This example will be making a display that only shows the basic PC info. However once you understand how this works the possibilities are endless (I use it to display every temp/voltage in my overclocked Crossfire enabled PC).
I will also put some tips at the end of the guide on how to work around a few bugs in LCD studio and make it load up a lot faster.
(This guide will also work for most LCD panels which can be accessed Via LCD studio.)
LCD studio basically works with a series of plugins which gather data from other programs and let you display it on your LCD screen. It comes with most of the plugins you will ever need but there might be one or two programs that you will need to have running to get the most from it.
The main ones I recommend and the ones used in this example are:
Fraps: http://www.fraps.com/download.php
Used to get your Frames per second data
Speedfan: http://www.almico.com/sfdownload.php
Used to get a lot of system information. In general always use more then one piece of monitoring software as not all of them are 100% accurate and you get a better picture by comparing results.
There are loads more and you will probably find that any monitoring software you already use has some plugins available.
Remove these ads by
Signing UpStep 1Getting Started
The image has to be 160X43 so I made a blank (black) new image of this size in Photoshop, saved it and opened in Paint. The thing to remember when you are making your image is that white will show up as black and vice versa so its easier to start with a black box and use a white brush.
**Quick tip: Make a new design in LCD Studio and insert the blank image (top button in the "Toolbox" tab). Now when you are making your design in Paint click save for an instant preview on your G15 or LCD screen.**
I have made a basic background template for use in this example which you can use by saving the Picture below.
Once you have your background setup in LCD studio it is time to start adding the data. In this basic example we are only going to get the system time, CPU temp, CPU Load (as a graph), memory load and FPS.
4
comments
Add Comment
Add Comment
