iImage Information
This is a 450v high voltage shocker/capacitor charger. Please note, though, that this device has a very high output voltage, and it (might?) kill the weak of heart (not to mention, it HURTS), so be careful when handling any capacitor or high voltage circuit. Thanks to Plasmana who got me started.
Step 11: Get the components.
iImage Information
Go to any place that devolopes desposable camera film. Ask nicely and you should be able to get a couple for free. The guts have already been removed...
Why is this?
grabbed more fun pic cameras for my "Daughters School Project". I wanted a more "D R O P" resistance device & everything neatly protected.
the subminature micro switch is positioned inside the 1 1/4 "PVC tube.
you squeeze the tube to charge, .....3- 5 sec. is plenty!!
I also wanted my actual college bound daughter to be able to change the batterys. So, I cut the battery holder out of the camera case & slide inside.
I only wish for a way to drain off the excess charge w/o blowing the board!
have KILLED 2 after discharging it against a metal surface. bummer :-(
its all fun,
Mr. Steve
Props to xkred27... this works sooo well!
built a 2nd one today!
I found that of the 7 cameras I received, only 2 were red LED's.
I believe the correct fun camera's item # is 3J9162.
{ located on bottom right }
see attached pix.
I concealed everything inside a Grill Lighter ! :-)
very cool,
Steve
I went to the local big "W-box" drug store & asked for 6 Fun cameras for my daughters' school Photo project.
Scored 7 !
I built this in an hour , mostly due to finding gear & stuff.
WoW!
a 5 sec. charge is a shocking surprise.
THIS WORKS AS STATED. probably make a couple more .
I used a Dremel tool with cut off abrasive wheel for the surgery on PCB bd.
I am trying to "shoe horn" it into an old Grille Lighter. {more innocent looking}
will post pic when done.
Congrats to Plasmana & to Xkred27 for a great follow up.
Steve
this is the basic electronics method.
to protect the dioder or transistors from HEAT while soldering.
you take a alligator clip or a aluminum heat sinking clip, made just for this purpose.
even small needle nose pliers & a rubber band on handles work.
clip to the lead you are soldering, between the body & your heat.
that keeps you from cooking the transistor.
though pre-tin & be quick.
Mr. Steve
Will post pics when I have time but in the meantime I welcome any suggestions.
the AA batteries are way too big to hide it good. but if u use 2 LR44 button cells
it becomes smaller!
The bigger one is actually an "electrolytic capacitor.
