3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a better RGB LED controller.
Step 3Adding the resistors.
There are four resistors to install and to keep things simple they are all the same value - 1000 ohms.
They are not polarity sensitive, so can be inserted any way round. Perfectionists might like to make the colour bands all read in the same direction.
The group of three resistors in parallel are for the MOSFET control, while the one that sits at the bottom of the PCB on its own is to limit current through the power indicator LED to a few mA.
The colour code on each resistor reads as follows. Brown (1), Black (0), Red (2), Gold (5%). The resistor value is worked out as 1, 0 and a multiplier of 2 which means two more zeros. Therefore it is 1000 ohms. The gold band indicates that the measured value has a tolerance of plus or minus 5%.
1 comment
Aug 23, 2011. 9:09 PMExiumind says:
"The group of three resistors in parallel are for the MOSFET control" What is their function? will some irf630 work? i plan to do this with an arduino..
sorry im quite a noob =P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:bigclive
Self employed industrial electrician who likes taking stuff to bits and modifying it, or building completely new stuff. There's nothing nicer than a completely unique one-off item that you custom mad...
more »
