Step 2Build a 1/20 Cubic Inch Robot.
I used .005" thick phosphor bronze sheet metal for the box structures because it can be soldered and dousnt oxidise or tarnish easily. Copper or brass could also be used. I originally used small drill bits to drill the bearing holes in the sheet metal for the rotating wire shafts. After breaking a few of them in a drill press, I ended up just punching holes with a large needle and hammer into the sheet metal. This creates a cone shape hole which can then be filed flat. The holes do not have to be a precise size or even perfectly placed. At this small a scale, the frictional forces are minute and if you look closely at the pictures you will see I used long .1" standard long header pins which are square, for the shafts and gripper fingers. Copper wire could also be used.
The glass bead wheels were mounted on brass pins epoxied to the bottom of the robot. It is important to use non magnetic materials for the construction or the power and control of the robot will be adversely affected.
Add Comment
