Step 3Bend the seat stays
Bend the seat stays down with the rear wheel and brakes still on. Don't bend it so far that the brake bracket will rub on the wheel or that the brake pads can't be adjusted to hit the rim. It would be nice to cut some sort of form for this step so that everything is bent evenly. I didn't do that. Instead, I used small pieces of 2x4 lumber to set where I wanted the bend and tweaked it by hand - kind of an ad-hoc form I guess. It worked well enough, but if you look real close, the seat stays don't have exactly the same arc. Next time I'd make a form out of plywood to bend them over.
I tried to have the top of the seat stays be parallel to the ground when the recently cut chain stays are around 6" off the ground.
Add Comment
