3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Variable High Voltage Power Supply
Step 6Power UP and Test it
  • C:\Documents and Settings\Owner\My Documents\My Pictures\PowerSupply\HVPS0008.jpg
  • C:\Documents and Settings\Owner\My Documents\My Pictures\PowerSupply\HVPS0007.jpg
*** WARNING ***
THESE NEXT STEPS ARE DANGEROUS.
Connect the power to the supply and turn on the main power switch. The "Ready" Indicator should light.
Set the voltage to 50 percent and press the HV ON pushbutton.
The HV ON Indicator will light and you will hear a slight hissing sound. This is okay. If you hear any snaps or arcing, determine where the problem is, shut off the supply, and dope the area. When it dries, test again.
With a grounded screw driver, bring the tip of the screw driver in close proximity to the output stud and watch for sparks.
*** WARNING ***
DO NOT TOUCH THE OUTPUT STUD WITH THE SCREWDRIVER. PERMANENT DAMAGE WILL RESULT.
If you are confident in your building skills, or hungry for sparks, SLOWLY ramp up the voltage to 100 percent and test again with the screwdriver.
Success will be indicated by the 2 inch long spark that you get from the supply.
*** WARNING ***
DO NOT ATTEMPT TO MEASURE THE OUTPUT OF THIS DEVICE WITHOUT SPECIAL TEST EQUIPMENT OR THE PROPER SAFETY EQUIPMENT.
*** DANGER DANGER DANGER DANGER DANGER DANGER ***
THE CURRENT PRODUCED BY THIS SUPPLY ALONG WITH THE HIGH VOLTAGE MAKES THIS DEVICE DANGEROUSLY LETHAL! DO NOT TOUCH THE HIGH VOLTAGE STUD DURING OPERATION. THIS THING WILL KILL YOU! GROUND THE STUD AFTER EACH SHUTDOWN TO DRAIN ANY REMAINING POTENTIAL.
3 comments
Jun 16, 2009. 12:34 AMvotedthewave says:
Is this -50kv or +50kv?
Aug 18, 2009. 6:00 AMElectronics111 says:
+50kv i think
May 18, 2011. 9:08 AMjmaniglia says:
If you connect the leads reverse it will be -50 as well
Oct 14, 2011. 9:04 PMjanderja says:
Yes it will be -50 wrt the other lead but not -50 wrt earth ground.
How can you make it -50 wrt earth ground? This will allow it to be used as a negative ion generator.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:burningsuntech
A long life and lots of opportunities to engineer some neat stuff is what Im made of. There isnt much I dont like to build or tinker with and my projects run the gambit from computer toys to high vol...
more »
