3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Whisky Still
Step 3The Column
The Column
Alcohol and water have surprisingly similar properties - each will dissolve in the other. This means that you will get water vapours in with the alcohol vapours, but they can be reduced. A tall column above the vat gives the water vapour a chance to condense and fall back.
If you can increase the surface area within the column, so much the better. Looking in my shed, I see a three-foot length of two-inch diameter tube that would be ideal - it's an old bed-leg. To increase the area inside, I could hammer lots and lots of nails into the pipe, or fill it with steel wool. If I was bothered about rust, I could use a similar copper tube and fill it with broken glass.
The column can be connected to the vat by drilling a suitable-diameter hole in the lid of the pressure-cooker, removing the weight-system. The gap between the column and the lid can be sealed with solder, epoxy, welded, or sealed with a compression-fitting, depending on the size of the column and the materials involved. Do not worry about removing the weights or blocking the safety-valve, as the still is never under pressure unless you do something stupidly wrong. The top of the column needs capping, with a hole in the cap to allow insertion of the thermometer. As with the joint at the bottom, this depends on the exact materials you used - it could be as basic as dropping a tin can over the top and epoxying it in place.
16 comments
Aug 15, 2011. 5:57 PMxd12c says:
I have access to quite a bit of stainless steep pipe & tube. What diameter should the pipe be and would the wall thickness be a factor? Would you want a thicker or a thinner wall?
Also, I see a lot of comments about solder & flux, etc... What about welding? I work with a bunch of PED welders that would give me a hand...
Sep 5, 2011. 6:38 PMbg_askins says:
stainless reacts with the vapors thats why copper is used in stills
Sep 9, 2011. 4:56 AMswingbug62 says:
quite to the contrary,stainless does not react,however copper does and helps to neutralize nasty compounds that cause off flavors.
Sep 11, 2011. 9:07 AMbg_askins says:
you win i just knew copper was good and stainless was bad thanks for the correction
Jan 23, 2012. 7:23 PMstoneyone says:
copper is good so is stainless aluminumin is bad the gas brings out the bad things in the alum ive made a lot of runs with copper and stainless never been sick
Aug 27, 2011. 8:06 PMtrushing1 says:
You may know this already,but make sure you weld the joints from the inside out so you have a sanitary weld on the inside of your pipe.Do this by taping the gas to the top of the tubing and tig the weld.The gas will come out he joint to be welded and produce a smooth seam on the inside of the pipe.
Apr 5, 2008. 11:06 PMRectifier says:
Never use steel wool. It will rust away immediately and ruin everything. Copper only, fastened with lead-free solder, or brazed, if you want a drinkable product. Lee valley sells a copper mesh for keeping slugs out of the garden that makes an excellent column packing. Packing is not necessary for a whiskey still, by the way.
Sep 17, 2010. 1:53 PMseamaas says:
also don't use glass use quartz sand ,sweaty gym sock (from the TV show M*A*S*H),activated charcoal (from a BRITA filter),or combination of quartz sand and activated charcoal
Apr 13, 2008. 9:28 AMtriggernum5 says:
Actually the packing essentialy performs extra distillations in the column.. HETP = Height Eqv to Theoretical Plate.. The vapur condenses in the column and redistills on further evaporation..
Actually the same effect can be had with a pot-still + thumper.. That would also allow you to reduce the stupid materials that could make it into your product without much for additional supplies.. If you build the thumper safely, then I'd only be concerned with solvents coming through.. You're right that heavy metals tend to fall back, but I know from experience that crap ends up in the down side.. Perhaps because of tilting/moving the still etc, but the end result is contamination of the downward slope.. The thumper would be easy to keep clean, and would trap any heavy impurities..
Sep 17, 2010. 1:58 PMseamaas says:
a thumper is a vessel filled with water which is between the vat and the condenser which catches any of the mash that is carried with the alcohol vapors. it is sort of like how a bong works or water pipe
Aug 4, 2008. 4:43 AMRishnai says:
They also have a habit of making thumping noises (probably through the same principle as the clicking noises cars make when they are parked and turned off after a long run). Quietly, but loud enough to be unnerving if you think there's ATF in them thar hills.
Apr 20, 2008. 8:45 PMtriggernum5 says:
A thumper is a midway redistillation.. From your still, a short, (insulated?) copper line runs into a sealed collector jar or whatever (but it can get really hot), and the line should run to nearly the bottom of that vessel.. Another line is attached to the lid of that vessel to accept vapor to the condenser.. You fill the thumper with already distilled liquor, and the heat from the new distillate going into the thumper boils the thumper.. What comes out of the thumper will be higher abv than a single distillation as long as the liquid in the thumper is stronger than your actual wash.. Its also a good way just to reduce the condenser length, since your actually putting the heat to work..
Apr 7, 2008. 3:06 PMRFilyaw says:
Also, stainless steel wool is available, and is cheap. It will not rust.
Apr 11, 2008. 9:43 PMSergei- says:
Hi Safest cleanest way is to get 100% copper mesh, people use it to control rats and mice from chewing into walls. Can't use just any tube. Rust shouldn't be an issue anywhere when making something people consume the safest thing is using food grade materials. You should nail nails through a pipe because it's unsafe especialy if you heating your boiler with gas, the vaipar will definatly leak out and boom there goes your set up and and a few things around it.
Apr 13, 2008. 9:37 AMtriggernum5 says:
I use Stainless Steel pot-scrubbers.. They fit ideally in a 2" column, great surface area and HETP, easy to clean via electrolysis, and the dollar store was selling 9/$1CDN which is about 8-9" of column packing.. They make copper scrubbers too.. Scrubbers are a refluxer's dream for ease of use.. I tried making copper scrubber type things out of stripped electrical wire.. Not horrible, but tough to keep available surface area.. I'm glad I picked up the 110 packs of scrubbers they had at the dollar store.. I think I'm set for life now with ~1000..:)
Apr 12, 2008. 10:12 AMtriggernum5 says:
What with the mesh and nail holes? Are you talking about reflux column packing?
Apr 13, 2008. 1:43 AMSergei- says:
Look at page step 3
Apr 13, 2008. 9:14 AMtriggernum5 says:
So lemme get this straight You're using an Aluminum, or brass column, filling it with galvanized metal, and sealing it with epoxy??
I'd seriously consider having your product tested, that is begging for trouble!!
Copper, stainless steel, or lab-glass column (doubtfully available if you used your bed-frame), with PROPER sealant, and SS, Cu, clay, or glass packing.. SS or copper dish scrubbies are ideal.. Their HETP is much smaller than marbles or raschig rings..
Personally I think the person you wrote this instructable has no business teaching others.. Its like the blind leading the soon to be blind..
For $50-100 you can build a still to write home about, that won't have the potential to poison ppl..
Copper, SS, silver solder and foodsafe flux, and flour based pastes.. Those are pretty much your allowed materials.. PERIOD!
Apr 13, 2008. 12:29 PMWhoTookMudshark says:
"the blind leading the soon to be blind" made me laugh out loud! Haha.
Apr 13, 2008. 9:18 AMtriggernum5 says:
Sorry Sergei, it kinda sounded like I was accusing you of these idiotic decisions.. Its the instructor that worries me.. I guess I was thinking you wrote it when you pointed out Step 3..
Apr 11, 2008. 9:47 PMSergei- says:
Oh yeah shouldn't use epoxy a dangerous chance contamonents from it might leech out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
830
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
