Introduction: Build a Low Cost, Scrolling LED Display for Your Arduino Microprocessor.
Picture of Build a Low Cost, Scrolling LED Display for Your Arduino Microprocessor.
The Arduino Microcomputer system is an affordable platform to learn about microprocessing and programming. Yet Arduinos can be used for instrumentation, robotics and many automated processes.
In this series we will go through some of the basics of software and hardware interfacing and I will show you how to build this simple but effective LED matrix display system.
All you need for the LED display is 30 LEDs of any color, 6 x 390-ohm resistors, 5 x 1N4148 (or 1N914) low power diodes, some thin wires and a small piece of perfboard to hold everything. Total cost, maybe $5.00.
Step 1: Arduino?
Picture of Arduino?
Oh yes, you DO need an Arduino processor, which can cost from $30 to $50. Look up http://arduino.cc , BoArduino and Freeduino and pick the one that appeals to you. Software-wise, they are all compatible and virtually interchangeable.
One major consideration is the 'input interface': the means to feed programming and data to your micro. If you are just starting out, I strongly suggest one that uses the USB. With it, not only can you talk to your Micro with your regular computer (WIndows, Mac or Linux), it can, within limits, power the micro as well.
One of the newest member of the Arduino family is the 'Nano', shown here trying to say "HELLO" on the LED panel. It's got everything on a 2" x 1" (5 x 3 cm) package, and has its own USB connection.
The Arduino is an entire developmental system that can interface to the real world: lights, sound, motion and can be connected to sensors that can 'feel' them.
Best of all, the Arduino Foundation is 'open' - all its software is free, and you are encouraged to share and develop your own.
Step 2: The LED Matrix Panel, or LMP
Picture of The LED Matrix Panel, or LMP
The LMP is 6-columns across by 5-rows down, totalling 30 LEDs. The size is chosen because this size Matrix is the smallest that can be used to display the English alphabet, and wide enough to be used for scrolling messages. It is also the largest matrix that can be built using ONLY the available output pins on 1 side of the Arduino package.
Technically: the columns are controlled by digital pins 2 through 7 (PORTD), while the rows use pins 8 through 12. This form of matrix addressing means that only ONE LED can be lit at any time, but allows us to control 30 LEDs individually without needing expensive multiplexing and addressing hardware.
Before we get to the actual construction, take a look at this youtube video to see some of the display functions that we can use the panel for.
http://www.youtube.com/watch?v=lCBOTupvXIY
Step 3: Begin Assembly
Picture of Begin Assembly
Although it is possible (and tempting) to use LEDs of different colors, it is recommended you stay with ones with similar voltages: reds, ambers, and greens are in the 2v range, while blue, purple and whites are 3v or more. This avoids the problem with grossly varying brightnesses.
Begin with a 2" x 3" (5cm x 7.5cm) piece of perforated circuit board (perfboard) and arrange the LEDs as shown. Align the SHORTER (-) leads towards the top of the board, which I had marked with an arrow.
Making sure the LED is flat against the surface of the board, solder the negative lead ONLY. Do that for all 30 LEDs.
Now fold the longer (+) lead of each LED over to touch its neighbor and solder them together. You should have the + leads of 6 LEDs connected this way, all pointing to the right.
Step 4: Installing the Diodes
Picture of Installing the Diodes
You will be fashioning pins to be inserted directly into the MPC board. Make VERY sure that you are able to attach them directly into female headers (sockets) labelled D12 to D8 on the microcomputer board. The larger MPC boards have a gap between pins D7 and D8; make the necessary adjustments to your installation!
Bend the leads of 5 x 1N4148 diodes to come out the the space at the bottom, with the cathode (-), banded side pointing towards the LEDs. The anode (+) end will attach to the micro's pins. If you find the wires too flimsy as a connector, reinforce them with a heavier wire.
Attach the cathode ends by thin wires to the LED's anode (row) ends: pin 12, row 1; pin 11, row 2; pin 10, row 3; pin 09, row 4 & pin 08, row 5.
