Step 5The power indicator LED.
iImage Information
The power indicator LED will only light if it is installed the correct way round, so note that the PCB position has a "+" symbol to indicate the long lead (the anode). LEDs generally have a longer positive lead and a small flat surface on the negative side of the resin package. If you look through the LED you will see that one of the electrodes is anvil shaped inside and holds the chip, while the other electrode is quite thin and just goes up the side of the anvil. Generally speaking the anvil is on the negative lead (but not always).
The power indicator LED is a simple but very useful addition to any control module. It makes troubleshooting so much easier if you can see that your unit is powered up and the 5V supply is healthy.
