3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a music studio in an apartment building
There are whole books written on this subject, and also a few other instructables -- but since each project is unique it's helpful, when you're planning your own studio, to see as many different solutions as possible.
You cannot build a sound studio without first understanding some theory: rik_akashian discussed this issue. The most important part to understand is that sound proofing (blocking the sound, so others don't hear you and you don't hear them) is very different from sound treatment (making your room sound good). Since this studio was built for mixing sound and music for film and TV in a residential coop apartment building in NYC, both sound proofing and treatment had to be near perfect. It also had to look good for clients... on a very tight budget.
In this instructable rather than a tutorial on the actual construction I will discuss the design, with links to the materials I used or other resources. This is not laziness, I swear! I just think it is more useful. I assume if you are building your studio you have basic construction skills.
Step 1Planning for noise, heat and power
Not only do you need to worry about sound from outside your studio, but depending on your gear, you need to worry about the noise your equipment makes. Since our studio is a converted bedroom, we had a closet which we could easily isolate and convert into an equipment "room"-- but then heat management became an important issue. Run 3 computers in a small sealed closet and they will crash within a few hours.
Since we were doing a gut renovation we were able to put in central air, but it could not be regular AC. The air handler was placed as far away from the studio as possible, and the ducts were over-sized and had a few extra bends. The same amount of air circulates, but the since it flows more slowly we don't hear the rushing air. One vent leads to the studio, the other into the equipment closet. Another difference with regular AC is the return air. Since our room is completely sealed we had to included vents to let the air out, rather than relying on cracks around the door. Doing this with a thin aluminum flexible tube would have punched a great big hole in our soundproofing, so we used 50 feet of insulated tube instead, twisting it and turning it as much as possible: air escapes, but sound can't make it through.
There is another solution if you're not able to put in central air: a ductless system like this one is fairly quiet and relatively easy to slip in wherever you need it. You just need to have access to outdoor space for the compressor.
Don't forget to plan for power! Use dedicated lines if it's at all possible. Plan where your equipment will be and figure out how much power it will draw. Heat and power are not areas for cutting corners. While your walls are open, think of other wires too. A wireless computer network will not work well in your studio if you build it properly, so it's a good idea to put in some cat6 cables. We have a piano in the living room we knew we would be recording, so we ran a couple digital sound cables from the equipment closet to a closet next to the piano. It's great to be able to make recordings without snaking mic cables all over the place for everyone to trip over.
Another thing to think about is lighting: I don't trust fluoresents because some of them buzz, and I've been trying to eliminate all incandescent lighting (plus incandescent is hot, and there's enough heat generating equipment in a studio as it is....) The obvious answer is LED. This light can be surface mounted, which makes it preferable when it comes to soundproofing. You will want to avoid using a can which will put a big hole in the ceiling (and soundproofing).
48 comments
1-40 of 48next »
Nov 17, 2010. 5:49 PMhenryvrgl says:
great job....could you tell me more about those hinges for the doors?
Nov 3, 2011. 3:34 PMhenryvrgl says:
Belsey,
You are a genuinely good person.
It's been almost an entire year sine you last responded to my question.
They really don't make 'em like you anymore.
Thank you.
Nov 2, 2011. 12:17 AMguitar-is-awesome says:
Hey, what is that desk? It looks like exactly what i need. Did you build it? If so, can you make another instructable? Great instructable btw...
Oct 9, 2011. 9:56 PMbowmaster says:
For the doors, could you use two solid doors with a layer of foam on both sides of each door? Also, how good would a layer of heavy shag carpet on the floor be for sound blocking, especially at the bottom of the door?
Oct 17, 2011. 3:37 AMbowmaster says:
When I say two doors, I mean one on either side of the doorjamb, so there would only be ~1.5" between them. One would open out, and the other would open in. The only problem I see is I would need to get special knobs.
Nov 2, 2009. 12:42 PMj03tv says:
Also tell your husband, Cubase ROCKS!
What films has he worked on?
Does he have a website?
Thanks
Nov 23, 2009. 9:21 AMj03tv says:
Okay, ill check it out! :)
Nov 4, 2009. 7:27 PMJAZ97 says:
would it work in a bedroom
Nov 5, 2009. 1:36 PMJAZ97 says:
lol sorry i was tired havent sleeped in about 2 - 3 days
Nov 2, 2009. 6:32 PMj03tv says:
Your husband makes some nice music.
Nov 2, 2009. 12:39 PMj03tv says:
Lol, the first step should be, "How to ask for permission to remodel the apartment".
$400 for that light fixture is insane, you could build the same one for the price you paid for it or cheaper, and customizable.
There are plenty of instructables for LED lighting, so be sure to check those out for your next project.
The sound proofing looks like it would allow enough peace and quiet for making music.
I want to make a room in my basement sort of like this but I wouldn't need so much sound proof, just enough to block the the low/bass freq's from traveling up stairs.
Nov 2, 2009. 6:18 PMj03tv says:
Although the LED's and components are dirt cheap as well as the power source, its actually really simple to put one together, unless that one has more functionality than an on/off switch. Its just time consuming with soldering and stuff, but I can relate to trying to put a limit on building things. I tend to always wanna build everything that I think would be cool or whatever aswell.
Sep 30, 2009. 10:10 AMshreiber says:
To Raysdad: You can pick up the Green Glue at Trademark Soundproofing with their main location in Rockland County NY. Additionally they have some good Soundproofing Articles on their website.
Jul 14, 2009. 5:26 AMraysdad says:
Any suggestions for a basement studio? We have a full basement, cinder block and concrete walls, open ceiling, and would be starting from scratch. My son wants to build a "room within a room," but it looks to me like the expense is way out of my reach. Where we we find the kind of used material you mentioned? We're over the bridge, in Bergen County. www.skipspainting.com
Jul 14, 2009. 10:00 AMraysdad says:
Good idea. Thanks.
Jun 11, 2009. 6:24 PMguitarman63mm says:
Very, very well written. I've known about the materials and theory involved, but still haven't procured the funds to make it happen. I suppose I'll end up making a very simple one of mdf and non-hardening caulk, but oh well. Has anyone experimented with active noise reduction? I've been thinking that it might be of assistance in studio situations, but I've yet to see a program that creates an inverse wave to destroy the original sound, in real time.
Mar 15, 2009. 9:31 PMmafordha says:
I was curious to know what type of drawer hardware was used for the slide-out keyboard shelf. Thanks!
Mar 13, 2009. 10:43 AMmanleywalker says:
Really nice Instructable and very inspiring. I really liked the way you balanced cost, functionality and environmental friendliness. Bravo!
Mar 12, 2009. 5:30 PMmichel moltrum says:
what can a person say? just excellence in this instructable.
Mar 12, 2009. 7:10 AMendolith says:
Do you have a plot of the frequency response?
Mar 7, 2009. 9:23 PMmanofadventure says:
Excellent information. I am going to set up a studio like this.
Mar 3, 2009. 8:28 AMMahavishnuMan says:
That's great work. I only wish I lived in an apartment where it would be feasible (or allowed) to soundproof like that. One suggestion I might add is that you could build your own diffusers. DIY quadratic residue diffusers have quite a few benefits. First, they're relatively easy to build. Second, they're substantially cheaper than commercially available solutions (and use identical technology). Third, if you can grok the math (which really isn't too difficult) you can design them to target the frequency bands you need, which often makes them work better for your purposes than commercially available solutions. Finally, well... it's fun to build stuff.
Mar 7, 2009. 12:59 AMMahavishnuMan says:
True, anything you get second-hand beats buying it retail or spending for materials. I probably wouldn't use that kit though. Sure, it's a QRD and the principle is the same, but there are two problems I see with it. First, you shouldn't place two identically designed diffusers that close together as it causes lobes in the diffusion pattern. Second, I would think a period of 13 wouldn't be enough to allow smooth diffusion across a three octave band. I'm debating how to create instructables for my own sound treatment as I made everything a few years before I even knew this site existed. I don't have the need to build any more, and the stuff isn't exactly easy to disassemble either.
Feb 28, 2009. 4:03 PMearthstation says:
What did you use for that picture? It looks like Google Sketchup.
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:belsey
I am trying to work on an overly ambitious tome, MAKE ANYTHING, a handbook for saving money, living green and having fun with trash. Trouble is, I keep getting distracted by pop-ups -- the cards, not ...
more »
