3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
51 comments
1-40 of 51next »
Jul 25, 2011. 7:44 PMjrevard says:
Instructions are gone. Can anyone email them to me?
jprevard@gmail.com
Justin Revard
Jul 20, 2011. 6:30 PMrussian lumpy says:
i dont get the part where you put that thing on that on that other thing on that one step
Jul 15, 2011. 2:36 PMaxeman911 says:
nice instructable, i like it
May 15, 2011. 11:01 PMhellstudios says:
Very Interesting project you have right there...
Nov 25, 2010. 10:25 AMmarcelocamposs says:
This project don´t works :
dont waste your time building it, there are too much errors: ports assigned to LCD are diferent in schematics and firmware, configuration bits are not correctly set by firmware, there are a reference to a lib not included, and more ... I only don´t understood why this guy post this here if he knows that will not work
Nov 24, 2010. 9:43 AMmarcelocamposs says:
Dear vithrar,
And about the xtal: this circuit don´t needs ?
Hi vithrar
And abou the cristal oscilator: this circuit don´t needs one ?
Sep 5, 2010. 12:46 AMmedieval says:
Good day sir. I'm very interested in this project. Could you kindly send me the .asm code? I try to compile the abvove given code, but there's quite a few errors. Thanks in advance.
Jun 23, 2010. 7:57 PMpeterpan73 says:
Unless the intention is to learn something, if its just the utility and cost wouldn;t it be a lot better to just buy it off the shelf as this :- http://www.jyetech.com/Products/LcdScope/eDSO062.php or get better bandwidth by simply using FPGA Pluto boards? Saves time and effort.
Mar 8, 2010. 8:39 PMvishnumohan1989 says:
Hi,
Can anyone help me in my project which is almost similar to the SCOPEY.I'm doing the project frequency measurement using FFT technique with a dsPIC4011.The measured frequency has to be displayed on a PC via RS232. Can any1 pls send me the code for this in C or Assembly??????i desperately need the code...
Mar 4, 2010. 1:34 PMptal78 says:
Is there anyway to make this work off the +5V from a USB?
Jan 26, 2010. 8:31 AMtissit says:
For "16-bit goodness", you should also have a look at the TI MSP430 line.
Nov 30, 2009. 6:30 PMsmartdude488 says:
 Has anyone built this?  I can't seem to get the GLCD to function.  Does anyone know the correct pin out on the board by pin name?
Oct 22, 2009. 12:22 PMsubaru1432 says:
dear
would you mind tell me these codes is suitable for pic30f6014a??
if not suite how can rewrite the program
Sep 22, 2009. 1:58 AMPISCESII says:
Very good write a program in assembly really difficult and this project is a good sample that every one that want to begin write dsPIC in assembly writer of this program has a good view about dsPIC & oscop Ehsan Mehrabi
Jul 20, 2009. 7:56 AMmeghas027 says:
i liked your project.can you arrange for the c code instead of assembly for this project.
Jul 12, 2009. 11:51 PMmehrdad1365 says:
hi.... Do You have the hex code? And others(Source code)? Can you send me?
Jun 24, 2009. 12:44 PMWicher says:
I did it this connection, but not mqködik.Valakinek has been constructed? What are the config settings?
May 29, 2009. 1:44 PMWicher says:
Sir can send me the hex code?
May 24, 2009. 12:07 AMfluffy111 says:
I like your project. But like liikata said there is no .hex file. Can you please send me that file? fluffy.gm@gmail.com
Apr 8, 2009. 4:46 AMliikata says:
Dear vithrar, i like your project, and i thing to make it, but i don see the source file /asm, hex../?
Can you send me?
I thing this is the great project for low cost scope!!!!
liikata@abv.bg
Thank you?
Dec 1, 2008. 11:26 PMsoshimo says:
Great project! Exactly what I needed and straightforward circuitry. The software is a work of art. One question though regarding the power supply. Could I use a wallwart jack and regulator circuitry with a wallwart supply instead of the onboard PS? I was hoping to prototype this before I etched it and am a little wary of having 120v AC laying around on bare poles. Thanks for a great weekend project though!
Feb 18, 2008. 7:38 AMjrv_boots says:
This is a great project to make! I would probably make this one with a higher sampling DSP(2Msps), add a dual trace feature, and give it a larger display (320x240).
Nov 8, 2008. 12:07 AMjsprat2012 says:
Okay, I have the printed circuit board layouts and photo etching ready to go. I have the chips and all the parts. Now, how do I make the software into something I can program into the PIC?
Feb 21, 2008. 5:29 AMjrv_boots says:
Yes, 2Msps is VERY wimpy, especially when other component can get 10Msps and better. Microchip has some DSP controllers with 2 ADCs built in. 320x240 displays can vary in price with the high end in the $100 or so. Any thoughts about adding in a USB port?
Nov 6, 2008. 11:03 PMThe Lightning Stalker says:
     My congrats to you for building this and doing all the programming in asm. It really is quite an achievement.
Oct 25, 2008. 9:22 PMjsprat2012 says:
The HEX code would certainly make like easier. Who knows, maybe someone could actually build one, besides Vithrar, that is. This construct with mystery code reminds me of Circuit Cellar. I purchased a "Build this" article only to find they do not have any printed circuit board artwork. Now who, in their right mind, is going to waste six months making, testing, and remaking a PCB for a "one-of" construction project? Vithrar must be a Circuit Cellar fan. They do not have artwork and he only supplies mystery code.
Aug 7, 2008. 7:38 AMlieshamza says:
Could you share the source please. Yes, because it does not work with my version of MPlab. Thank you in advance
Jun 12, 2008. 12:21 PMsubin.sam says:
sir , can u provide us the hex code.
Aug 1, 2008. 7:55 AMpbj says:
Good morning! Do You have the hex code? And others(Source code)? Can you send me? Thank you?
Jun 18, 2008. 1:56 PMj9k says:
just bought aan icd2 for the 33f devices and have been looking on the net for projects purely coded in assembly. everything is coded in C... even the examples from Microchip. anyway i want to learn assembly and this projects code has been a big help. THANKS!!!!!!!!! j9k
May 30, 2008. 12:09 AMsubin.sam says:
sir can i also use AGM1264F-FL-GTS-D
May 17, 2008. 7:58 PMmichaelmill says:
HI.
I like this scope . But I have a question.
In the schematic you have lines RB4,RB5,RB,RB&,RB8 of the pic going to only 3 pot's ? And a parts placemeat for the pcb's Any help would be appreciated.
thank you michael
May 14, 2008. 10:54 PMsubin.sam says:
sir can i use LCM-H12864GSF
Apr 14, 2008. 6:41 AMtestor says:
Very Fine! It looks like you have done the hardest parts of a portable oscilloscope. Perhaps you or another would look into adapting the circuit to work with a laptop through the USB port.
Jan 20, 2008. 8:38 PMthegimpster says:
Great project. I have been looking for a cheap o-scope to build. For those of you out there wondering wether to build it or not I have been doing some searching and you can get the 3 main chips for free. The two microchip ones you can get as free samples, and you can get the other chip from TI as a sample too. That just leaves the display to buy assuming you have or can scavange the other stuff.
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:vithrar
