3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a cheap soldering iron holder
This is a soldering iron holder that I built for less than $10.  It will hold multiple soldering irons or desoldering irons, and it supports the iron by the handle, so that the iron's heat is not wasted by heating up the soldering iron holder itself.
Step 1Materials and tools needed
List of materials:
1.  Metal electrical box.  You can pick this up at a hardware store.  The one I am using is a square, deep-well galvanized box.  It is a 2-gang size, 4 inches square, meaning that you could fit two standard switches or outlets inside it.  The deep well holds the soldering irons at a steeper angle, but you don't necessarily need it for the holder to work.  A 2-gang box means that I can have two (or even three) soldering irons stored in it, so if you only need one iron at a time, a smaller electrical box can be used.
2.  A piece of scrap 2x4 wood, 3 or 4 inches long.  This will elevate the soldering irons so that the tips don't accidentally touch the worktable.
3. A larger piece of scrap wood for the base.  Mine is a piece of 1x10 pine.
4.  Wood screws.  The ones used here are one and a half inch deck screws.  They just have to be long enough to go through your base wood and into the 2x4.
You will need a hammer and screwdriver to assemble this. In addition, I recommend a drill fitted with a screwdriver tip to speed up assembly.
3 comments
Mar 14, 2010. 9:40 AMdchall8 says:
I need that!  Thanks!!
Mar 13, 2010. 9:22 PMcaitlinsdad says:
Nice, I would still think you need to put a "cage" around the hot end sticking out.  Maybe a piece of stiff coathanger wire in a stretched spring shape screwed on to the opening.  There are a few times I've caught the cord and dragged the iron across the workbench.  Your idea would be good for hot glue guns too.
There may be sharp burr from breaking out the punchout coins.  Make sure you file them smooth so kids don't cut themselves, let them make mini ninja stars if they want to do that.
Mar 13, 2010. 7:57 PMmeddler says:
Cool idea. I do a lot of wood burning art. This is neat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:exabopper
dot-com crash casualty
