loading
Step 2: Laser Modulation
Now we need to grab those headphones and take them apart. You should have one speaker attached to a cord that you can plug into an iPod or a stereo. Plug it in and start playing music to make sure it all works. We want to be able to glue the little circular mirror on the speaker itself.
Grab your glue gun, dab a bit of glue on the back of the mirror, and quickly and carefully place it right in the middle of the speaker, ensuring it remains flat.
It could have been made easier. It is just a laser pointing towards a mirror attached to the speaker. Anyways the idea is great.
DUDE!!! That is so cool! Too bad people in the US can't build it... They made it illegal to ship out lasers more than 5mW... Jerks. They always ruin my fun !
They changed that to 10 mW. And building your own is not illegal. You can make them out of very powerful LEDs if you know where to find the parts.
Or swipe one from a DVD burner. They're sometimes upwards of 100 mw
I would advise against that, only because those can be powerful enough to light matches, burn through cardboard short circuit street lamps, etc. But it should be safe if you diffuse it enough. I'm not a laser expert though, so I may be wrong.
Well, yeah, that's what makes them fun!<br><br>But anyways, for this application you'd probably want to use a big lens, and spreqad out the signal. That way, you could get the brightness of a 10mw point on a much larger surface.
If such lasers were illegal to own, my Epilog engraver would either be illegal, or nonfunctional.
It's a rather odd situation, seemingly limited to laser pointers and consumer level retail lasers. Here's a link:<br><br>http://www.fda.gov/Radiation-EmittingProducts/RadiationEmittingProductsandProcedures/HomeBusinessandEntertainment/LaserProductsandInstruments/ucm116373.htm<br><br>&quot;Does FDA have a mandatory limit on the power emitted by laser pointers?<br><br>Yes. Laser products promoted for pointing and demonstration purposes are limited to hazard Class IIIa by FDA regulation.<br>21 CFR 1040.11(b) and 1040.11(c), limit surveying, leveling, and alignment, and demonstration laser products to Class IIIa. This means that pointers are limited to 5 milliwatts output power in the visible wavelength range from 400 to 710 nanometers. There are also limits for any invisible wavelengths and for short pulses. Pointers may not exceed the accessible emission limits of CDRH Class IIIa or IEC1 Class 3R.&quot;
yes, but that just applies to lasers promoted for pointing or demonstration purposes. It says nothing about lasers *not* promoted for pointing or demonstrations. just buy one promoted for science, lab work, or disc reading and use that. Also, I've seen lasers for sale that are 20 to 1000mW available in the US... seems odd, are you sure that's right?
The one problem is that it won't be very loud... It could be modded with a larger speaker... Hmmm...
15'' sub wooffer would be really good for this with a huge amp and 32 speakers around the place turned up full blast. <br>that would be so cool
DYLEGO - The internal speaker is just to create vibrations for the laser itself. It doesn't really make all that much sound. I use a splitter cable from my audio source - one cable goes to my speakers, the other to the laser show.
That makes sense... I guess I should read the instructable all the way through next time, huh? DYLEGO
then does that mean that dvd burners, hd-dvd players, blu-ray players, and laser cutters are all illegal here in the US?
no dvd/cd players and burners are in a different class to hand held pointers. and a good 8x dvd burner will have a laser diode around 250mw
I have a laser pointer that can shoot across my 2 acre long yard! it's a laser level so I guess it has to be powerful. Only thing is I cant get the true laser pointer out of the thing. It's a ft and a half long so I wouldn't be able to do much with it without taking out the laser.
Maybe I could mod a normal laser pointer...
you cant change red ones only green ones. the green ones are restricted, where the red ones are maxed out. google it.
or just buy a 20x dvd burner or an obsolete hd-dvd player and use those lasers. there are more than a few instructables here that tell you how to harvest and use those lasers that are capable of 100+ mW. Both you can usually get for under $50. heh. heh.
I remember watching a laser light show, and there is a way to make a cirlce with the light. You send the laser against a mirror that is angled, and on a rotating shaft so it wobbles in a circular fashion. Sending a laser light beam against it will give you a circle, or if you change the angle, an ellipse.
Yeah, I did that with my green laser by shining it off of an angled lego at the top of my eiffel tower statue. But it only made a parabola, not a full circle. It's very interesting to look at.
when i get some lazorz and mirrors i will make a huge lightshow with the subwoofers i have
Just remember, do not look directly into the laser with your remaining functional eye.
cool cool pretty nice good work can you make a video so I can see it in action thanks
Does it matter how big the headphone are?<br />
yeah it matters, but the dancing happens anyway, bigger speaker gives you bigger angle of move.
how much power does the AC/DC adapter provide?&lt;br /&gt; &lt;div id=&quot;refHTML&quot;&gt; &lt;/div&gt;<br/>
Awesome! great instructable!
Nifty. I think we've all thought of this without ever doing it so well. Moar pichsus though!
About This Instructable
52,834views
108favorites
License:
More by gmilburn:Build a laser show that moves to your favourite music
Add instructable to:
