The display may work as a stand alone device driven by a microcontroller (Arduino stuff) or may be driven by a PC / laptop (interfaced by some discrete digital logic).
Design constrains / requests:
-to be big enough to be readable from 20-30 meters
-to be bright enough to be visible / readable in sun light
-to use energy efficient light emitting devices (bulbs, LEDs) / (low electrical power consumption)
-to use feasible and long lasting light emitting devices
-to withstand to harsh environment (some contests may be during fall, winter times, during rain, strong sun)
-to be light and sturdy in the same time (it has to be carried from point A to B)
-to have a reasonable size in order to fit on regular vans or on the roof of a car - it must be carried from a location to another
-to show hours, minutes, seconds and miliseconds (hundreds of a second) as a chronometer
-to show as well the temperature (negative and positive), local time and current date
-to separate the pair of digits by ":" - 2 separation dots
-to allow multiplexing of segments and digits and separate control of minus and separation points
-to have a reasonable cost
-to involve a reasonable amount of work
-to look nice
Based on these requirements, my choice was to use red LED strips for 12Vdc (these are comming in reels and you can cut the desired length), polycarbonate panels and a wooden frame. All the LEDs were connected using cheap network cable (8 wires inside, full copper).
The LEDs were connected to form 7 segments per digit and 8 digits (6 digits are big size and 2 digits are small size (these 2 digits are used to display hundreds of a second)). Also in front of the first digit is a big minus sign (for negative temperatures) and between each pair of digits are 2 separation dots.
Tools needed:
-cutter
-scissor
-wire cutter (wire desoldering tool is nice to have)
-soldering iron and related tools for electronic parts soldering
-drilling machine and drill bits
-wood saw (any, you need to cut wood a few times)
-brush to paint
-silicone pistol
-hot glue pistol
-printer to print A4 sheets
-others (?!)
Materials needed:
-red LEDs - 2 reels at 12Vdc with adhesive back tape, one reel is 5 meters or 300 red LEDs
-polycarbonate panels for constructions - roofs (transparent preferred - mine was on sale and it is light brown)
-wood to build the wooden frame
-wood paint
-network cable 20 meters (UTP cable)
-sanitary silicone 2 tubes
-hot glue sticks 4-5 sticks
-thick paper pattern to align the segments and the digits - 6-8 A4 sheets (2 types - small and big)
-transparent packing tape
-plastic crosses for ceramic tiles 100 pieces pack should be more then enough (the thickness matter, so 3-4mm is ok or use 2, each one on top of the other)
-others (?!)
Unfortunately at the moment of building this huge 7 segments 8 digits LED display I didn't take too many pictures, I had no intention to share that experiment, but now I realized that it may be interesting for others as well.
Due to this reason, the instructable did not documented with pictures each detail, some of the existing pictures are not the best or the most explicit, so you need to understand my English or to imagine another way of performing the same operation. Or simply to ask where you don't understand :) !
Let's start!
2012/12/10 Edit: LED stripes -> LED strips - see comments for more explanations
Step 1: Creating the 7 digits display paper pattern
The LEDs are coming in reels and are powered by 12Vdc. I can cut the desired length of LED stripe, but I had to follow a few rules:
-minimum LED stripe consist of 3 LEDs, this is 5 cm (~2 inches) minimum length
-the LED segment must be multiple of 5 cm
-each LED segment must have 2 power wires at one end (+12Vdc and GND)
-LED segments of a 7 segment digit have a specific angle - see a small 7 segments LED display to understand what I'm talking about
-LED digits have a certain clearance between them
-the points between each pair of digits must be made from 2 small strips in parallel (5cm strips)
So here are the choices: the big 7 segments display used 3 LED strips of 5cm LED (3 LEDs per stripe), the small one uses 2 LED strips x 5cm.
In order to make the 7 segments digit paper pattern, I downloaded from the internet a 7 segment display image and I scale it up in order to fit the 15cm and 10cm LED segment size lengths. Since I used 2 types of digits (small and big), 2 sizes of paper pattern were created.
In the end, the big digit is 33cm tall by 22cm wide and the small digit is 23cm tall by 16cm wide.
