loading
Picture of Build a low tech CFV stove
The most popular alcohol fuel based DIY backpacking and camping stoves utilize aluminum beverage cans to provide a laminar or pressurized vapor fed flame. However, they have limited fuel storage and thermal generating capacity, durability and adaptability. Most require an extraneous pot stand or holder and have additional construction, storage, startup and usage needs.
While high tech CFV (Capillary Force Vaporizer) burners represent an advance in technology they are unfortunately too high tech to be offered to DIY stove builders as a solution.
Fortunately a low tech CFV stove can overcome the limitations and disadvantages of both the high tech CFV stove and the alcohol fueled beverage can stove by using low temperature evaporation of alcohol fuel fed to the flame at the perimeter by an encompassing pad wick made of almost any absorbent material. In fact, it might (except for the flame) be mor properly called a Capillary Force Evaporator stove.
While being easy to construct and simple to use it can be made to meet virtually any fuel storage, thermal generation capacity or durability requirement in addition to making replenishment of fuel during operation possible and startup hassles a thing of the past.
A basic low tech DIY CFV stove can be built quickly in an emergency to meet most any fuel or thermal need but with more time and materials it can be adapted and built to accommodate virtually any backpacking, camping or other need.
I think what you did here was great, but over explained. Gotta keep it simple for simple folks.
Michael_oz3 years ago
Just a word on Asbestos: Don't do it!
"The inhalation of asbestos fibers can cause serious illnesses, including malignant lung cancer, mesothelioma (a formerly rare cancer strongly associated with exposure to amphibole asbestos), and asbestosis (a type of pneumoconiosis)." (Wikipedia)
KittyF4 years ago
I'm confused too. Are you lighting the edge of your metal paper towel sandwich? what does the wick do, do you light that too? or is it just serving as a wick to bring more fuel into the paper towels?
What purpose does the screen serve? (just gratuitous curiosity, that one.)
And last, but not least, why turn you tuna can or any can upside down? why not just put a small reservoir of alcohol in the bottom of the can and leave it right side up?
sorry for all the questions, but I'd like to understand the concept a bit better. thanks, Kitty
Wasagi5 years ago
Nice!!!! Could you use two tops of cans to replace the aluminum sheets in the stove?
Hi Please do a video, I am confused , the video would help. Is what you have described, basically a wick that you put in an open can of alcohol? the center wick, is that to go up to the screen paper towel sandwich? I do not flame only ask, I live near the ocean so I figure one day I may need stuff like this with the family, all the stuff I have read came down to , thus far, no matter the shape the type, they all work about the same. BUT, that doesn't mean some person can't make one that works easier and looks nicer and is a lot safer, (more stable). I have box full of svea brass stoves and a few pop can units I made. I Would like to make yours as well. Thank you very much for posting this one it looks rather nice and please do a video as you make one. spark master
mattias law6 years ago
sorry but im not quite clear here, too many calculations and stuff. but is this something that can be reused and see for the picture with the string poking out the top is that for putting the fuel in or for lighting it. this could be very good because i need something which is very small and compact
sypher6 years ago
I am sorry, but this looks far more complicated than a Penny Stove, in construction and function. Seem a lot like a roll of toilet paper in a paint can soaked in alcohol, I think those a called ghetto stoves. Interesting idea, and application. You could make this thing thicker? It would hold more fuel. Something else I just thought of, the tip of a flame is the hottest point, I noticed that the flame is half way up the side of the make shift pot.
seudo4117 years ago
Great instructable, would it be possible to use a metal jar lid and another piece of circular metal to make a larger reservoir.
watermelon (author)  seudo4117 years ago
Also be sure to experiment away from anything that might catch fire and only with adult supervision. Too much alcohol, i.e., too large of a reservoir or a disfunctional design can be much harder to extinguish in the event of a mishap.
Its also good advice to avoid panicking in the event of a mishap.. Straight up alcohol fires are easy to extinguish, but can spread FAST! If something happens, take a step back, pick up something you've decided already will smother fires well, and calmly put out all visible flames.. The last thing you need is to spill more alcohol in a rush, assuming you were stupid enough to ignite while the main bottle wasn't secured.. After you get all visible flames out, its a good idea to darken the area id possible to detect rogue flames.. On top of that, start small.. You can usually scale this stuff up easy.. A 5mL test rig will burn more than enough, and is 'pretty' harmless..
The problem with any reservoir is keeping it thermally isolated. I've used a smaller metal lid to raise the pot above the absorbent material by about a quarter inch which seems to have reduced thermal transfer from the pot to the absorbent material when it heats up and the water starts to boil. You could possibly use a metal lid with a deeper lip to hold additional absorbent material and then use a smaller metal lid to separate the absorbent material and the pot but if it does not work and you have too much fuel watch out! The idea here, however, is to try and match the capacity of the reservoir with the amount of water you need to boil. For instance I can boil about 20 fl oz of water in a Heineken 24 fl oz aluminum can with the top cut out and keep it going to hard boil three large eggs with 1 fl oz to 2 fl oz of Isopropyl by using an upside down tuna can with a depressed bottom filled with absorbent material. Adjusting the reservoir capacity to match the maximum job you have in mind will then allow you to do other jobs using less fuel. For instance, I use the same set up to boil water for tea with only 3/4 fl oz which results in hot tea but an end to the flame as soon as the water is boiling. Unlike my electric pot which does not have a timer I can set it up to make tea most anywhere, light it, go away and do something else and return to find no flame and a waiting hot pot of tea.
We had a really old really insanse liquid fuel jet lighter that worked like this, a wick flame heated a special nozzle that went in to the fuel sponge... after a while it fired spurts of fuel and eventually stabilized to be blasting a massive flame out the side, we called it the crazy professor stove... once the jet self sustained it didn't burn fuel at the wick much so it became efficient and very fun... Same principles in very different actions... I wonder how big I could get this principle to work on... soon come's up with completely ridiculous jet engine idea
watermelon (author)  killerjackalope7 years ago
Yeah, I was thinking jet engine for a project too, after putting too much fuel in a beverage can pressure stove the jet vapors reaching 3 or 4 inches after the liquid stopped spurting through the jets. I thought it was going to blow. I was thinking maybe a jet turbine powered generator project as well after doing one for a small ram jet type engine. I was just looking for info or an instructable on how to balance turbine blades, like maybe if they were tires? If you want to collaborate that would be cool!
Hey I'm working on a new stove jet plan based on this, I'll see how it goes, if it's good and had the effect I have planned it'll be an interesting low tech way of delivering a high power flame to stuff, it should also work horizontally...
I'm looking forward to seeing it.
Ooh I never saw this reply, if you have a good plan aswell It might be interesting, unless you'd rather have an arms race instead, I already predicted the instructables war so the arms race is the next logical step...
One of these...?
Hmmm an insane trans-continental collaboration of jet engining... That's very similar to the one's we had a few of but not as good or rare, we ended up with four or five of the original design ones, you can solder easily with them as they're designed around lighting a pipe... Have a look at one and see if you can give me an estimate ofr the size of the jet hole nozzle... It would really be appreciated as I'm going to instructables on make a petrol lighter, a jet lighter and maybe just a normal gas lighter...
Nice instructible. Out of interest, if you made a longer wick and had the tuna can open-end up (with fuel in the bottom), would the stove draw its fuel up the wick?
