3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Whisky Still
If you're reading this, I assume you are interested in the theoretical transformation of a relatively weak alcoholic mixture into a relatively strong alcoholic mixture. That is, the distillation of whisky.
If you don't know about the early stages of whisky distillation, here is a quick round-up:
Take some grain, and allow it to sprout. Just as it starts to sprout, quickly kill it by drying. It is now a "malted grain". Mix the malted grain with hot water and stir until you get bored - you are dissolving the sugars from the grain into the water. Filter out the solids, and add yeast. Keep the mixture slightly warm (and sealed from the air) until the yeast has turned the sugar into alcohol. You now have a wash that is ready to be distilled. Apparently, the wash has a strength and taste similar to beer, so maybe you would like to start there.
Distillation is the process of separating a mixture of liquids with different boiling points. In this case, we're trying to separate ethanol (alcohol) from water. Pure ethanol boils at 78.4oC, and pure water boils at 100oC, so heating the wash will make the ethanol boil off first.
Step 1What you need
What you need
A still has three separate parts - something to heat the liquid, something to help water vapours condense before they escape the apparatus and something to cool and trap the alcoholic vapours.
I will refer to these parts as the vat, column and condenser. You also need a thermometer with a scale that goes to at least +100oC.
Legal point: It is illegal to manufacture spirits in the UK without a distiller's licence which is required under the provisions of section 12 of the Alcoholic Liquor Duties Act 1979 and this includes manufacture for "own/domestic use". For this reason, my images are a mixture of diagrams and stock photos. This goes against the usual practice here, but I kind of want to keep my job, and if I did it for real, images posted here can (in a UK court of law) be used as evidence against me. Before constructing your still, you must check local licensing laws to ensure you are not committing an offence, or obtain a distiller's license.
Since this is more a guide to function than form, you may choose to use different materials to those suggested, such as paying out for all-copper fittings. This is by no means an exhaustive tutorial, so if you are planning to produce quality drinking-spirits on a regular basis (as opposed to something merely flammable), you may even want to invest in a purpose-built still. Just remember (again) that, in the majority of countries where you can read this Instructable, you need to check the legality of distilling alcoholic beverages for personal use.
243 comments
1-40 of 243next »
May 6, 2012. 7:08 PMShadeburst says:
The distilled ethanol will be close to tasteless, right? How do we go about giving it a genuine whisky/whiskey taste? At a recent brandy tasting the presenter said that they store it for three years minimum in casks of charred French oak. I'm guessing that some caramel is added to provide colour? Bell's for example has a strong toffee taste.
Mar 21, 2012. 7:45 PMbarefootbohemian says:
This was so nice to read, I got distracted and just had to when I saw the title. I had used very similar method to build myself a distilling chamber for essential oils, but I think I will go back and make some changes to mine. Maybe then I can delve into making some absinthe :)
Mar 28, 2012. 9:06 AMbarefootbohemian says:
Ha ha, good thought! But since I have an allergy to alcohol, it will be my "taste testers" seeing fairies and elephants running about the room!
Aug 5, 2011. 11:21 PMfuzvulf says:
For fuel distillation, good instruct able.
a note of caution
One brance of my family tree was in the Appalachian mountains of Virginia, US. They were not well liked by revenuers but they were by their customers. Some people thought it was okay to use just anything to distil spirits. Its not. For fuel use its probably fine but if anyone on here is planning on drinking anything then please read the following.
The stills built by my ancestors were all copper, assembled with fold joints, copper rivets and sealed with a paste made from corn starch, flour and cat tail fluff. The still was heated slowly to cure the paste and no solder was ever used on any of the connections. Where possible the copper was formed to a tight joint that really didn't need much help in sealing.
heated alcohol can and will disolve lead out of solder or even eventually from harder alloys. Do a search on pewter's contribution to lead poisoning in history.
Heat, steam, and alcohol vapour can leach out undesireable substances from materials not suited to distillation. Not all epoxies are chemically inert when set and may result in a contaminated end product. Even chemically inert epoxies may become chemically active if the user exceeds the epoxy's heat limitations.
Some brass contains small amounts of lead, especially brass which comes from certain asian countries and therfore should not be used for standard food or beverage containers much less under the conditions encountered during distillation.
I count most of you folks as friends I'd like to keep all of you around as long as possible :p
Mar 21, 2012. 7:50 PMbarefootbohemian says:
I am so glad you added that, as it has been the downfall (and worse) of many wanna-be moonshiners.
Note to HG341, lead free solder is not safe for this application either. It will react the same as steel does.
And note on another side: medical treatment for anti-freeze poisoning is pure ETOH (aka ethanol) intravenously given only under strict medical supervision and monitoring.
Feb 20, 2012. 4:57 PMnamora says:
All great advice. The booze is hard enough on a guy without laceing it with heavy metals. As a jeweler I have used silver solder which contains no lead however I don't know what besides silver it contains. Just a thought.
Feb 11, 2012. 9:55 PMhg341 says:
use lead free solder they make it now xD
Oct 19, 2011. 6:54 PMcdousley says:
i feel like ive read that entire statement before
Aug 15, 2011. 5:57 PMxd12c says:
I have access to quite a bit of stainless steep pipe & tube. What diameter should the pipe be and would the wall thickness be a factor? Would you want a thicker or a thinner wall?
Also, I see a lot of comments about solder & flux, etc... What about welding? I work with a bunch of PED welders that would give me a hand...
Sep 5, 2011. 6:38 PMbg_askins says:
stainless reacts with the vapors thats why copper is used in stills
Sep 9, 2011. 4:56 AMswingbug62 says:
quite to the contrary,stainless does not react,however copper does and helps to neutralize nasty compounds that cause off flavors.
