3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a custom display in LCD Studio (For G15 keyboard and LCD screens).
Step 7LCD Studio Tricks and Tips
This is just the most basic information display but using the same technique you can create pages of displays for anything you want. I personally have 1 screen showing all the main system info, then others that I can switch to showing detailed info for each part of the system.
To Run your design when windows starts you need to make a new playlist and add your designs to it.
Then go to "Tools", "options" Then click the "General" tab.
Make sure "Load at start up" is checked.
Make sure its set to run in traybar.
Select your saved playlist as your startup playlist.
Uncheck the bottom 3 boxes.
Now close this and exit LCD studio COMPLETELY. It is bugged and will NOT save your options unless you close it down now (if it closes with windows it will not save any options you have changed).
To make it load a bit quicker go back to "tools", "options" then click the "Plugins" tab.
Select each plugin that you wont use and untick the load at start up option.
Again close this and close LCD studio COMPLETELY to save your options.
You can more then like cut out a LOT of plugins and this saves loads of time when you boot up.
Well I hope that was of some use to someone. The G15 display is a brilliant tool for overclockers. With a decent display setup you no longer have to scan between 5 pieces of software to check your system stats while you are OC'ing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Duranis
