rpm range by changing the shape of the cones and length of the &quot;belly&quot; of the pipe- creating a &quot;tuned&quot; pipe. <br><br>My pipe was designed to be a little less effective but cover a larger rpm range. Some pipes can cause the engine to be very sluggish unless its in a very narrow rpm range (my first pipe, for example). That type of pipe has a VERY notice-able powerband- when it hits the right rpm range, the engine really takes off.
Thanks for both responses. What about the noise? <br><br><br>
Believe it or not, this pipe was more quite than the stock pipe the bike came with... It is possible to build your own silencer too. When I get the rest of the bike done to the point it's ride-able, I will do some more testing- a silencer may be in the works.
Years ago I bought a simple silencer, tube type. I worked very well at 100 Km/h or over, but under 90 Km/h it was very loud. The grief was that almost always the car was driven at less than 90 km/h...!
Oh, and I like your welding tip. I was basically doing the same thing, but using a MIG welder. The extra rod helps cool the puddle down so the base metal doesn't get too hot, melt, and fall out. Never tried it with a stick welder though. <br><br>I believe TIG welders *dip* the rod in the puddle when welding aluminum for the same purpose- to cool the base metal.
Nice job good infomation!
Sorry If i somehow skimmed past it when reading your instructable, was just curious as to what make of bike yours was? It has a great cafe look.
I never did mention that... sorry!<br><br>It's a 1967 Yamaha YL100C- also known as a Trailmaster. Yamaha also built a &quot;street&quot; version called the Twinjet, which was a 100cc 2 cylinder two stroke. Mine was meant to be a dual sport, but I'm in the process of converting it to a cafe bike.
Interesting bike--I've got a '70 L5T-A 100cc Trailmaster, enduro (what they used to call dual sports). The bike in your picture looks very similar to mine.<br><br>Nice article, BTW :-)
i did few pipes for my tomos targa, some with oxy-acetilene, some with mag, and the last one that wasnt tested yet with TIG and i'd say TIG is def. the way to go:) few more things i discovered, silencers dont affect power too drastically, so if you want your bike to be silent do a bigger silencer without doubts:) buuuut, bent stinger pipe is bad for preformance, so dont do &quot;scooter&quot; style exhaust with bent stinger and silencer facing to the front of the bike....<br>http://www.youtube.com/watch?v=S_bpV11N0zg<br>here's a vid of my pipe its on a 50cc 2 speed automatic bike:)<br><br>http://shrani.si/f/2L/4E/4mCdnXas/3.jpg<br>and heres the last pipe i made, that still needs to be tested
20 gauge is a LOT easier to work with and oxy-acetylene is definitely the way to go. Also remember to clean EVERY weld on the inside as you assemble it. Especially with your 18 gauge, it would be easier to take all the pieces with DXF file to a metal shop and have it cut for you. Make sure to coat the metal with anti-rust and then clean the edges before welding.
Very interesting, I have been building pipes for 2 strokes for nearly 35 years .and this was well written, one thing you should stress is that when making the &quot;sliver&quot; to shape the pipe the thin edge ends on the MAX diameter of the tube/cone. That is the only way to keep the pipe to its designed tuned length.<br>One book for the average rider you left out of your list is the late great Performance Bikes Tech author John Robinson's &quot;2 stroke tuning&quot; the other book for the &quot;scientists&quot; is Prof. Blair's research paper <br><br>Keep up the good work.
Your probably that guy that goes by my house at 3 AM sounding like a horny weed eater on steroids..
Nice instructable! When I was researching venturis and critical flow for work I came across this concept, but it's cool that you brought it down to earth.
read Gordon Purves Blair of Queen's University in Belfast he published the formula's for building tuned pipes with rev range and and port timings.<br>so you can get the most ride-ability out of the bike<br>
C'mon, lets hear it going like snot(on the pipe for the layman)! Video with sound, please!
I know, eh?! My goal is to have it done by June. I will for sure have pics and vid of it running by then! I still need to rebuild the oil pump before I can run the engine, and I still have to finish the rearsets, rear brake assembly, and put the new front tire and tube on. Getting closer...
Another way to make metal tubes:<br><br>http://www.youtube.com/watch?feature=player_embedded&amp;v=DGszBVy3cgU
Great instructable but I was thinking, I have been working on my yamaha banshee and I added new exhaust (wish I saw this first but it oh well lol) any way if you increace the airflow of the exhaust don't you have to rejet the carb I know my banshee ran extremely lean after the new pipes.
Yes, that is very true. I will make a note of it in the testing section, thanks!
No prolblem I love two strokes too they are so simple but so powerful, most of my toys are two strokes and I am going to have to try this out on something, and thank you for a great instructable
great instuctable, funny name dork punch! I also love playing around with 2 strokes the simplicity is genius. playing with expansion chambers can be addictive, Ive built a few, it great to go on that first ride with your new pipe. <br>The other thing that is cool to play with on a piston port 2 stroke is putting a spacer under the barrel it changes the port timing, and can make a sedate putt putt scooter into an animal. Try making a base gasket out of 2 or 3mm aluminium, you will be surprised. it works even better if you take 2 or 3 mm off the top of the barrel, to keep the compression ratio the same.
About This Instructable
287,780views
130favorites
License:
More by dorkpunch:Customize or Refurbish Hot Wheels! The Utlimate Mini Mobile Metalshop Penny Engine- micro air powered engine!
Add instructable to:
