Step 7Assembling the furnace
1. Insert hair-dryer into air chamber
2. Put fire chamber on top of air chamber
-Which is easy as pie but extremely dangerous. If the fire chamber is nudged even the slightest bit the whole thing will topple over, creating a gauntlet of hot coals and molten metal at your feet.
On the other hand though, being able to remove the fire chamber from the furnace gives you the advantage of being able to shake out the coal dust that will eventually clog the holes to the air chamber. This allows you to keep the fire burning hot longer for multiple melts.
If you feel you can't handle having the fire chamber loose, than you should dig a fire pit, fill it with sand, and put metal stakes in the ground running along the sides of the cans. This will hold the cans in place but still allow you to quickly remove the fire chamber.
The tabs were about 1/2" wide by 2" long and 1/16" thick and available at home depot or lowes. I attached them with two screws each so they couldn't pivot.
Also, doesn't your hair dryer melt? I had an old dryer from the 60's with a hose attachment which I hooked up to the plenum with some pvc fittings. The PVC melted the first firing. Then I got some brass fittings and it was fine.
And I've been wondering about the dryer myself. It's got scorch marks all over the nozzle, but it seems to not be melting at all.