Sep 11, 2011. 9:07 AMbg_askins says:
you win i just knew copper was good and stainless was bad thanks for the correction
Jan 23, 2012. 7:23 PMstoneyone says:
copper is good so is stainless aluminumin is bad the gas brings out the bad things in the alum ive made a lot of runs with copper and stainless never been sick
Aug 27, 2011. 8:06 PMtrushing1 says:
You may know this already,but make sure you weld the joints from the inside out so you have a sanitary weld on the inside of your pipe.Do this by taping the gas to the top of the tubing and tig the weld.The gas will come out he joint to be welded and produce a smooth seam on the inside of the pipe.
Jul 26, 2010. 8:21 AMcanadachris says:
if anyone needs any information about how to make your own homemade alcohol safely, Id be glad to help out, my grandfather owns vineyards in leamington, Ontario Canada and we have been making wine and all sorts of spirits for over a decade, its a simple process and Id hate to see someone get ill because of mistakes that could have been easily avoided,
Jan 16, 2012. 1:48 AMloyalsidhu says:
Hi
please let me know the whole process & quantity ratio of sugar, water, yeast etc for 40 litre.
Mail at sirnava@gmail.com
Thanks
Jan 10, 2012. 5:46 PMoregonredneck says:
I would really love some advise and help. If you or anyone could contact me that would be awesome. I made my first run and have a finished product but need some help on the hydrometer and fermenting questions as well. thanks emccally83@msn.com
Mar 18, 2011. 5:02 AMgeorogers says:
I have a copper still it lacks a "worm",however I'd like to know how to make brew and distill a clear potable spirit.For my first run I'd like to keep the process as simple as possible.Thanks , George Rogers
Jan 13, 2011. 3:23 PMJyssa says:
I want to make a liquor out of the plums that grow in my backyard. I'm from NZ so it's perfectly legal to do it here, but I just don't know how!
Dec 3, 2010. 12:29 PMsnakeeyes101 says:
Hello,
When first using my still, how do I calibrate the amount of methanol that will come off before I reach the ethanol? Thanks for your help.
Aug 6, 2010. 11:17 PMBearcat_Welding says:
I'm a first time starter and im wanting to do Wines and Brandies, My wife and I love the great fruit flaviors in both. I'm going to be doing every bit of it at home and i would like to know what you would recommand from start to end and the process, what is the best things to use not only in fruit but materials.. I would like to use, of course grapes,razzbries, and maybe oranges. If you have any other suggestions on fruit, please let me know. If we need to do this at a more private setting let me know and we will set-up something with e-mails Thanks Bearcat
Oct 5, 2011. 4:20 PMJavin007 says:
Plums make an excellent whiskey.
Sep 27, 2011. 4:58 PMkullervo says:
This is how I won the science fair in ninth grade. County, too. Built a still and distilled Coors into pure alcohol. My teacher wouldn't loan me a hygrometer, so I used pH paper to test purity.
There were still Coors stains on the ceiling in my room when my parents sold the house.
Oct 19, 2011. 6:52 PMcdousley says:
"Mom buy me some beer!" "WHY?" "uhhhh....School project"
Oct 19, 2011. 10:12 PMkullervo says:
I always did well in science. The key is motivation.
Jul 5, 2010. 2:20 PMseamaas says:
it's called wort not wash
Aug 4, 2011. 9:27 AMlunitick says:
For young BEER that has not been fermented it is called wort (vert) after the MASH has been fermented and is in the prosess of being distilled it is called WASH.
Jul 5, 2010. 11:04 PMseamaas says:
you're right I forgot. i am an amateur brewer do i should now by now
Aug 1, 2011. 2:03 PMtechno guy says:
So can you just directly burn whatever comes out as the final product?
Jul 28, 2011. 8:52 AMrickharris says:
Errr it's Illegal in the UK unless licensed!!
Still pots don't explode! tell that to the 5 Eastern Europeans recently killed in Boston Lincs.
Your picture of the pressure cooker seems to show the safety valve which you say don't bother if it gets blocked - Whereas in a perfect world the system isn't pressurised there are circumstances where it might be and so the safety valve is a good - Ummm -Safety feature.
I have 'heard' you can distil alcohol in the freezer freezing the water and then pour off the Alcohol. You could do this in a PET soda bottle. There are Turbo yeasts that produce higher levels of alcohol.
Jul 21, 2011. 10:57 PMtdawber-mandeno says:
it's great in new zeland there is no laws against distilling but you can not sell...
Apr 21, 2011. 8:55 PMcbs2018 says:
cool
Oct 14, 2010. 10:21 AMzhenpenthaye says:
Rectifier: I'm not sure about what you call the "Acetone" coming out of the still after the main product:) Acetone has a boiling point of 58 degrees C, so you should have cleared all of it in the headings.
Oct 12, 2010. 7:21 PMMT-LB says:
Hey and if its undrinkable you could always use it as grease cutter
Apr 5, 2008. 11:06 PMRectifier says:
Never use steel wool. It will rust away immediately and ruin everything. Copper only, fastened with lead-free solder, or brazed, if you want a drinkable product. Lee valley sells a copper mesh for keeping slugs out of the garden that makes an excellent column packing. Packing is not necessary for a whiskey still, by the way.
Sep 17, 2010. 1:53 PMseamaas says:
also don't use glass use quartz sand ,sweaty gym sock (from the TV show M*A*S*H),activated charcoal (from a BRITA filter),or combination of quartz sand and activated charcoal
1-40 of 243next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
831
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