The paper used was A4 size, 4 sheets put together using packing tape; these were printed at home using my personal printer. After that, some cuts/holes were cut at each end of each segment on the paper patterns in order to be able to mark the points where to fit the LED strips - assembly guides.
Step 2: Trimming the polycarbonate and marking the LED segment's positions
The operation was performed using the cutter, I cut 2 identical pieces, 50cm by 200cm. Beware which side is the face you want to use for inside and for outside. Peel the protective sheet from the polycarbonate panel now on the part used as inside.
I used the paper pattern to mark the points on one piece I cut before - put the pattern on the polycarbonate sheet and mark the points using a permanent marker (like Sharpie or similar).
I double checked that I marked correctly and things are looking like a pattern for a huge 7 segments LED display - 8 displays.
Step 3: LED strips creation
For a big LED segment I cut at every 15 cm (3 groups of 3 LEDs or 3 lengths of 5cm), for the small segment, I cut at every 10 cm (2 groups of 3 LEDs or 2 lengths of 5cm).
The big minus sign I cut it from 3 groups and the small points between each pair of 7 segments display I cut from 2 x 3cm LED stripe.
Step 4: Soldering the power wires to each LED stripe
I cut equal wire lengths and I stripped the ends of each wire length to prepare them for soldering.
For each LED stripe I cut in the previous step, 2 wires were soldered: +12Vdc and GND. The LED separation points (the ones between each pair of digits) were soldered in a little bit different way since were needed 2 x 5cm strips in parallel. After that step,
I had a lot of LED strips wired at one end (but no pictures taken at that moment, sorry).
Step 5: LED strips assembly on the polycarbonate panel
In the previous steps I marked the polycarbonate panel to know where to glue the strips, so I glued all the strips on the polycarbonate panel according to the markings previously done.
Step 6: LED segments wiring and soldering
-a segment bus - 7 lines for segments
-a digit bus - 8 lines for digits
-a separation dots . minus sign bus - 2 lines for the minus sign and 6 lines for the separation points
-----------total 23 lines in 3 buses
That means to use 3 network cables (each one has 8 wires, 3 x 8 = 24 wires). I took 3 meters of cable and I stripped the network cable grey insulation on about 2 meters of the total length, I kept some insulation on the end which goes outside the polycarbonate panel. Using hot glue, the bus was assembled on the polycarbonate panel. I created this color schematic in order to make an easy assembly of the LED segments to the bus (soldering the wires).
Step 7: LED strips wiring to the bus
After each solder joint, I checked if the LED was turning on and if the current was similar like for a reference LED stripe (to make sure that the solder joint is well done - avoid cold solder joints). (at this step I took no picture at that moment, sorry)
Step 8: Hot glueing the wires and the ceramic tile spacers on the polycarbonate panels
The plastic spacers for ceramic tiles are used to ensure some clearance between the 2 polycarbonate panels - in the end it is like a sandwich: polycarbonate on sides and LEDs in the middle. I don't want that the top polycarbonate panel to touch the LEDs. This was done using hot glue and for each point 2 spacers were glued one on top of the other.
I checked one more time that the LED strips can lit using the bus wires. It is important to check this because on the next step I put the other polycarbonate panel on top of the LEDs and I sealed the assembly. (again, no images for this step)
Step 9: Sealing the polycarbonate sandwich
The silicone excess was removed and spread on the sides of the sandwich. A secondary sealing contour was applied on the exterior and was spread as well on the entire edge of the panels.
If you look from the side, the polycarbonate panel has its profile like small pipes, I recommend to seal them, if water gets in, may affect the transparency. Leave the silicone to cure for about 24 hours. After that, I cut the corners of the panels at 45 degrees.
Step 10: Making the wooden frame
The wooden frame is 206,5cm by 55cm and has an "L" profile in order to fit the polycarbonate sandwich. Also I put a threaded metal rod M4 on the middle of the frame in order to make it sturdy (wood is elastic and the sandwich may fall out of the wooden frame).
There you can see the protection foil on the polycarbonate sheet, that part is on the back of the display and is not directly visible. I tried to peel it off, I cleaned the front face visible to the audience, but was hard and in the end I gave up on the other face.
