3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Very Small Robot: Make The World's Smallest Wheeled Robot With A Gripper.
Step 6Robot Controller Software
Here is the software program for the Picaxe microcontroller. It sends pre-programmed sequences to the Polulu servo controller which moves the magnet in 3d space to control the robot. With slight modifications, it could also be used to program a Basic Stamp two.
To program the Picaxe I found it necessary to disconnect Pin 3 (serial output) from the servo controller. Otherwise the program would not download from the PC. I also found it necessary to disconnect pin three from the servo controller when turning the circuits on, to prevent the servo controller from locking up. Then, after a second or so I reconnected pin 3.
'Program for R-20 magrobot pickup sequence using a polulu servo controller
high 3 'serial output pin
pause 7000
'set to 0 position
serout 3,t2400,($80,$01,$04,1,35,127) 'position s1 13-24-35 counter-clockwise
serout 3,t2400,($80,$01,$04,0,35,127) 'position s0 c-clock
pause 7000
'level magnet
serout 3,t2400,($80,$01,$04,3,23,127) 'position mid
pause 1000
'move forward long servo1
serout 3,t2400,($80,$01,$04,1,21,127) 'position clockwise
pause 1500
'grip down
serout 3,t2400,($80,$01,$04,3,26,127) 'position down
pause 2000
'close grip
serout 3,t2400,($80,$01,$04,2,25,1) 'slow speed clock
pause 50
serout 3,t2400,($80,$01,$00,2,0,127) 'stop servo 2 rotate
pause 700
'move forward short
serout 3,t2400,($80,$01,$04,1,13,127) 'position clock
pause 1000
'grip up
serout 3,t2400,($80,$01,$04,3,23,127) 'position midpoint
pause 700
'turn right 90
pause 470
serout 3,t2400,($80,$01,$00,2,0,127) 'stop servo 2 rotation
pause 1000
'forward
serout 3,t2400,($80,$01,$04,0,13,12) 'position s0
pause 1500
'grip down
serout 3,t2400,($80,$01,$04,3,25,12) 'position mid
pause 2000
'close grip
serout 3,t2400,($80,$01,$04,2,25,1) 'slow speed c-clockwise
pause 50
pause 400
'backup
pause 700
'grip up
serout 3,t2400,($80,$01,$04,3,22,12) 'position mid
pause 1000
pause 6000
'set to 0 position
serout 3,t2400,($80,$01,$04,1,35,127) 'position s1 13-24-35 c-clock
loop:
goto loop
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
387
Author:mikey77
I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
