Step 7Safety Rules, and Disclaimer
ALWAYS wear rubber safety gloves and stand on a rubber safety mat when operating this supply.
ALWAYS wear protective goggles when power is on. Especially if you plan to power a laser with this unit.
NEVER touch anything or device that is connected to the supply while it is in operation without adequate protection.
NEVER defeat the safety switch on the case or operate this supply with the lid removed.
DISCONNECT the supply from power before opening or working on it.
FOCUS your attention on what you are doing with this device. Eliminate any distractions or annoyances in the area where you use this device.
DO NOT ALLOW others to operate or work in the same area of this device without adequate supervision or safety training.
REMEMBER, Smokey says, only YOU can prevent People Fires!
*** DISCLAIMER ***
You, the builder and user, bear the responsibility for your own safety in building, testing, and using this supply. By building this device, you acknowledge the risks involved in it's operation and accept those risks as a result. I will in no way be held responsible for your actions, including your death by this instrument and you accept these terms by building and using this device.
Add Comment