Step 11: Assembling the polycarbonate panels and the wooden frame
Also I used some hooks and some small carabiners in order to have some hanging points (the display has to be hanged on a higher point for visibility).
Here is the final result of the huge 7 segments 8 digits LED display panel:
Some facts:
-Total number of red LEDs: 525 pieces
-8 digits, 7 segments red LED
-Total length of LED stripe: 875 cm (one reel of 5 meters + 3,75 meters from a secondary reel)
-Total current when all LEDs are on (at 12Vdc): ~2 amps
-Size of the finished LED panel display: L 206,5cm x h 55cm x t 6cm
-Weight of the finished LED panel display: 9 kg
Visit Our Store »
Go Pro Today »
Not sure what I would use it for, but the LED strips are a great way to overcome the huge wiring issue that accompanies a Seven Segment Display.
How about a Debt Clock. Don't know how you would drive the display but it would turn heads. 14 digits unless you wanted to enumerate cents too. Then you would need 16 digits.
Great Job!
Driving the LEDs is pretty straight forward: for this setup (7 segments and 8 digits) I have a bus of 7 lines for each segment and another bus of 8 lines for each digit, each of these lines is controlled by a microcontroller pin (15 pins in total) and using multiplexing, the result is displayed.
Due to the fact that the LEDs are powered at 12Vdc, I cannot drive them directly from the microcontroller pin, so I need to drive them through an external transistor. Basically I need to separate the positive supply from the anode of the LED strip and the ground from the cathode of the LED strip, this is done using a P channel MOSFET and an N channel MOSFET. I tested on a breadboard the configuration and it worked - check the attached schematic, if I apply logical 1 (5Vdc) on both transistor inputs, the LED strip is glowing, if one command is 0 logic (0Vdc or ground), the LED strip is off. My digits bus is the anode (+12Vdc), my segments bus is the cathode (ground or GND / 0Vdc).
Nice One!
I think what plan back Rounding times If that's annual New year 2013 for completion time walking 10,9,8,7,6,5,4,3,2,1, 12 hours, hurray New year
Therefore I want new building with large plate members gezoekte lighting.
I would like to build something, I know not on Electronic print
make?
I hope that with your answer?
With friendly greetings; Corrie Pover
You can build such a device but you need an electronic board to command the LEDs to display the message. Search the internet for a count down timer with 7 segments digits and you can start from there.
Hurray :)
-LEDs - 2 reels - 60$ both
-polycarb sheet - 20$
-network cable - 5$
-hot melt - 3$
-sanitary silicon - 5$
-screws, plastic crosses, cable ties - 3$
-wooden frame - this is hard to estimate, I think it would cost me around 30$ (someone did it for me and didn't charge me)
-some paint for the wooden frame, hooks and carabiners - 10$
*these prices are here, you may have cheaper stuff in your country.
Did I miss something? If not, ~140$ (136$ to be more precise), so maybe you can say a maximum 150$ for the display panel itself. Of course you can make it cheaper, but even 150$ looks cheap for a 6ft display.
This display is useless without some electronics behind, but that is another story I'm working on (a microcontroller board with buttons, LCD display and power MOSFETs for driving the LEDs).
Lots of uses for those LED strips.
Going to look at the polycarb as the base structure for a solar panel after seeing this.
But....
Am I the only one reading stripes, as in what you get in toothpaste?
Strips right?
Regarding the stripes / strips, sorry, I cannot help you :) aren't the same thing? (English is not my native language). Thanks!
I love using those strip lights when I can - they make it so much easier to do!
A stripe is usually a pattern, not a tangible thing. A zebra has black and white stripes, and you can paint striped lines. The American flag is composed of 13 stripes.
A strip is a description of an object (tangible or not) that is long and slender. Airplanes take off and land on an airstrip. The famous road with casinos in Las Vegas, Nevada, is called "The Strip." The LEDs in this project come attached to an adhesive strip.
I know English can be a confusing language, and there are many variants: British, American, Australian, etc. The word strip can be used to describe a single stripe, but the opposite is generally not true.