Step 5: Add the 2nd Layer + Column Resistors
Picture of Add the 2nd Layer + Column Resistors
To isolate the leads of the LEDs, cut a smaller piece of perboard to go over the connections you have already made. Do not make it any bigger than necessary.
Again, match up the pin connectors of the microprocessor with your matrix. Some microcomputer boards have an extra space between pins 7 and 8 and you must allow for that.
Join all the negative (cathode) leads of the LEDs vertically as shown below. Install the 6 resistors to match up with pin 2 (at the end) of the microprocessor with column 6. The other connections are pin 3, col 5; pin 4 col 4; pin 5 col 3; pin 6 col 2 and pin 7 col 1.
After you verified all your connections and trimmed off all the ends, your LMP is complete!
A quick test is to connect a 3 to 6volt source (like 3 or 4 AA batteries) and touch the + to a ROW (pins 8-12) and the - to a COLUMN (pins 2-7), ONE and only one LED should light up.
A word on the choice of resistor. The value (390-ohm) selected is for 8mA to go through the LEDs. This may seem low but the efficiency of the driving program make it unnecessary to use higher power. If absolutely needed, the resistor can be as low as 220-ohms.
Now, if everything looks OK, plug in your LMP, making sure (again) that pins 2 - 12 match up with the sockets on the Arduino. Then you can paste the following program in and see your efforts light up!
Continued in Part 2
Step 6: A Test Sketch
Picture of A Test Sketch
/* LMP Test
  • Copyright (c) 2009 qs@quantsuff.com
  • Scanning horizontal and vertical pixels
  • LED Matrix row:1-5; col:1-6
  • Map PORTB == D8:D12 pin[row+7] : +v
  • PORTD == D2:D7 pin[8-col] ; Gnd
  • Our output: col::D2:D7 -ve (LOW) while row::D8:D13 +ve
int delayTime= 80; // 1mS increments before next LED
// change from 1-100 and see what happens
int delayStep;
int ledPin, col, row ;
void setup() // run once, when the sketch starts
for (ledPin=2; ledPin<=12; ledPin++) // Standard setup for LMP
{ pinMode(ledPin, OUTPUT); // sets the digital pin as output
digitalWrite(ledPin,(ledPin<=7)) ; // and sets all OFF
void loop() // run over and over again
/* Map PORTB == D8:D13
  • PORTD == D0:D7
  • Our output: col::D7:D2
  • (8-col) -ve (LOW)
  • while row::D8:D13 +ve
  • (row+7) +ve (HIGH)
for (row=1; row<=5; row++) { // Vertical: left to right
digitalWrite(row+7,HIGH); // Enable entire ROW
for (col=1; col<=6; col++) { // then one pixel per col
digitalWrite(8-col,LOW); // gets turned on
delay(delayTime); // for a moment
digitalWrite(8-col,HIGH); // then OFF
} // before next one
digitalWrite(row+7, LOW); // We're done with this row
for (col=6; col>=1; col--) { // Going UP right to left
digitalWrite(8-col,LOW); // A shortcut: leave col enabled
for (row=5; row>=1; row--) {
digitalWrite(row+7,HIGH); // Turn 1 pixel on
delay(delayTime); // Wait a moment
digitalWrite(row+7,LOW); // then off...
digitalWrite(8-col,HIGH); // finished with this column
qs made it! (author)2016-09-21
Here is the image of the LED board shown in Step 5 with a bit more description. The resistors are hidden by Layer 2 but the green lines show where they connect.
