3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a long-wheelbase low racer recumbent bicycle
Step 10Remote steering handlebars
Here is where, with a little ingenuity, you could eliminate the need for a second donor bike. If you feel like fabricating a simple steering assembly, go for it and please post photos. I had a steering tube already cut out and ground from another project and decided to use it to save time. I will assume that you are using a donor steering tube.
This is one of those parts that will need to be adjusted to your body and preferences. I sat on the bike with the assembled steering tube with handlebars attached and held my arms in a comfy position. You will likely need someone to help you with this.
Once you figure out where you want the steering tube, measure and cut a length of 1" conduit, grind to fit the steering tube and main tube, and weld to the main tube. I have had this tube face both forward and back. I prefer forward, but whatever seems to work best should be fine. Weld the steering tube at approximately the same angle as the front steering tube. Get it as close as you can; it will help with the feel when you are turning to have everything at the same angle.
Cut the forks from your second donor bike and weld on a tab the same size as the front tab. It's easier to match everything up if the the forks are built similarly. The distance from the center point of the steering pivot to the pivot of the tie rod should be equal. Mount the other tie rod end here.
Re-install the bottom bracket, cranks, and pedals (if they aren't already there). Install your remote handle bars and fiddle with them so you don't hit your knees when you pedal. This will take some trial and error.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:homba
