A few technical and functional improvements:
- Less wires - controllers and batteries move with the motors and are signaled with IR light.
- Precision not needed - I was able to set-up a 8x10ft track without measuring anything
- Reproducible - used standard parts, used the same components in many spots
- Expandable - use longer tracks to make it bigger - track cost is about 50cents a foot.
- Removable - hangs from the ceiling by 4 small hooks
- Future? Could be used as basis for a big 3D printer
Overview
- Materials
- Frame
- X-Axis Mechanical
- Y-Axis Mechanical
- Z-Axis Mechanical
- X-Axis Electronics
- Y-Axis Electronics
- Z-Axis Electronics
- IR Control Overview
- IR Receive Circuit
- IR Transmitter (TV remote)
- IR Decode Process
- X-Axis Control Code
- Y/Z - Axis Control Code
- What's next?
- Complete Wiring
- Complete Code
Remove these ads by
Signing UpStep 1: Materials
6 - 8' J channel
7 - Big continous servo motors -- HobbyPartz --- EXI-Servo-B1226
1 - Roll of electrical tape
2 - Arduino UNO boards
3 - Small peices of perferatored board
2 - IR de-modulator
1 - Universal TV remote control
1 - 25' coiled phone chord
1 - 15' straight phone chord
1 - Roll packing tape
1 - Pre-made claw with servo -- Spark Fun ROB-10332
2 - 4 AA battery packs, rechargeable
6 - screw hooks
3 - Peice plywood - 2x6" each
1 - roll metal plumbers strap
Tools:
- Drill
- Computer
- Soldering iron
![knex claw machine [first on site] that has instructans](http://www.instructables.com/files/deriv/FJW/PDVN/GGPF4BSL/FJWPDVNGGPF4BSL.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
And what is the IR de-modulator? could you
send a picture of it separatly?
thanks!
I haven't got my head around arduinos yet, but, I'm thinking about using worm driven wheels controlled by multi channel proportional radio -so does not matter.
Again, fantastic stuff. Did you ever try this set up with a more powerful claw servo by the way, how does it wok out?
I used the servo motors because I already had them. I disabled the position feedback, so they are just small DC motors with gearboxes and control boards, in a plastic case. My thought was "What can I do with all these servo motors? Maybe I can just tape them together...."
All the Arduino stuff and IR is not really needed either. You could do this with no micros, just physical switches and wires.
I still have the thing up on the ceiling, but I made it hard to replace the batteries, and did not include an off switch, so they die over a few days even if not used.
but one question . i had normal dc motors in mind which i was going to use . i notice u used servo motors . but why is that ? what was the necessity to use servo motors
? can't accomplish the same objective by normal dc motors?
I don't see the code or the wiring
