3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a foundry and sand-cast aluminum.
Step 4Materials and tools.
I built my furnace for nothing, and you can too if you borrow some tools and swipe some trash.
Required to build furnace
Tools
  • Drill with large bit suitable for steel. (Hammer and large steel spike can be substituted)
  • Tin snips
Parts
  • 2 coffee cans of equal dimensions (one for furnace, one for air chamber)
  • 1 hair dryer with a cold air setting
  • 1 tin can (Blue Runner bean cans are the perfect size and are very strurdy)
  • At least 4 metal stakes (optional)
Required to operate furnace
Stuff
  • Instant light charcoal
  • Charcoal lighter fluid
  • Barbeque lighter (the long-nozzled kind)
  • A bucket of water (to cool hot tools)
  • Aluminum cans
  • 3 or more boxes (optional)
Tools
  • Tongs (I use 2 pairs)
  • Some sort of long, metal stick
Safety gear
  • Leather gloves (preferably welding)
  • 100% Leather and/or cotton upper torso/arm coverings (Big Smith jackets are perfect)
  • Gas mask (optional, you can just hold your breath when near the furnace)
Required to make mold
  • a large container
  • sand
  • Something to impint a design in sand with or way to draw in sand (pottery, carvings, body parts
etc.)
10 comments
Jan 7, 2012. 10:30 AMWiredfey says:
Question,i have a heat gun which i use to take off formica when doing remodel and use it to melt ice. would this be more effective?
Feb 9, 2012. 8:23 AMWiredfey says:
that's kind of funny but interesting :) thanx,time to hit up a goodwill for a dryer.
Jun 10, 2009. 1:46 PMman ray says:
what did you use for a crucible?
Aug 4, 2009. 9:43 PMWyle_E says:
That was certainly a steel can. BTW, I've seen a lot of aluminum soup cans lately. They usually have pull-tab tops. Before you use a food can for a crucible, check it with a magnet. The best cheap crucible for aluminum and zinc alloys is a short piece of steel pipe with a piece of steel plate welded over one end. I haven't checked with local welding shops, but it would probably cost less than the cheapest clay-graphite crucible from Budget Casting Supply. There are a *lot* of web sites devoted to amateur foundry. www.backyardmetalcasting.con is a good start.
Sep 11, 2011. 6:29 PMbshelton4 says:
I can make you some stainless crucibles if you would like or carbon steel. I take paypal so you are covered and ship USPS.just need to know the size and what kind of material you would like. 256-309-9406 is my number. Thanks.
Dec 10, 2009. 1:47 PMlegendeveryone says:
Can you use a glass bottle or container as a crucible? I know it has a much higher melting point than aluminum and is somewhat easier to come by than steel.
Oct 1, 2009. 2:50 AMbackyardmunitionist says:
Have you ever tried a ceramic crucible? I was wondering if you would get a purer product if you didn't have the ferric metal possibly alloying minutely with the aluminum.
May 18, 2010. 11:54 AMleifbus says:
 Could you make a crucible out of plaster? (since you could cast the aluminum into it anyway?)
May 26, 2010. 8:12 AMWyle_E says:
Plaster, like portland cement, sets by a hydration reaction.  Get it hot enough and it dehydrates, turning back into dust.  The furnace is going to be a lot hotter than a mold full of molten metal.
Jul 2, 2011. 8:44 AMjbend says:
can you use wood insted of charcoal.
Jun 27, 2009. 6:16 PMgoodinstructabledude says:
What happens when you don't hold your breath?
Aug 6, 2009. 12:10 PMSeverinR says:
its called metal fume fever. The galvinized steel cans produce fumes and probably the impuritys of the aluminum do too.
May 4, 2010. 5:49 AMgusew says:
I saw once that you could TIG (GTAW or gas tungsten arc welding) weld two soda cans together...so i tried it in my welding and metal fab. class and the cans just melted and smelled horrible causing a bad headche.
Apr 24, 2009. 11:52 AMarduinoe says:
thats a cool drill
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Fenris The bbw
