3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Variable High Voltage Power Supply
Step 2Gather the parts
Gather the parts
All the parts with the exception of the variac used for voltage control came from my junk collection or Ebay. Here's the list:
CHASSIS - Texas Instruments TI99 Computer case. Any metal box will do as long as there is enough room for the parts. An electrical box will do just fine. The computer case had a switch, an AC plug adaptor, and a removable lid so it was perfect.
F1 - 5 Amp fuse with holder (Radio Shack).
HVM - HV Multiplier - This is a build it yourself part made up of (6) 12KV High Voltage Diodes and (6) 470 picofarad 20KV High Voltage ceramic doorknob capacitors. You can buy all the parts on Ebay. I have already posted an instructable on this. Just search for High Voltage Multiplier.
I1 - READY Indicator - GREEN 120 volt Neon lamp (Radio Shack). An old 120 volt Neon indicator from a microwave oven is what I used here.
I2 - HV ON Indicator - RED 120 volt Neon lamp (Radio Shack).
K1 - Contactor - 120VAC 10 Amp DPST Relay with a 120VAC coil.
OBT - Oil Burner Transformer salvaged from an old oil burner from a mobile home rated at 120VAC @ 2.25 Amps on the input and 6Kv 20Ma on the output. The single pole type was used here. This can be purchased from a burner service company for about $65.00
S1 - SPST N.O. Cherry Microswitch for case safety.
S2 - DPST Toggle or rocker switch for power on.
S3 - SPST N.O. 120VAC Pushbutton switch.
VT1 - A variac was purchased for $60 from an electrical supply house. Any dimmer that can handle inductive loads up to 5 amps will work. The variac can control 2.5 amps. Just enough for the OBT.
MISC - You will need some wire lugs and various colors of wire scavenged from power cords for the internal wiring.
13 comments
Mar 10, 2012. 3:46 AMMachine says:
I like the quality internal layout, it looks professionally done. A meter on the front panel could be good.
It'd be hard to measure directly the output volts as a high-voltage divider would be needed (more cost, insulation difficulties).
So a meter calibrated in kV but measuring the output volts at VT1 would be an easier method to indicate final voltage.
Nov 15, 2011. 8:10 PMwespow1 says:
i cant seem to get the image up so i'll give you a URL to the burner http://www.ebay.com/itm/OIL-BURNER-TRANSFORMER-110-HIGH-VOLTAGE-10-000-WEIL-MCLAIN-GOLD-BURNER-BASE-NEW-/120811839341?pt=LH_DefaultDomain_0&hash=item1c20f25f6d#ht_1543wt_1163
Nov 15, 2011. 8:05 PMwespow1 says:
Hello i was wondering if a OIL BURNER TRANSFORMER 110 HIGH VOLTAGE 10,000 WEIL MCLAIN GOLD BURNER BASE NEW would work here is a images of the burner
May 12, 2011. 5:42 PMaweis says:
if i only want a killavolt (1000 volts) from a 70 volt alternating current generator, would i be able to do that for around 50 dollars?
Jan 10, 2011. 9:54 AMMoo_cow says:
If I were to take out the multiplier, would if work for 0-6000 volts?
Wanting to use this for part of my science fair but I do not need to go over 6000 volts.
Dec 20, 2010. 5:55 PMewpwrqlty says:
I only need a 100-700 VAC variable supply. Can I modify your design to achieve this goal?
Dec 21, 2010. 8:01 AMewpwrqlty says:
Thanks for your quick response.
The device does not need to provide any current. I only need to provide variable voltage potentials between 100-700 VAC. I am attempting to create a voltage calibration set for my BMI 8800 power disturbance analyzers.
The required voltage (Vrms) calibration levels are:
1. 0
2. 7.6-8.4
3. 30.2-33.4
4. 75.5-83.5
5. 150-170
6. 200-225
7. 300-335
8. 604-670
I am using a 0-140VAC Variac to produce the first four levels.
I tried using a hipot tester to produce the last four levels and was successful up to level 8. The hipot unit that I own is a Hiptronics HD5 0-5KV at 5 mA.
The impedance of the BMI voltage input channels during calibration is 1.01 Megga Ohm. At approximately 500 VAC the leakage current light was glowing and the unit was vibrating and ready to fail on leakage. My Hipot tester would need to have at least a 20 mA output capability in order to complete the calibration series
Jun 21, 2010. 9:13 PMCharlesBarret says:
Hi, i think that your source cannot supply that much current (20milis) because that depends on your load resistance.. mmm how do you know you can hold that much current in your design? thx..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:burningsuntech
A long life and lots of opportunities to engineer some neat stuff is what Im made of. There isnt much I dont like to build or tinker with and my projects run the gambit from computer toys to high vol...
more »
