3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Variable High Voltage Power Supply
Step 4Wire the low voltage side
  • C:\Documents and Settings\Owner\My Documents\My Pictures\PowerSupply\Schematic1.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\PowerSupply\Schematic2.JPG
Decide if you are going to include a power contactor and case safety switch. If so, use the first schematic. If not, then use the second schematic.
Wire the supply starting with the AC connector, fuse holder, switches, variac and power contactor.
Test each stage of your build to make sure your wiring is correct.
Next wire up the OBT and test the range of the variac.
To test the output of the OBT, hold a GROUNDED screwdriver near the OBT output terminal.
If you see an arc, good. Power off the supply and disconnect it from Mains and move to the next step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:burningsuntech
A long life and lots of opportunities to engineer some neat stuff is what Im made of. There isnt much I dont like to build or tinker with and my projects run the gambit from computer toys to high vol...
more »