LeskoIam (author)2011-08-30
Hello. I just noticed that your pictures don't match the description. In a picture row 1 connects to arduino pin 8, row 2 connects to arduino pin 9 and so on. In description row 1 connects to arduino pin 12,.... So I would just like to know which one is correct? Keep up the good work!
the seaker (author)2011-01-28
hello nice 'ible! do you by any chance have code for the scrolling text? that would be wonderful
Berserk87 (author)2009-04-04
the fact that you need to already own a $30-$50 device pretty much ruins the "low cost" part. but good guide for those that have an ardunio already.
zaketus (author)Berserk872009-04-04
One can make Arduino at home, for lets say $10-$15. And when student (or someone else with really tight budget) gets Arduino for $30-$50, it's good to be able to get cheap accessories for it. This is one of those "why I didn't thought that" -moments. Great instructable!
shinmai (author)zaketus2009-11-26
Actually, I just re-ordered the BOM for a really barebones arduino-compatible I build on perfboard, and the final cost per board is only about $7. Granted it lacks built in usb (I make versions with RS232 for a few bucks more) and a 5v voltage regulator would add a little to the price as well. That's besides the point, which is that getting a device to run this display isn't something that will require a hefty hit on the wallet. If you've got cash to burn, you should concider some of the nicer boards like the official Arduino or it's clones. They definitely add a whole new degree of usability and comfort.
On a completely different subject: With fairly minor modifications (wiring and orientation of the leds) the same display could be charlieplexed, allowing for it to be run from a mere 5 pins (unless my math is off). Charlieplexing can be daunting when beginning electronics(who I'm assuming this instructable is mostly aimed for), but with a bit of planning and good notes of the wiring it can be a great way to multiplex leds for projects just like this.
Anyways, great instructable. Really informative and detailed and easy to follow. And A+ on the pictures, they're all well focused and framed to show the "good bits" :)
ajam123 (author)2009-09-17
So went and build this matrix and everything seems to work. But I did it without the diodes. I just soldered a resistor on every row (+) and the scanning works great. Also I tried the VU meter code from part2 and that too seems to work. So my question of course is... What's with the diodes? O and thank for the tutorial ofcourse, it's my first "big" arduino project.
qs (author)ajam1232009-09-18
The diodes are there because the uP will operate the LEDs at their maximum reverse limit of 5-volts, and COULD damage cheaper LEDs.
ajam123 (author)qs2009-09-19
Ah I see. Well I don't think I used "cheaper" LEDs but we'll see how long it holds out. Thank you and I'll be looking forward to the scrolling text instructable.
ajam123 (author)2009-09-18
O and another thing. Have you posted more code elsewhere besides the "vu-meter" and test lines? I absolutely NEED more code for this. Thanks again!
I'm in the process of putting together another 'ible on scrolling text - should be along as soon as I have the time. qs
xeoware (author)2009-09-02
I´m trying to put text, but i´m new on programming, do you have a sketch with the scrolling text?
jimmy321 (author)2009-05-19
If we upgraded the project, it could be a small commercial system for small businesses. For example, we can use FPGA to replace 4000 logics to drive more LEDs, use a microcontroller (like AVR or PIC16/18) and an SD card slot to allow customer to run custom patterns in the LED panel.
Electo-Matic
qs (author)jimmy3212009-05-19
The LMP can certainly be ramped up to virtually any scale.
I designed this to be a low-cost project (under $10 in parts) that anyone with an Arduino and some electronics experience can build, and many of the special effect features are already designed in. You can see some from this demo video here:
matstermind (author)qs2009-05-19
what are those blue lights moving up the screen?
qs (author)matstermind2009-05-19
They're not really there - probably just refraction from the lens of the video.
ok
frenetic (author)qs2009-05-19
This is my favorite:
The MUSICATOR.
policemedic13 (author)2009-05-11
Sorry but I'm new to programming, do you have a sketch of the actual text scroll code that I could learn from.
dunnos (author)2009-05-04
if I build something, ( like my current project arduino POV) i just build the hardware and then try and program the software. usually fun...
qs (author)2009-04-28
You didn't say if you are direct addressing the 5x7 or through some sort of multiplexing or latch, it's hard to decide what information may be helpful. The first thing you should do is get data sheets from the people who sold you the parts. Then at least you know what questions to ask! Since I designed this circuit with scrolling in mind, the programming is quite simple, but may not apply to what your display requires.
About This Instructable
63,629views
80favorites
License:
More by qs:Joule Thief LED circuitsA Triple Channel Musicator - the TriM...Musicator Jr - Mk 2
Add instructable to:
