Step 12Assemble, Adjust and Enjoy!
a. Start with the base flange, this time using the flat and lock washers
b. Slip the PVC Conduit over the pipes as you assemble
c. Tighten the pipes until they are snug against the PVC and aligned in their proper positions. The lower pipe should be centered over the hole in the base.
d. Thread on the top assembly and align it
e. Once satisfied with the alignment, tighten down the set screws
f. If necessary, adjust the bend angle of the hinge tab with a large Crescent type wrench so that the spring is perpendicular to the tab. Do this if the spring is not stable and allows the top to collapse when downward pressure is put on it.
g. Stand back and admire your work!
comment
Add Comment
Add Comment
