Step 8Destroying your aluminum cans.
The 3 sections which have to be seperated are the top, the sides, and the bottom of the can.
My favorite method for destroying the cans is illustrated in the pictures. Unfortunately, I can't get the image notes to work, so you'll have to read the procedure up here and follow along with the pictures below.
1. Cut or rip the can in half.
2. Make a slit in the top half, perpindicular to the lid.
3. Tear along the slit and pull the siding off of the can top.
4. Make a slit in the bottom half of the can, at an angle to the bottom.
5. Tear as close to the bottom as you can, and remove siding.
This goes much faster if you form a production line with some friends in which one person has one of the steps above assigned to him/her.
I sort the cans into boxes of halves, siding, tops, and bottoms, with the occasional box for cans with painted tops or bottoms.
Once you're done with your cans, it's time to ready your foundry.
Anyone who knows anything about metal work - or elementary physics - can explain why -and explain why all of your examples are foolish. There is no need to debate the question here. Just because you havent gotten hurt yet dosen't mean you should tell amature metalcasters not to worry about adding water to their crucible.
Before you run your mouth off anymore, read "PREVENTING MOLTEN ALUMINUM-WATER EXPLOSIONS" at http://www1.eere.energy.gov/industry/aluminum/pdfs/explosions.pdf
Have a nice day.
Why on earth would you compare sticking an air hose in a bucket of water -- to steam expansion in molton metal?
"be nice"
During casting operations, there is a risk of a sudden release of molten metal due to process upsets onto casting equipment, pit walls or the pit bottom where water accumulates. As molten aluminum contacts the water, a steam film forms on the surface of the metal. The steam film can destabilize as the molten aluminum contacts other surfaces in the pit. When this occurs, the water spontaneously transforms from a liquid to steam leading to a high pressure steam explosion. While these explosions are infrequent, the possible consequences are a major concern for safe aluminum casting.
I wouldn't plunge anything into a puddle of molten aluminum that had a sweat of moisture on it, let alone actual liquid.
The puddle of metal is a seal. You can pop the top of your can and it won't make any difference at all. I can only guess that so far you have been lucky and have not trapped any steam in molten metal.
An epic steam explosion?
http://en.wikipedia.org/wiki/1883_eruption_of_Krakatoa
http://www.darwinawards.com/
http://en.wikipedia.org/wiki/Steam_explosion
see the second paragraph, second and third sentences. it describes this perfectly. the rest of the article is semi-relevant as well.
(hint hint)
I've been a little too busy to check on my instructable lately, my family and I are renovating a new house, and I don't have much free time.
If I was here to take part in this discussion here's what I would have said:
Steam explosions are very real, and a very real concern to all who work with molten metals. They are caused by water becoming trapped within a molten metal and then rising to the surface, shooting from the metal in an explosion of steam that carries molten metal with it.
Sounds scary right?
It should, it's F@$#ing dangerous.
Trapping even an ounce of water within a molten metal could end with destructive drops of molten alumimum flying everywhere, searing flesh and burning everything they touch! (This is what pfred2 is describing)
OMG PANIC!
However, a can with a few drops of water on it will cause (if anything) very tiny, very harmless, bubbles. (such as jtobako describes)
OMG PANI-whoa hold on a sec....those are actually kinda cute.
In fact, even if (IF!) there was an extraordinarily large bubble that shot a little aluminum towards you, that's not as dangerous as everyone seems to think. If you wear the proper safety gear (lots of thick leather and some form of face protection) the drops will not burn through to your skin, but will stick to your clothes instanty hardening into a cool little dot of aluminum
I take precautions against trapping water by cutting up my cans. Having open cans allows me to wash away all the incredibly sugary soda (a breeding ground for various fungi & bacteria) and not trap water in the cans. I can store them however I want and all the water evaporates away.
As I said in my previous comment, I plan on making some form of instructable that illustrates molten aluminum safety, which will of course show some molten metal explosions and how to prevent them. It might take me awhile to get around to it because I have a very busy summer, but I assure you it will get done.
If you have any requests or suggestions regarding what I include in the instructable please respond.
